Questions/Observations about 3 different methods of sub PEQ (MiniDSP 2x4 and REW) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
Old 04-29-2017, 05:30 PM
Quoted: 449 Post(s)
Liked: 326
Down firing can be interesting for those of us who are not on concrete floors....
Link to budget Home Theater build
http://www.avsforum.com/forum/19-ded...i-version.html
unretarded is offline
Old 04-29-2017, 05:59 PM
citsur86's Avatar
Quoted: 1343 Post(s)
Liked: 528
No clue how I just found this thread now but I had an idea Plasma. Why not set the target to be at the bottom of the dip and PEQ the remaining response down to that? Then just boost Subwoofer channel on your AVR?
EDIT: Nevermind I see now that you fixed by moving. This would have been a suggestion for the original issue of boosting the dip.
citsur86 is online now
Old 04-30-2017, 05:28 AM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 2098 Post(s)
Liked: 618
Without boost filters, the dip would still remain with that approach, albeit slightly better. However, the subjective SQ is best when target level is where REW sets it (halfway between peaks and dips).
Anyhow, this time REW did basically set the target level at the bottom of the now smaller dip.
PlasmaPZ80U is online now
Old 06-06-2017, 09:46 AM - Thread Starter
Liked: 618
here are the updated measures after getting a boom mic stand and measuring in sweet spot 1 foot above highest part of mattress with thick blanket on mattress... stand is not touching anything but floor (except for UMIK-1 usb cable touching mattress)
sub PEQ cut only and YPAO auto EQ off, sub is set to mid bass extension/damping, 100Hz global x-over in AVR... basically everything as I normally listen and no sw dist tweak done (just sub PEQ and YPAO run):
ID:	2174306   Click image for larger version
ID:	2174314   Click image for larger version
Name:	Side Surrounds.png
ID:	2174322   Click image for larger version
ID:	2174330   Click image for larger version
ID:	2174346   Click image for larger version
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
Old 06-06-2017, 10:16 AM
citsur86's Avatar
Liked: 528
sub PEQ cut only and YPAO auto EQ off, sub is set to mid bass extension/damping, 100Hz global x-over in AVR... basically everything as I normally listen and no sw dist tweak done (just sub PEQ and YPAO run)...
Looks good! What is your noise floor? Asking because I thought I remember the suggestion being to measure at 40db higher than the noise floor and noise floor in most cases being around 50db. Not sure if it really effects the measurements much, but maybe run a couple sweeps around 90db and see how it looks.
Old 06-06-2017, 11:21 AM - Thread Starter
Liked: 618
noise floor is pretty low, below what the UMIK-1's limitations are (I believe it is limited to 50dB noise floor based on Jerry's guide, page 50):
"Your listening room’s noise floor
Using the REW SPL Meter, click the red record button. Make the room as quiet as possible—turn off the HVAC system, turn off appliances such as the refrigerator if it is within hearing distance, quiet the wife, kids, pets, etc. When things are as quiet as possible, the REW SPL Meter is displaying the noise floor in your room. Most typical listening rooms with have a noise floor of approximately 40dB. However, with the USB mic’s we are seeing readings of 50dB, which is the lower limit of the USB microphone’s measurement range."
In any case I have measured 10dB higher before, and aside for distortion figures being lower and perhaps some very low dB noise in waterfall, there is no noticeable difference between 75dB peak level and 85dB peak level (based on spectrogram scale method). I did measure LFE at 85dB (just used a -10dB offset afterwards) and FL+FR+sub was 6dB higher than the individual parts, but again used -6dB offset afterwards to compensate).
Old 06-06-2017, 11:24 AM - Thread Starter
Liked: 618
^If there is noise, with frequency response you get odd, very narrow upward and downwards spikes in the lower dB areas with unsmoothed modal response.
Old 06-06-2017, 11:46 AM
citsur86's Avatar
Liked: 528
Got it - so maybe I don't have to run the sweeps so loud at 12am when the family is sleeping. Since it's basically the only time I can get some quiet in my house, I bought a couple sound machines for mine and my son's rooms upstairs. Blocks the sweep sound entirely.
Old 06-06-2017, 11:48 AM - Thread Starter
Liked: 618
as long as 75-80dB level looks the same as 90dB you should be good
Old 06-06-2017, 11:57 AM - Thread Starter
Liked: 618
here is an example of mild noise past 200Hz on the LFE measure (first is low extension/damping with noise, second is mid without noise):
Name:	noise past 200Hz.png
ID:	2174522   Click image for larger version
Old Today, 09:12 AM - Thread Starter
Liked: 618
.mdat file for those who want to see it.
