* Offical Velodyne Support Thread * - Page 325 - AVS Forum
 9Likes
post #9721 of 9743 Old 09-18-2014, 07:17 AM
Flo from France's Avatar
Update regarding my defective unit ( DD15+)
Dear all,
As you may know, I've shared here few weeks ago a description of the problem that I'm currently facing to with my Velodyne DD15+ (bought in Paris at the end of 2011) : for more details, please see page 319 of this thread.
After some discussions with "Rob Morse" and "Jeff at Velodyne" (via PM), it was clear that I had to have my subwoofer serviced. I've then made the travel from Normandie to Paris to have it serviced (thanks to my local dealer) by the french distributor, HamySound. Unfortunately, I learnt at that time that even if this subwoofer was still under the umbrella of the "3 years US guarantee", it was exceeding the 2 years european guarantee by several months... :-(
After investigations by the technical staff from Hamysound, it appears that the complete amplification board has to be changed. To do so, Hamysound is asking me 700€ (about 905 US $ !) parts+labor. I'm very surprised that such a high-end subwoofer (that I've purchased for 4840€ in France (about 6000 US $ !!!) has to be serviced just few months after the legal guarantee. I have to add that this subwoofer was NEVER driven hard (especially because my wife was pregnant in the 2012/2013 timeframe, my young daughter is here to testify ;-) so I don't understand the reason of such an expensive repair especially for a device that was respected and used at low volume (05-15), only during several dozen of hours. To me, it seems that this unit had a hidden defect when I bought it...
I've explained this issue to velodyne thanks to the "contact us" section of their web site and have asked for a gesture of goodwill but with no success. Is there someone here that might help me ?
Many thanks in advance !
With my best regards,
Flo, from France
Flo from France is offline
post #9722 of 9743 Old 09-18-2014, 08:00 AM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
Originally Posted by Flo from France View Post
Dear all,
Flo, from France
Velodyne did receive your email, it was in this mornings in box and I have responded to your email. In my email I asked for you to provide some additional details so that we might be able to assist you. Please reply to my email with the requested information, I will then discuss the matter with our French distributor to see if they are willing to work with you.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
post #9723 of 9743 Old 09-18-2014, 01:54 PM
Hello Rob Morse,
Many thanks for your feedback : I'll provide the requested informations within the next minutes.
Best regards,
Flo, from France
post #9724 of 9743 Old 09-18-2014, 02:28 PM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
Hello Rob Morse,
Best regards,
Flo, from France
Your message was received.
post #9725 of 9743 Old 09-19-2014, 12:10 AM
Liked: 0
Velodyne does not have stock of the sub-assemblies any longer, the components themselves can be purchased at virtually any local or online electronics parts house.
I had a play with my two faulty VA-1210xii's today. The unit that when demo'd to me did not produce any output strangely enough worked today when I fed it a source! It is also the one I had previously had a look at the amp. The only thing that I could visually discern that could possibly be an issue was that the two large capacitors (4700uF 50v electrolytics - power supply filters?) had very slightly bulging tops, but were bulged equally. I pulled the amp out of the unit that emits the loud hum and these two caps were of a different manufacturer (slightly smaller) but same value. They didn't have bulged tops, but on one the "shrink wrap" on it had cracked around the top (maybe a sign of stress?). I had read a post here several pages back where a guy had replaced these caps and fixed his loud hum issue on a different model, so I figured I had nothing to lose, so I unsoldered that cap with the cracked wrap, and replaced it with one of the bulging caps from the working amp. Plugged it in and turned it on....no hum, and working fine when hooked up to a source! So 4 caps ordered from online supplier - I may as well replace both pairs on both amps, as maybe the bulging ones cause the 1st amp to lose it's output sometimes (or it could have other issues like a dry joint somewhere that I "remade" when I removed and replaced the amp), and I have to resolder a cap back into it anyway. So with any luck, in a few days I will have two working VA-1210xii's for $12 in parts.
