* Offical Velodyne Support Thread * - Page 323 - AVS Forum
 7Likes
post #9661 of 9687 Old 07-30-2014, 07:32 AM
sparoz's Avatar
Originally Posted by Rob Morse View Post
It sounds like you have tried all the settings I would recommend, the next step may be to have the 1/2 watt bypassed to allow the always on function to work. The service center can also test that the board is functioning correctly. The subwoofer should stay on provided there is signal coming into the LFE input. With the 1/2 watt circuit the DD plus RCA input requires a minimum of 10mV RMS @ 80Hz when the line control trim set to maximum to stay active.
I have noted you said RCA, and I am connecting through the XLR. Would that have made any difference?
sparoz is offline
post #9662 of 9687 Old 07-30-2014, 08:27 AM
Rob Morse's Avatar
Liked: 25
It might, I would give it a try.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
post #9663 of 9687 Old 08-04-2014, 08:52 PM
Liked: 0
DPS12 Issue
Hello -
New to this forum and unfortunately not very audio savvy. I have an 8+ year old DPS12 that very recently started to give out static and then go in & out on a regular basis. It now fails to produce anything even though it is powered on. Any suggestions on what is wrong and a ballpark figure on repair cost? any suggestions on a comparable velodyne replacement is repair too expensive?
aciaccio is offline
post #9664 of 9687 Old 08-05-2014, 07:16 AM
Scott Oakley's Avatar
Liked: 80
Originally Posted by aciaccio View Post
Hello -
Suggest waiting for Rob Morse of Velodyne to respond; he's very responsive and helpful. I recently had to replace the amp in my SPL1500 (ended up with a refurbed one) and it works fine. Velodyne's customer service and responsiveness were excellent.
Panasonic 2013 55VT60
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
Scott Oakley is online now
post #9665 of 9687 Old 08-05-2014, 08:11 AM
Rob Morse's Avatar
Liked: 25
Hello -
The static output would indicate an electronics issue, assuming you have verified the source is good.
The easiest way to confirm the issue resides in the subwoofer is to connect the left and right outputs of a working disc player directly to the subwoofer's left and right inputs, so that there are no other components in the hook up. Place a CD with bass in the player and hit play. If the subwoofer continues to exhibit the issue, then the electronics require service, if the sub plays the bass cleanly, then the issue resides elsewhere in the system.
If it turns out the subwoofer is in need of service, we can assist you by having you complete this RMA request form. Once we receive your completed form we will be able to provide you with an estimate, and instructions for removing and shipping the rear panel assembly.
As to your question about a current replacement, the DPS would fall somewhere between the Impact and Wi-Q series subwoofers.
post #9666 of 9687 Old 08-06-2014, 07:16 PM
Liked: 0
Thanks for all your help!
aciaccio is offline
post #9667 of 9687 Old 08-09-2014, 07:55 PM
Harbinger's Avatar
Sorry, I was unaware, this can be the problem with this type of troubleshooting.
Assuming the driver was behaving itself when buttoned up, it is difficult to steer you in a particular direction, the failure mode is not a common occurrence. If I were to try and find the point of failure, and the symptom was the power cutting out, I would start with the controller and power supply boards before moving to the amplifier. I can provide schematics to aid in the diagnostic if you like.
I've replaced all the electrolytic capacitors on the sub's main PC board and the four sub-boards. Unfortunately, things are now worse. I only get random clicking, no incoming audio, and roughly every 25 seconds I get a "brrrow-rrow" sound like the sub's just been powered up. I swapped the caps back to the originals--same problem. So, something went south in the replacement process.
The provided schematics were hard to read but I was able to determine that all caps were installed correctly, and the values were in the correct places as I swapped them 1 for 1. What makes me worry a bit is that there are several trim pots on the sub-boards and no references on the schematics as to how to calibrate them. Consequently I haven't touched them.
Normally I order low-ESR caps when fixing power supplies for monitors. I ordered low-impedance caps for replacements for the sub, except for a few that were unavailable in low impedance models and used standard electrolytics instead.
Do any of these symptoms sound familiar?
Harbinger is offline
post #9668 of 9687 Old 08-10-2014, 06:25 PM
Liked: 0
Hi Rob
I have a Velodyne HGS-12. The label on the rear says it was made in 1999. It has been great for me. I usually unplug it when im not using it, as i only use my theater about 2-3 times per month. today i plugged it in and it doesnt seem to have any power at all. no faint hum or buzz from the speaker (there usually is) so im assuming my amp is in need of repair. you agree? any tips? time to fill out the RMA form?
