* Offical Velodyne Support Thread * - Page 329 - AVS Forum
 12Likes
Old 12-18-2014, 05:56 AM
Liked: 0
DD Plus - 230V - Disable 1/2 watt circuit ?
Originally Posted by Rob Morse View Post
The 230 volt version of the DD plus subwoofer includes a 1/2 watt standby circuit mandated by the EU, this circuit will not allow the subwoofer to remain powered on after a period of time of non-use. The auto on/off circuit will work to power on the subwoofer if you supply it with enough signal, unfortunately the always on and 12 volt trigger features are disabled by the 1/2 watt circuit.
There are steps that can be done to optimize the signal going into the subwoofer so that the Auto on/off works well, if you continue to have issues, your local service center can by-pass the 1/2 watt feature at your request. EU rules permit this to restore functionality such as the 12 volt trigger, however we are required to ship the subwoofer with the 1/2 watt circuit engaged.
Same Problem for me to,
can you point me to a circitmap to do deactivate the 0.5watt circuit by myself ? My Service Center is
far away (some where in Germany) and on/off trigger is what I need with my Denon AVP-A1HDA !
Ok, there are more little Problems with my DD10+, bought used 15m old. See Post#9840, like
-no Picture from Welcome/System Settings Screen (comp/s-vhs) ??
Well perhabs we can get this done ?
hoping - bassmann.de
keep grooving
bassmann.de is offline
Old 12-18-2014, 09:01 AM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
When the unit is in 0.5 watt standby mode, there will be no picture from the video output.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is online now
Old 12-18-2014, 09:08 AM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
Hi all Thread Readers, greetings from Germany !
Well, last week I bought a 15 month old Velodyne DD10+. Now connected to my Denon AVP-A1HDA.
Trying to do a Setup with the Digital Drive Plus Software (Rev 1.01 / 2011 !!), it reads my SerialNo
but if you try to upload a messurement it says "no sync" ! But the the file seems to get uploaded.
Hmmm, perhabs there is a newer, bugfixed Release of "Digital Drive Plus" ?
I connected the Video output Composite or S-VHS to my Denon to check the Setup, there is no
Introductory Screen - only a big light gray Picture ? Nothing else, Hmmm.
A Factory reset, as showen in the Manual didn't change anything.
-Has anyone an idea to fix this ?
-Is there a DigitalDrivePlus 2.x ? Can you point a Link to me ? Velodyne Download Page, said there is, but not for mine (SerNo starting with 7xxxx) Hmmm.
wondering
bassmann.de
There is no update to the software. The no synch indicates that you are not playing the sweeptone CD and the subwoofer has not synchronized to the audio.
Old 12-18-2014, 09:10 AM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
Originally Posted by nitro1max1 View Post
I have a DD-15 that developed a like pop sound when using the sub. At low level volume it play fine. When turning the volume up it pop and keeps play pop again. The louder it plays the more it pops. It's very annoying when it happens. Everything else works. Not sure if it is the board or the driver. Any input what you think it could be? Would like to repair the sub if I can. Thanks
I would recommend contacting service@velodyne.com . They will likely provide you a wiring diagram to disconnect the accelerometer/servo circuit and test the subwoofer that way. The result is not fool proof, but is a good indicator as to if the issue is driver or electronics based.
Old 12-18-2014, 11:53 AM
Liked: 0
ok Rob, thanks for this quick reply !
1) No the unit ist not in Standby Mode, in normal play mode I can't get a Picture
on my Denon!? There is only a blank grey Picture to look at.... not realy a Welcome
Screen. Ideas on that?
2) The On/Off/Trigger Mode is useless and contra productive for EU-Customers,
please give me an advice to deactivate the 0.5watt Module as you mentioned before .
I can manage a SolderingIon as a iT-Prof, i think. That would be a great help, to
get this fine Unit to work as it should.....
Thanks for your help, Rob and keep inventing !!
bassmann.de Ralph
keep grooving
Old 12-18-2014, 12:08 PM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
There are a couple of possibilities, the standard output could be set to NTSC formatted video and the receiver might be expecting PAL. There manual for the subwoofer will tell you how to switch the video type. Another possibility is that there is an issue in scaling, this happens sometimes, the solution is to try setting the HDMI output of the receiver to a fixed lower resolution temporarily. Ultimately the best solution is to use the USB output connected to a PC.
bassmann.de Ralph
PM sent
Old 12-18-2014, 12:11 PM
Liked: 0
1)No the unit ist not in Standby Mode, in normal play mode I can't get a Picture
bassmann.de Ralph
got your PM late, thanks.
