Subwoofer rattles playing bassy songs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 08-23-2017, 09:36 AM - Thread Starter
.Kyle's Avatar
Liked: 0
Hey guys. How are you all?
I have the same subwoofer as I've written about in my previous posts, it's still wonderful. Same PSU powering it, etc. Sometimes when playing bassy songs for example, EDM, Trap/Rave, the front of the subwoofer vibrates or rattles a little bit, not always, but sometimes.
The part I am talking about the outer part with the arrow pointing next to it. It's the round outer part that sounds like it rattles.
The other photos are too large to upload, so I've added them and a video of the sub playing in a zip. Click to go to my Google Drive.
.Kyle is offline
post #2 of 16 Old 08-23-2017, 10:05 AM
littlefoott's Avatar
Quoted: 344 Post(s)
Liked: 198
you bass boost is real high
have you seen this setup guide
https://www.crutchfield.ca/S-10g5sGs...rs/tuning.html
Audyssey is a great start, but not always a great finish.
Receiver:Marantz SR-5010, Speakers:Def Tech ST-8060 towers, CS-8040 center, SR-8040 surrounds, Pro Monitor 1000 heights
Subwoofer: SVS PB-2000
TV: 65" LG UG8700 remote: Harmony 1000
littlefoott is offline
post #3 of 16 Old 08-25-2017, 06:55 PM - Thread Starter
.Kyle's Avatar
Liked: 0
Yeah it is quite high, although I'm just not sure why I hear rattling sometimes.
.Kyle is offline
post #4 of 16 Old 08-31-2017, 03:32 PM
Dave-T's Avatar
Quoted: 519 Post(s)
Liked: 241
Sounds like you are pushing the limits of the subwoofer and asking to much it. Are you getting distortion? If so time to upgrade?
Dave-T is online now
post #5 of 16 Old 09-09-2017, 05:20 PM - Thread Starter
.Kyle's Avatar
Liked: 0
There is no distortion of any kind. Just sounds a little rattly at times. I've been told not to worry too much about it but just not to have the bass boost too high during bassy songs.
.Kyle is offline
post #6 of 16 Old 09-11-2017, 11:17 AM - Thread Starter
.Kyle's Avatar
Liked: 0
I've been reading up on some websites and researched how subs work, what components are what, etc. From researching and some slight testing I am wondering..could it just be a wire touching the woofer during high excursion for example? I have tried retuning the amp and have lowered the bass boost. At first I did test increasing the amp gain a little and then backed off when it started getting too much.
The following settings sound fine, no rattle or vibration of what ever it is. It just sounds like the black outer ring has a hole or something or other, I don't know.
https://drive.google.com/file/d/0Bx-...ew?usp=sharing
EDIT: If I apply a little bit of pressure on the left side of the rubber outer ring the rattle goes away.
.Kyle is offline
post #7 of 16 Old 09-11-2017, 01:14 PM
Quoted: 344 Post(s)
Liked: 198
unscrew the amp and take a look inside
and check the tightness on the subwoofer screws
post #8 of 16 Old 09-11-2017, 02:04 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
That sounds like voice coil rub if pushing on one side of the surround stops it, but voice coil rub is more of a scratching sound than rattle. If you push on the opposite side does it make it louder/worse? Can you post a video of it or audio?
Edit I see you did post a video, yeah that sounds like tinsel lead slap. You can remove the woofer and put something on the wires to pad between the wires and cone.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is online now
post #9 of 16 Old 09-11-2017, 02:45 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
If you want to test to see if it is voice coil rub play a lower test tone at 20hz or so and see if you can still hear it, it will sound like a scratching sound. At a lower frequency, it should be easier to tell if it is slap or rub. Here are some tones if you need them https://1drv.ms/f/s!Alekwwtstb8wiso36N8W9byD2Li_ng
Just be careful with the volume, you want enough to make the sub move a lot but not push it too far so it is bottoming out. Try some higher frequencies at 60 and 80hz also, these you can turn the volume up higher. Using test tones helps to hear the "noise" verse using music. It is hard to hear in your video because the mic on your phone or camera sounds like it is distorting also but it sounds like a buzzing which would be the tinsel leads.
post #10 of 16 Old 09-11-2017, 04:22 PM - Thread Starter
.Kyle's Avatar
Liked: 0
The first two tests (010-019 Hz) and (020-029 Hz) does not make the sound in question. As it is 12:22 AM where I am right now, I will try and record more tests and send the footage tomorrow.
.Kyle is offline
post #11 of 16 Old 09-13-2017, 09:07 AM - Thread Starter
.Kyle's Avatar
Liked: 0
Upon reading and doing more research I stumbled across this video on YouTube. This is what my sub does if my amp isn't tuned correctly. (the gain I mean):
It starts to clip out. I'm watching that video and have now learnt that it's not good if my sub does this so I'll take that into careful thought and try to prevent my sub from doing this. I just don't really know what I should really set my crossover (freq) and gain to though... I mean, if I turn up the gain with a song playing a bit when tuning/testing, the gain decrease/increase makes my sub start clipping so I have to try and either increase to a stable set or decrease.
.Kyle is offline
post #12 of 16 Old 09-14-2017, 04:41 AM
schwaggs's Avatar
Quoted: 171 Post(s)
Liked: 266
What do you mean by "I have to try and either increase to a stable set..."
If you are truly experiencing clipping, increasing the gain will only make it worse. You cannot turn up the gain to "move past" clipping...
schwaggs is offline
post #13 of 16 Old 09-14-2017, 09:28 AM - Thread Starter
.Kyle's Avatar
Liked: 0
If I increase the gain a bit higher the clipping goes away but the bass is too much even with the bass boost at 0 dB, it still vibrates my floor of my apartment complex, the other side of my corridor, below me and above me. This is why I have to try and sometimes decrease the gain at times.
EDIT: Okay so this is what I mean about my sub "rattling". This is the best description and "showtell" I can give.
At the start of the video you can hear a rattling before I start speaking. That's what I mean.
I've removed the old photos/video from my Google Drive and uploaded the new ones of what my crossover, bass boost and gain are set at.
https://drive.google.com/drive/folde...EU?usp=sharing
.Kyle is offline
post #14 of 16 Old 09-14-2017, 05:50 PM
bscool's Avatar
Quoted: 687 Post(s)
Liked: 550
It sounds like tinsel lead slap to me like this
it is a fairly easy fix. Take the subwoofer out and put something soft like foam insulation or speaker gasket tape between the leads and the cone. Or they have terminals that can be turned or bent. Every sub will be made a little different so it is hard to tell you what to do without seeing it.
I would say the reason it stops when you touch the cone is because it limits the excursion just enough so that the tinsels are not able to hit the cone and vibrate.
post #15 of 16 Old 09-15-2017, 10:30 AM - Thread Starter
.Kyle's Avatar
Liked: 0
Would a bit of bubblewrap help too? I don't have anything spongey like that.
.Kyle is offline
post #16 of 16 Old 09-15-2017, 10:17 PM
Quoted: 13 Post(s)
id try to find foam, and not a super "plasticy" type one, something soft. Bubble wrap will make noise like a plastic grocery bag
Canadian Bronco is offline