JeremySt777 is offline
post #9669 of 9687 Old 08-11-2014, 06:32 PM
Rob Morse's Avatar
Liked: 25
I am sorry but I am unable to provide much guidance here. I am not a repair technician, and the ULD has not been a supported product for nearly 8 years. I truly wish I had some knowledge to share on this topic, but the techs who worked on these units are no longer with us either.
post #9670 of 9687 Old 08-11-2014, 06:35 PM
Rob Morse's Avatar
Liked: 25
Originally Posted by JeremySt777 View Post
Hi Rob
It would seem that the electronics may have failed, to confirm I would suggest testing the subwoofer.
post #9671 of 9687 Old 08-28-2014, 09:41 AM
JoeBlow74's Avatar
Quoted: 13 Post(s)
Liked: 37
My wife and I purchase two Velodyne DEQ-12R subwoofers from a local high end audio/video shop about 5 years ago. Both have been working rock solid the entire time. About two weeks ago I started hearing this high pitch whine coming from each subwoofer. One is louder than the other, but still make a whine. I can hear this whine while sitting in my chair 6 feet away. Both subs still work excellent minus the whine. I have unplugged the sub cable and the noise is there. I have plugged each sub into a different receptacle to check if I have bad power coming to my house. The noise is still there. I have had both subs plugged into a power conditioner/regulator the entire time I have owned them, so I know the power is clean and always flowing. Would anybody have any recommendations on what this noise might be? A friend told me that the built-in amps might be going bad. I hope this is not the case. Any suggestions would help? Again, this just started about two weeks ago.
X-Box Live name: OGgamer1974
If you want to be friends on through xbox network, just send me a request through X-Box Live and mention AVS in the request.
Cheers
JoeBlow74 is offline
post #9672 of 9687 Old 08-28-2014, 12:19 PM
Liked: 80
Interesting...Its suspicious that both subs would start this at the same time. I would do some low level trouble shooting:
1. Turn ALL components off. Is the noise still there?
2. Run an extension cord to an outlet as far as possible from the one you normally use for them and plug them in (with all other components off). Is the noise still there?
3. Does the whine increase/decrease with volume changes a the AVR or subs?
4. Is there some other source for the whine (fridge, a/c, etc)?
5. Try the method above (plug a CD player output directly into the sub).
Keep us posted...
Scott
Marantz SR-5005 AVR
B&W 805 Speakers
Velodyne 15" Sub
TiVO Roamo OTA
post #9673 of 9687 Old 08-28-2014, 01:21 PM
Rob Morse's Avatar
Liked: 25
As I read your description, you have disconnected the subwoofers from your A/V system so that only the power was connected, and you still experienced the issue. If this is the case then it would seem that there is an issue with the electronics. It is unusual for both subs to exhibit the same issue at nearly the same time, however it is possible that even with a surge suppressor present that an electrical anomaly could have instigated the issue. Regardless, we can assist you in having these units repaired. Complete this return order form and send it to service@velodyne.com, we will provide you with pricing and information about having the electronics packs serviced.
post #9674 of 9687 Old 08-28-2014, 11:58 PM
conkers's Avatar
DD18+ power issue
My authorised dealer and installer has just gone off on summer holidays, maybe you can help in the meantime. The sub is working fine, however the power toggle seems to be having issues. It was previously set up as active mode, and has been working fine, switching off as normal if no signal detected for several minutes. However, recently it has started switching on and off completely randomly, even when the rest of the system is switched off. I changed the power mode to "inactive" so that it would be on all the time, and yet still it is switching on and off randomly. Any ideas please? It is a 230V unit supplied to me in HK and is still within warranty but I am hoping a return isn't required! Thanks in advance.
conkers is offline
post #9675 of 9687 Old 08-29-2014, 02:42 AM
krilin's Avatar
Liked: 0
Can you please help me very much, where can I get it VELODYNE CHT-12Q amp panel?
Hungary order shipping?
krilin is offline
post #9676 of 9687 Old 08-29-2014, 11:23 AM
SoThere's Avatar
Hi, Rob:
The recent Napa Quake damaged much of our audio gear, including our pair of DD15s. Can scratches and gouges on the black gloss finish of these be repaired or, if not, are replacement cabinets available?