#1 obove will be the next to work on, wount it ?
bassman.de
keep grooving
Old 12-18-2014, 02:05 PM
MN-Rabbit's Avatar
Questions For Rob Morse
Hi Rob!
I have a Velodyne V-1215X from the nineties. Do the numbers designate a 12" passive front facing with floor facing 15" driver? Also my Pioneer Elite only has one subwoofer out...should that be connected to the left line in only or should a splitter be used and connected to the left and right line in. Thanks so much in advance for your time and knowledge!
MN-Rabbit is offline
Old 12-19-2014, 10:08 AM
Liked: 0
Hgs-12x no workee!
I just purchased the lovely sub from a goodwill store, as even if I had to fix it, I like where the money is going. So turns out I do need to make fixee, but need to figure out if it is the amp or the speaker. I believe it is the amp, but wanted some opinions from folks with more experience .
When I turn it on. It makes a sort of higher pitched intermittent soft buzzing sound. When I hook it up to a source, the buzzing matches the music, and volume adjustment has no effect on output. If needed I'll put up an audio file of it, if that is allowed here. Can you guys suggest what to do to make sure it is the amp, and then where I can send it to get it fixed for a reasonable price?
Robin
Rlocksley is offline
Old 12-20-2014, 12:34 PM
Liked: 0
I have received your email, as well as the many emails forwarded to me by all the European distributors you have contacted. I replied with a series of questions, and received your answers. Based on your answers I advised what the problem could be, assuming the issue is determined by the distributor as audible to a normal person from a meter away. The distributor claims they can hear nothing, while you claim the problem is audible 40 meters away. I have emailed both you and the distributor that Velodyne is willing to provide a replacement electronics pack at no cost and suggest we see how things go from there.
Hello.
New amplifier exhibits the same problem. Whistling is exactly the same.
Please about solutions.
gibosl is offline
Old 12-22-2014, 08:20 AM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
Originally Posted by MN-Rabbit View Post
Hi Rob!
The numbers designate a 12 inch forward firing driver and a 15 inch downward firing passive radiator. The subwoofer in monaural so connecting to either the left or right input is fine as the signal is summed internally. If you experience low levels, then sometimes a y-splitter will help.
Old 12-22-2014, 08:22 AM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
Robin
Buzzing sounds indicate electronics issues. Our service department can assist you with getting that repaired. Please contact them with your serial number at service@velodyne.com
Old 12-22-2014, 08:27 AM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
Originally Posted by gibosl View Post
Hello.
Unfortunately I will need to direct you back to the distributor. They are your local contact that are able to assist in resolving the issue. My understanding is that they have been unable to duplicate the issue either before or after we replaced the electronics. Have you looked into the possibility of an environmental cause? Perhaps taking the subwoofer to a friends and connecting it to his system to see if the issue is still present.
Old 12-22-2014, 03:11 PM
Liked: 0
I have been trying Subwoofer in 10 different places and distance more than 60 kilometres far and most people could hear whistling. It proves that issues is not caused in my home only. In High end Audio (that's distributor) they let me know that this is final solution and they can't (or they don't want) do anything else. During our last phone conversation they hang out and also stopped to reply my e-mails. At the moment I see only one option. I'm going to send subwoofer to expert opinion and let specialist to decide. The distributor keeps claiming: no noise from the source (but why they don't let me stay during test of subwoofer?)
My troubles lasts since buying of Subwoofer o 8th of October. I dont want to buy different product neither different brand. I only wish to have my Velodyne SPL 1000 Ultra fixed.
Many thanks for your understanding.
gibosl is offline
Old 12-22-2014, 05:53 PM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
I appreciate your efforts to resolve the issue you are experiencing. The reality is there is nothing that I am able to do for you on this end, unless you want to ship your subwoofer to the United States for service. Our International Distribution Agreements establish one importer for a region and they alone represent resell, distribute, and service Velodyne products as they see fit. It is my understanding that the distributor was willing to exchange the whole subwoofer for you, but your subwoofer is not in new condition, leaving component replacement the only option.
I do not know why you hear something that they do not hear, nor why the problem continues after having had the entire electronics pack replaced, as there is nothing in the driver assembly, nor the cabinet that could make such a sound. I do not recall this symptom having been brought to my attention before with this series of subwoofer.
