* Offical Velodyne Support Thread * - Page 334 - AVS | Home Theater Discussions And Reviews
 15Likes
post #9991 of 9998 Old 04-15-2015, 08:51 AM
Rob Morse's Avatar
Quoted: 83 Post(s)
Liked: 35
Originally Posted by ksubrama View Post
Hello Rob,
I got my HGS-15 back from Bammel TV today for the second time. This time the tech is confident that they have fixed the issue, citing "electrical alignments".
I plugged the unit in, and so far no more rattling. Bass is clean.
I do notice however that when there is no signal and the subwoofer is on, there is a fan like noise from the subwoofer until it goes on standby. It is an audible "whoosh" like sound from the listening position.
My subwoofer only started doing this after Velodyne sent me the upgraded THX Ultra 2 amp board in January. Is this normal?
I'm hoping that the sub issue is fixed for good. Will test again tomorrow.
KSub
It is not uncommon to have a faint noise (hiss or hum) when idle, typically this can only be heard within 2-3 of the subwoofer in a quiet room.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
post #9992 of 9998 Old 04-22-2015, 08:26 AM
Liked: 0
Question Does anyone have a schematic for VA12BV110 or similar (VA12BVX10 series or equivalent
Hello members,
I have been enjoying my VA12BV110 since I can remember and has been perfect for my needs.
Unfortunately, as of last week, it has developed a humming sound that's exclusive to any audio input.
My first action was to look on yelp for local speaker repair shops but all of them asked me to request a new circuit board.
I have not reached out to VELODYNE yet because this is a 20 yer old sub and I don't have the receipt or any warranty information with me. Honestly this has outlasted almost everything I have owned and I am happy it lasted me so long
As a former digital electronics engineer, my limited analog skills tell me that AC signals are somehow making their way through to the amp.
My limited experience tells me it's either or both of the regulation capacitors and/or bridge rectifiers that are shorted (which will have a cascading effect on the rest of the components).
I don't have a proper bench with me anymore (moved out into management years ago), but a schematic would be very useful in basic troubleshooting.
Does anyone have a schematic for VA12BV110 or similar (VA12BVX10 series or equivalent)?
ZachDavis is offline
post #9993 of 9998 Old Yesterday, 07:52 AM
Rob Morse's Avatar
Quoted: 83 Post(s)
Liked: 35
Originally Posted by ZachDavis View Post
Hello members,
The schematics for this subwoofer's electronics are available. Please send an email to service@velodyne.com . Provide the model number as listed on the back of the subwoofer, and the serial number. It may also be helpful to provide a photograph of the back panel as some of these early models had different amplifier variants that are determined by the shape of the metal plate.
post #9994 of 9998 Old Yesterday, 01:01 PM
jgirado's Avatar
Velodyne DD-10 and MCACC PRO (Pioneer SC-89)
Hello everybody,
I recently bought a Pioneer SC-89 (current top of the line Pioneer receiver) which comes with MCACC PRO room calibration (or equalization).
MCACC PRO suppose to correct/fix phase alignment, standing waves, EQ the sub-woofer, group delays, and who knows what else :-)
Suppose to be even more advance than MCACC and MCACC Advance:
http://www.pioneerelectronics.com/ep..._Ref_Guide.pdf
Anyway, I still use my old Velodyne DD-10 for LFE because I really love this sub-woofer, never have the urge to replace it. It's great!
And as everybody knows the DD-10 comes with it owns auto-EQ and room EQ.
Before I had Denon AVR-4809, then AVR-4520CI with Audyssey and found a way to make them work together, but with MCACC PRO I kind of lost, too many variables!
Can somebody recommend me a step-by-step procedure to calibrate them together? At least something to start. I already checked this forum for information but all related post use MCACC *not* MCACC PRO which seems to be more powerful (one difference is that it suppose to EQ the sub-woofer).
Thank in advance,
Javier
jgirado is offline
post #9995 of 9998 Old Today, 09:15 AM
Rob Morse's Avatar
Quoted: 83 Post(s)
Liked: 35
Hello everybody,
Thank in advance,
Javier
Typically these AV receiver based EQ systems are not as robust in the subwoofer frequency range as the Digital Drive's 8 band parametric EQ system. So my standard recommendation is to run the Self EQ on the DD, then run Pioneer's EQ protocol, then take a look at the DD curve in the parametric mode and make any fine tune adjustments as needed.
post #9996 of 9998 Old Today, 10:39 AM
jgirado's Avatar
Thanks a lot Rob. I did run the self-EQ and then ran MCACC but missed the last step (run DD in parametric mode to make final adjustments). I'll do that and report back. Thanks again for your prompt response.
Javier
jgirado is offline
post #9997 of 9998 Old Today, 11:04 AM
Rob Morse's Avatar
Quoted: 83 Post(s)
Liked: 35
Javier
My pleasure....keep in mind, the last step is not critical, its just the fine tuning if your a perfectionist.
post #9998 of 9998 Old Today, 11:30 AM
jgirado's Avatar
Thanks...
On related topics:
1) Before running MCACC PRO, should I disable the DD-10 XOVER (crossover) for all presets (1. Action/Adventure, 2. Movies, 3. Pop/Rock, 4. Jazz/Classical, 5. Custom, 6. EQ Defeat). The DD-10 manual mentions something about possible problems using two crossovers (receiver + DD-10)
You can find it here:
A Word About Subwoofer Outputs https://velodyne.com/pdf/digitaldriv...anual_revg.pdf
2) Since I don;t know which type of music I'll play, should I preset "5. Custom" before running MCACC PRO?
Javier
jgirado is offline
Velodyne Acoustics , Velodyne Impact 10 10 Subwoofer , Velodyne Wiconnect 10 Wireless Subwoofer , Velodyne Eq Max 8 8 Subwoofer , Velodyne Eq Max 10 10 Subwoofer , Velodyne Eq Max 12 12 Subwoofer , Velodyne Eq Max 15 15 Subwoofer , Velodyne