AndyfromOz is offline
post #9726 of 9743 Old 09-19-2014, 01:58 PM
rob80b's Avatar
Liked: 31
I understand better now, your having difficulty getting acknowledgement when switching presets. Unfortunately we do not have replacement LED logo badges for all the DD subwoofer. Depending upon the serial number we might be able to get you a replacement. Please contact service@velodyne.com for assistance.
Hi Rob
Just to let others know I had success with replacing the Logo/light, but is a bit of DIY once you figure out which DD Logo Badge you have as there are two versions and not all are available.
Also there is no led as such which illuminates the logo, the logo is the light.
The original badge is screwed and glued to the front bezel and needs to be carefully pried off, I used an oyster shucker, see photo for removed badge assembly and new one installed.
Name:	DD LOGO BADGE.jpg
ID:	269769   Click image for larger version
ID:	269785   Click image for larger version
ID:	269793   Click image for larger version
Robert
Toronto, Ontario
rob80b is offline
post #9727 of 9743 Old 09-19-2014, 02:57 PM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
I am glad to hear you were able to resolve the issue.
post #9728 of 9743 Old 09-21-2014, 09:24 AM
VTECH8TR's Avatar
Rob,
I have a Velodyne HGS12 with the amp model # DD12BG and it started to flutter when a bass not hits. Is my amp or sub blown? Is it worth sending the amp to fix? How much does this normally cost.?
Luis
VTECH8TR is offline
post #9729 of 9743 Old 09-22-2014, 06:19 AM
kcd1369's Avatar
Liked: 0
Hi,
i have a Velodyne HGS12BG. It started making a buzzing sound (very loud) intermittently. Then it just died. The power indicator comes on. No protection circuit light.
But no output either. i absolutely loved this sub. And want to get it repaired if its not going to cost an arm and a leg.
With the weight of this thing in mind, can I send the amp board in for repair or do you need the whole cabinet? Or, could I buy the parts and do the repair myself? I don't trouble shoot to component level, but with a drawing I can check to the board level at least.
Thank you in advance for any help you can provide.
David
kcd1369 is offline
post #9730 of 9743 Old 09-22-2014, 08:26 AM
posimosh's Avatar
So, do any of you (mostly) lovely, (mostly) gentlemen, have any use for an intact, working, uld-12? Like all of the uld line of this vintage, the surround needs replacing. Other than that, it's nearly perfect. I've been holding on to it for around 5 years now, afraid to use it with the disintegrating surround (and light-sleeping child and girlfriend.
I just powered it up the other day and everything still works as it should and it's all original (even the caps are still going strong.) the only thing I'm missing from back when I saved my allowance for about 2.5 years to buy this sub I heard at filco (I think... Maybe it was another stereo shop in Sacramento who's name escapes me...) is the remote control (not to be confused with the "remote", which is what they call the control box... The control box which I have).
Anyway, I know this is dangerously close to belonging in the "classified" section, so excuse my posting here if it displeases you... Like just want to make sure it goes to a good home if at all possible.
Anyway, if y'all have any ideas, I'm all ears. I currently split time between SF and (the armpit of California), Sacramento (which is where the sub is located currently.)
I can share a bit more about its lineage privately depending on any feedback I receive.
Thanks gents (and ladies... As the case may be!)
posimosh is offline
post #9731 of 9743 Old 09-22-2014, 09:51 AM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
Originally Posted by VTECH8TR View Post
Rob,
Luis
I am more perplexed by you having an HGS series subwoofer with a DD series amplifier, these should not work together as the analog accelerometer and the digital servo control are incompatible.
post #9732 of 9743 Old 09-22-2014, 09:57 AM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
Originally Posted by kcd1369 View Post
Hi,
David
The electronics can be removed and sent in for service. Please complete this RMA request form and send it to service@velodyne.com. They will then provide you with an estimate and instructions for removing the electronics and shipping them in.
post #9733 of 9743 Old 09-23-2014, 05:59 AM
kcd1369's Avatar
Liked: 0
Thumbs up Form sent
Rob, Thanks. Form and email sent.
kcd1369 is offline
post #9734 of 9743 Old 09-23-2014, 04:48 PM
jbresee's Avatar
Hey Rob,
I have an HGS-10. The amp has been replaced once. Recently, the sub started making a burping noise, but it's steady like a machine gun. Removing the audio connection to the amp doesn't help. Sometimes switching the low pass filter on and off can make it stop.
