JL sub question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-12-2017, 09:25 PM - Thread Starter
Liked: 0
JL sub question
I am setting up a 12 x 18 foot home theater and have dual JL d110's on order. Having second thoughts and wondering if a single 12 inch fathom would be better for a small room. 50/50 music and movies.
ryno1330 is offline
post #2 of 11 Old 08-12-2017, 10:02 PM
xcjago's Avatar
Quoted: 13 Post(s)
The F112 is a big step up from the D110. It has deeper bass extension and more output than even 2 of the D110. The only advantage with dual D110 is you can get a smoother frequency response.
xcjago is offline
post #3 of 11 Old 08-13-2017, 10:06 AM - Thread Starter
Liked: 0
Thanks. I'm guessing for tactile bass and thump I would get more from the f112 for movies...would that be accurate? Maybe the room correction software would help smooth it out too vs the d110s?
ryno1330 is offline
post #4 of 11 Old 08-13-2017, 10:16 AM
Jonas2's Avatar
Quoted: 1366 Post(s)
Liked: 585
Yes.
Only so much room correction can do - sure, it'll help, but it will not be able to do what two subs can. Doesn't mean one sub properly placed won't be good, but I rarely see anybody stating that one sub is better than two.....
JL makes nice sub-woofers, but they are pricey. Affording 2 x F112s might be challenging, but if you can do it - do it. There are other very high quality subs though that will allow you to stretch your budget farther, with excellent performance.
5.2.4 System....Display: Sony XBR-65X930D; Processing: Anthem AVM60; Power Distribution: Panamax M5400-PM;
Mains:
Paradigm 85F and 55C (Piano Black); Side Surrounds: Totem Acoustic Tribe III (Dusk); Amplification: D-Sonic M3-2800-7 (7ch. x 400w);
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Sony BDP S-470, Pioneer CLD-59
Jonas2 is offline
post #5 of 11 Old 08-13-2017, 10:43 AM
Dave-T's Avatar
Quoted: 539 Post(s)
Liked: 250
Jl Subs are nice. I would definitely get I JL F112v2 over two D110's. F112v2 is going to hit lower and also has DARO and ELF which the Dominion series does not. Buy one F112v2 now and if you need another which you probably will not save up and buy another at ac later date. I my self for a 10x21x12 room with 9' ceilings am going to buy one F112v2 at first and if I need a second will buy another or one F113v2 and be done. Just Make sure you get a F112v2 not a F112v1, there is a big difference.
Dave-T is offline
post #6 of 11 Old 08-13-2017, 10:50 AM - Thread Starter
Liked: 0
Yes.
Great thanks guys. I was also going to consider dual f110s but wonder if I would run into the same issue with less output for HT like the d110s (they do have a more and lower output than the d110s but prob not as much as the single fathom). Oh choices. Thanks again. I do realize I can get more sub for the money but like working with a local dealer and like jls fit and finish.
ryno1330 is offline
post #7 of 11 Old 08-13-2017, 11:09 AM
Dave-T's Avatar
Quoted: 539 Post(s)
Liked: 250
FYI JL no longer sells the F110v2 anymore. If your dealer has then they are left over stock he/she has. I spoke with Randy at JL last month about specifics on a F112V2 vs F113Vs and he informed me that they had discontinued the F110V2. Who is your local dealer? is your local dealer giving you a good price or are you being quoted list price? What speakers are you running in your setup?
Dave
Dave-T is offline
post #8 of 11 Old 08-13-2017, 11:31 AM - Thread Starter
Liked: 0
Dave
Edit - after talking with JLdirectly i actually decided to go with dual e112s. I think it should be a good setup. Thanks for everyone's help.
ryno1330 is offline
post #9 of 11 Old 08-14-2017, 06:10 PM
xcjago's Avatar
Quoted: 13 Post(s)
That's a good way to go. The E112 is not far behind the F112 and you save a good amount of cash.
xcjago is offline
post #10 of 11 Old 08-14-2017, 06:17 PM
Jonas2's Avatar
Liked: 585
Good move! I think you'll be happy with those duals.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #11 of 11 Old 08-15-2017, 07:56 AM
Dave-T's Avatar
Quoted: 539 Post(s)
Liked: 250
Nice choice
Dave-T is offline
