subwoofer recommendation - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By iceatola
  • 1 Post By stealthpentai
post #1 of 11 Old 09-24-2017, 10:01 AM - Thread Starter
Liked: 2
Looking to spend around $200
Going to be for mainly movies and games. Room is about 11x18 feet.
I was looking between the BASX S8 and the JBL550 as they are both around the same price, but I dont know which would be better.
Looking for other recommendations too.
stealthpentai is offline
post #2 of 11 Old 09-24-2017, 10:39 AM
iceatola's Avatar
Quoted: 47 Post(s)
Liked: 55
For your budget get the Bic-f12 sub instead
MIX_MASTER_ICE likes this.
LG 55inch UHD TV
Receiver: Emotiva Fusion 8100
Amps: Emotiva XPA-3, UPA-700
Polk Signature Series - S20 for L/R, S35 Center, S15 Surrounds
Subwoofer PSA 2xV1801
Roku 4, Nvidia Shield, Darbee Darblet 5000
iceatola is online now
post #3 of 11 Old 09-24-2017, 10:43 AM - Thread Starter
Liked: 2
I was thinking of the BIC F12 too, you think that would be better than the JBL 550?
post #4 of 11 Old 09-24-2017, 11:21 AM
iceatola's Avatar
Quoted: 47 Post(s)
Liked: 55
To me it's the best for the most bang for your buck
LG 55inch UHD TV
post #5 of 11 Old 09-24-2017, 11:22 AM
gajCA's Avatar
Quoted: 4322 Post(s)
Liked: 2779
Not a chance.
https://flash.newegg.com/Product/9SI...E&gclsrc=aw.ds
Geoff A. J., California
gajCA is offline
post #6 of 11 Old 09-24-2017, 03:50 PM
MIX_MASTER_ICE's Avatar
Quoted: 1426 Post(s)
Liked: 1202
For $200 or less the F12 is always a popular choice. The Bic RTR-EV1200 is a slight variation of the F12. It's available at rakuten.com via Beach Audio for $177.49. You also get 5% rewards points, which amounts to $8.85. The Jamo J-110 is also still available for $180 on ebay. I would avoid the JBL 550p sealed sub. From what Ive read it doesn't have any real extension advantage over these ported subs and you can bet being sealed it won't have near the output lower in range than the ported subs. I had the JBL sub150p from the older Studio line a few years ago and this 550p looks like it may be using the same 10" PolyPlas driver and 300w/500w amp. Granted the sub150p was ported, but to me it was a very poor performing subwoofer.
Rec Room>Vivitek 1080p projector w/100" screen/Hisense 65" 4K, Onkyo TXNR656, Fluance signature towers & center, AV5 sides, Loft 40 rears, RBH I-12/e x2, I-12 x2 subs. Living Room>Sammy 59" Plasma, Onkyo HTRC560, Klipsch KF28 L/R, KC25 center, Polk RC60i in-wall rears, SVS PB12NSD (x2) subs. PC set up> 27" LG IPS, Onkyo TXNR509, Primus P363's, JBL 550P sub. Master Bedroom>Samsung 42" LED, Pioneer VSX532, Denon 5 spkr set, Jamo J110 sub. Gaming> PS4 (x2), PS3, XBox One (x2), XBox 360
MIX_MASTER_ICE is online now
post #7 of 11 Old 09-24-2017, 03:54 PM
Tom Vodhanel's Avatar
Quoted: 2059 Post(s)
Liked: 6058
Might be worth a read thru.
http://thewirecutter.com/reviews/best-budget-subwoofer/
Tom V.
Power Sound Audio
“Quality isn't expensive, it is priceless" --- fortune cookie
Tom Vodhanel is online now
post #8 of 11 Old 09-24-2017, 04:07 PM
torii's Avatar
Quoted: 1547 Post(s)
Liked: 842
brent butterworth was the reason I bought my klipsch over monitor audio silvers back in the day when he worked at hometheatermag i believe.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #9 of 11 Old 09-24-2017, 09:21 PM - Thread Starter
Liked: 2
How is the Acoustech PL-200 II versus the JBL 550 / BISX S10?
post #10 of 11 Old 09-25-2017, 02:35 PM
gajCA's Avatar
Liked: 2779
The PL200 pretty much plays down to only 30hz.
"The PL-200 does not have a lot of extension or output and unfortunately the inductance of the driver limits the top end output as the upper bass of the response is greatly rolled off. On a positive note this subwoofer has a good limiter in place which makes it dummy proof and prevents you from blowing it up with too much input signal. Also the distortion performance above tune is quite good even at maximum output, but some vent noise was notable at the highest output levels. In room this unit should extend to 30Hz with useful output. "
http://data-bass.com/data?page=system&id=47
gajCA is offline
post #11 of 11 Old 09-26-2017, 08:28 AM
fast200's Avatar
I am in a similar situation as the OP with a similar room size. I have a soundbar I'd like to add a sub to for home theater use without spending a fortune. I've seen recent deals on the Jamo J-110, JBL Studio 550p, and the BIC F12. How do these compare for my use? Are these models overkill for my intended use case?
fast200 is offline