Questions:
1. Do you still repair the amp for the hgs-10?
2. If so, what is the cost to have it repaired?
Jim
jbresee is offline
post #9735 of 9743 Old 09-24-2014, 09:19 AM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
Originally Posted by jbresee View Post
Hey Rob,
Questions:
Jim
The electronics from the HGS10 can still be serviced. You would need to complete this RMA request form and send it to service@velodyne.com. They would then provide you with a return authorization number and provide you with a quote for service.
post #9736 of 9743 Old 09-24-2014, 10:00 AM
jbresee's Avatar
Thanks Rob,
I've sent in the form. I appreciate the help!
Jim
jbresee is offline
post #9737 of 9743 Old 09-27-2014, 03:24 PM
Liked: 0
Update: I sent in the electronics of the DD-15 with the "rumble" to Velodyne (just shipping the electronics cut down on shipping costs). They were able to confirm the problem, replace the controller board, and ship back the repaired electronics. The repair took just a little over a week, and was reasonably priced. The repair cost included a 1 year warranty & return shipping. Thus, I am happily back in business. Thanks to everyone at Velodyne for a job well done.
robyork is offline
post #9738 of 9743 Old 09-29-2014, 01:10 AM
Liked: 0
Unfortunately, replacing the caps in the unit that previously had the loud hum has caused the hum to return, perhaps even louder. Tried putting the previous caps back in but no good. Guess that one is off to local repair shop for a quote.
post #9739 of 9743 Old 09-29-2014, 07:35 AM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
It was worth a shot, hopefully the service shop will be able to bring them back to life.
post #9740 of 9743 Old 09-29-2014, 09:48 AM
gman086's Avatar
I'm in the same boat with my VA-1215 XII: amp is shot and I'm not comfy with replacing a few amp parts as it's 16 years old. I'd planned to just find another plate amp but the funky measurements (16" x 6") make it impossible without plating off and cutting. Not really cool with that either. My question is are the drivers in good enough shape to even worth trying to fix this sub? They've been used nearly daily for 16 years so they had quite a nice run; I would assume they wear out over time and lose some "tightness"? Anyone know where I can find a long skinny plate amp that will fit this without carving up the box?
G
gman086 is offline
post #9741 of 9743 Old 09-29-2014, 11:13 AM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
G
Those drivers should be fine so long as the surround material is in good condition. If not, having the surrounds redone on this model is typically fairly inexpensive.
post #9742 of 9743 Old 09-29-2014, 12:36 PM
gman086's Avatar
Thanks Rob. I guess I could leave the dead amp in it and just run some wires from a new amp which I could just lay on the carpet behind the sub? I believe there's a Dayton 500 watt plate amp to be had locally for $150. Worth a try?
Cheers,
G
gman086 is offline
post #9743 of 9743 Old 09-30-2014, 12:11 PM
Rob Morse's Avatar
Quoted: 29 Post(s)
Liked: 27
Cheers,
G
I do not have any personal experience with the Dayton 500, so I can not speak to that, however if it were me, I would take a look at the possibility of repairing the original amplifier before considering workarounds.
Velodyne Acoustics , Velodyne Impact 10 10 Subwoofer , Velodyne Wiconnect 10 Wireless Subwoofer , Velodyne Eq Max 8 8 Subwoofer , Velodyne Eq Max 10 10 Subwoofer , Velodyne Eq Max 12 12 Subwoofer , Velodyne Eq Max 15 15 Subwoofer , Velodyne
User Tag List