I will speak with our International Sales Manager to have her speak with the distributor about re-establishing communication with you to work for a resolution. I will make some testing recommendations for them.
Old 12-23-2014, 08:54 PM
orcrone's Avatar
Quoted: 51 Post(s)
I need some advice (again)
I posted a similar question about six pages ago, but now I'm looking at a totally different creature.
To increase the WAF we're building a home entertainment credenza which will hold the electronics and subwoofer (not MY first choice). When built I planned on ordering one or two SVS SB-2000 subs. I've found some used DD-12+ subwoofers; one person selling his for $1800 and another person selling dual subs for $3400. The DD+ series particularly attracts me because, aside from their great performance I'm hoping the EQ can offset some of the effects of living in the credenza. Just wanted to get opinions on purchasing this sub. It will be used in a living room (3000 cubic feet) open to a dining room and foyer to the left of the listening area (another 2000 cubic feet). Additionally the breakfast area, behind the listening area is open to the listening area via a 7' wide, 8' high archway. Don't know if that counts, but that's another 1500 cubic feet.
Should I be thinking two DD12+ for this area, or am I getting a little crazy?
It was suggested that instead of a single DD12+ I'd be better served by two Optimum 12. What's your thoughts there?
The DD15+ is a bit too big for the credenza, so I'm limited in this line to the 10" and 12" subs.
I appreciate any advice before making this investment.
orcrone is online now
Old 12-23-2014, 11:07 PM
Streetpilot's Avatar
Dead MiniVee Any help??
Total noob just discovered the site, looks great. Looking for a little help.
I recently received a dead 8" minivee and thought I'd give it a try to fix it hoping it might be something simple.
I've only just opened it up and had a basic look around.
When I turn on the power switch nothing happens, strange to note no pwr LED?
Fuse is good, ohmed good and jumper bypassed just in case.
Speaker looks good, no cone or VC noise and at the terminals 6.5 ohms and ~ 0.5 VAC when moving the cone.
Board output terminals not open or shorted and reads like a diode in one direction.
Visually no leaking lytics, nothing burned, nothing brown or discolored, no overstressed parts seen anywhere.
Bridge has 330 VDC so PS looks good. (I don't have a scope).
There was a very faint burnt smell when I first opened up the enclosure that can't be localized.
I don't know what the third lead is going to the spkr.
Is there a schematic available?
Are there fusible links?
Is there anything I could be missing?
Any help would be appreciated, I really want to compare this to my Foundation 1200 I've had since new.
Thanks for your help.
Streetpilot is offline
Old Today, 05:54 PM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
First of all, as a man who uses two subwoofers in his system, I would say you are never crazy for thinking of two subs. In fact, if your room is oddly shaped two subwoofers may be more to your benefit than the equalizer. Combined it could definitely help.
When it comes to two Optimums vs one DDplus, I would typically choose the two Optimums, especially if you are a hybrid listener or don't spend much time doing critical music listening. The Optimum is a very good quality sub, and I am a huge proponent of running two subs in your listening room.
I would not be worried too much about the 15 inch sub. The DDplus 10 and 12 already extend down below 20Hz so unless you are looking for 15Hz at less than 3dB down or you are trying to fill a room over 5500 cubic feet in volume from a single sub, it does not gain you much.
Old Today, 06:00 PM
Rob Morse's Avatar
Quoted: 50 Post(s)
Liked: 31
All things being equal and the subwoofers performing at factory specs, the MiniVee and your F1200 are going to be very different beasts. While the MiniVee is an amazing subwoofer, with good tight bass, it is limited by the 8 inch driver. The F1200 will play deeper and fill a larger room simply based on size. The Foundation series is also a servo controlled subwoofer which provides for greater accuracy and less distortion, not that the MiniVee is a slouch, but for pure music the Foundation series is superior.
The MiniVee series subwoofer can be serviced by removing and sending in the back panel assembly for a flat rate. Please contact service@velodyne.com for the current repair rate and to obtain a return authorization.
Velodyne Acoustics , Velodyne Impact 10 10 Subwoofer , Velodyne Wiconnect 10 Wireless Subwoofer , Velodyne Eq Max 8 8 Subwoofer , Velodyne Eq Max 10 10 Subwoofer , Velodyne Eq Max 12 12 Subwoofer , Velodyne Eq Max 15 15 Subwoofer , Velodyne