I haven't been able to check the functionality of the subs or other gear, as it will take several weeks for cleanup, since our west Napa neighborhood and downtown were the hardest-hit areas. As earthquake insurance is prohibitive in California, few people have any coverage; thus, it will take months or years to recover. A block or two away, a house shook off its foundation, as a fault line ran across the street and under the house. This was the case with several homes, some of relatively recent build from the eighties or later: lots of red tagged houses. Our place seems safe structurally, but the contents are pretty well trashed, including about $15K in speakers.
Thanks for your help,
Rich
Shaky Napa Valley
Eschew obfuscation.
SoThere is offline
post #9677 of 9687 Old 08-29-2014, 12:40 PM
Rob Morse's Avatar
Liked: 25
If you disconnect the input cables, so only the power cable is connected and place the subwoofer into standby, will it wake up after a period of time?
post #9678 of 9687 Old 08-29-2014, 12:42 PM
Rob Morse's Avatar
Liked: 25
For Velodyne sales, service, and support in Hungary please contact our regional distributor:
HaziMozi Studio Kft.
Honfoglalas ut 111 (Peterhegyi es Ady Endre sarok)
Budapest
1221
Hungary
Tel : 36 70 3330099
Email : alex.portoconstruct@gmail.com
Url : www.THX.hu
post #9679 of 9687 Old 08-29-2014, 12:49 PM
Rob Morse's Avatar
Liked: 25
Originally Posted by SoThere View Post
Hi, Rob:
Rich
Shaky Napa Valley
As a native Californian I certainly understand the damage earthquakes can cause, and as a homeowner in California have been forced into the same insurance situation. I wish I could give you some good news, but unfortunately replacement cabinets are not available for the original DD series subwoofers.
As far as repairing damage to your cabinets, depending upon the extent of the damage, a profesional cabinet shop or speaker repair shop may be able to help. Unfortunately since the cabinets were purchased from a contract manufacturer and not assembled by us, we do not have the capabilities to repair them.
post #9680 of 9687 Old 08-29-2014, 02:14 PM
conkers's Avatar
Thanks Rob, will report back.
conkers is offline
post #9681 of 9687 Old 08-29-2014, 02:23 PM
SoThere's Avatar
Thanks for replying, Rob. I'll see if I can find a cabinet shop.
Cheerio,
RJ
Eschew obfuscation.
SoThere is offline
post #9682 of 9687 Old 08-29-2014, 02:55 PM
conkers's Avatar
Still the same Rob, in "inactive" standby mode it still switches on and off randomly with no signal cable attached.
conkers is offline
post #9683 of 9687 Old 08-29-2014, 03:10 PM
Rob Morse's Avatar
Liked: 25
Can you PM me the serial number of your subwoofer please.
post #9684 of 9687 Old 08-29-2014, 04:01 PM
conkers's Avatar
PM Sent Rob.
conkers is offline
post #9685 of 9687 Old 08-30-2014, 12:02 AM
krilin's Avatar
Liked: 0
Budapest
1221
Hungary
Tel : 36 70 3330099
Url : www.THX.hu
Thank you very much I'm looking for them
krilin is offline
post #9686 of 9687 Old Yesterday, 06:25 AM
orcrone's Avatar
Quoted: 34 Post(s)
I need some advice
To increase the WAF we're building a home entertainment credenza which will hold the electronics and subwoofer (not MY first choice). When built I planned on ordering one or two SVS SB-2000 subs. I just learned that I may be able to purchase an HGS-12 subwoofer, about 12 years, for $200 - 300. Just wanted to get opinions on purchasing this sub. It will be used in a living room open to other rooms, so it's a fairly large area (about 5000 cu. ft.?).
orcrone is online now
post #9687 of 9687 Old Yesterday, 09:23 AM
Liked: 0
Velodybe servo s
Originally Posted by David Bott View Post
AVS Forum welcomes Bruce Hall, President/CEO of Velodyne.
In this thread, please feel free to ask support questions in regards to Velodyne products. Velodyne staff will monitor the thread and respond as they can. Members of this forum of course are also welcome to help out as they can. For after all, this site is dedicated to people helping people in Home Theater.
I have a 14 year old subwoofer fsr -15 that now is making an ugly background sound ) .I dont know if it is electronic or blown speaker. What are my options
simapc
simapc is offline
Velodyne Acoustics , Velodyne Impact 10 10 Subwoofer , Velodyne Wiconnect 10 Wireless Subwoofer , Velodyne Eq Max 8 8 Subwoofer , Velodyne Eq Max 10 10 Subwoofer , Velodyne Eq Max 12 12 Subwoofer , Velodyne Eq Max 15 15 Subwoofer , Velodyne
User Tag List
