Shakers - Simple/Cheap Hookup - Visual Guide - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #2551 of 2563 Old 12-08-2014, 10:03 PM
derrickdj1's Avatar
Quoted: 471 Post(s)
Liked: 344
Remember the other channels are 85/105 db for reference playback and the sub/ LFE goes to 115 db.
derrickdj1 is offline
post #2552 of 2563 Old 12-08-2014, 10:52 PM
XclusiveTN's Avatar
Quoted: 26 Post(s)
Thread is way to many pages to go thru them all. Trying to keep this as low budget as possible. I have a Denon AVR 2112-CR running my 5.1 surround system and wanted to know can I use this to power 4 aura pro bass shakers as well? If so that would be awesome, if not how what would I need to run another cheap avr to power the bass shakers?
XclusiveTN is offline
post #2553 of 2563 Old 12-09-2014, 08:58 AM
Gracepreacher's Avatar
Quoted: 135 Post(s)
Cheryl, thank you so much for your explanations! That makes complete sense.
Next question, I just read about "group delay" induced from cascading crossovers in another forum, and I do have a slight sense of the timing being off on the bass shakers. Could this either be from doubling of crossovers, or maybe the fact that the AVR is set up with a subwoofer speaker delay setting measured from my MLP to the sub, but the shakers should theoretically be set to zero (because they are right under me)? Has anyone else had issue with timing and solved them? Maybe a compromise by setting the distance in the AVR to half/average between the two? All the more reason to try my sub nearfield!
Gracepreacher is offline
post #2554 of 2563 Old 12-09-2014, 12:56 PM
CherylJosie's Avatar
Quoted: 476 Post(s)
Liked: 180
Group delay refers to the relative time delays of the various components in a signal.
Group delay is important but usually only when multiple drivers (or drivers and resonators like ports or passive radiators) in a single system simultaneously produce the same frequency. Out of phase components might add or cancel in a complicated fashion, altering transients, inducing audible tonal coloration, or smearing the perceived location of the sound.
The amount of delay that a crossover or lowpass induces is only a cycle or so of waveform, just a couple milliseconds at most and almost certainly imperceptible from a shaker, especially since there are no out-of-phase components that could be substantially interacting with the output from the shaker and it is unlikely that your tactile senses could even discern frequency-dependent phase-induced cancellation anyway.
I suspect that what might be occurring is that the shaker, chair frame, seat suspension, and your body form a damped resonator that needs multiple cycles' worth of energy from the amplifier to build up to full shake.
A speaker driver is a low mass cone with a relatively powerful motor driving it and it reaches full output very quickly in response to a 'steady-state' signal such as a tone burst test. In contrast, a shaker/chair is a high mass system with a relatively weak motor driving it. A shaker likely relies upon gradual buildup of resonating energy in the seat frame to compensate for the lack of driver power.
The experience could be a strong function of the shaker, the chair, even the size and shape and density of the person sitting in it might noticeably affect the experience.
It is also possible that the lower frequencies in the sound track are delayed for better realism, or out of sloppiness, who knows?
For more realism, turn up the system volume so you can feel the slam from the subwoofer. Add more/heavier shakers to your chair (yes, the mass of the shaker is an important factor since it is the 'anchor' that the motor pushes against). Make sure that you orient all the shakers on a single chair so they all drive toward your body in unison and get the polarity right when you connect them.
I doubt that nearfield placement of the subwoofer will do much since the room EQ will automatically reduce its output to compensate anyway. Nearfield placement will tend to make the room resonant modes less prominent in the localized sound near the 'sweet spot' but should not affect the actual balance between sub and satellites much. It might also drastically impair the sound in the rest of the room too so before you start embedding electrical conduit in a concrete slab floor try it out first to make sure you like what you hear.
Do not expect a shaker to create a convincingly realistic illusion of trembling Earth. Maybe shakers can enhance realism if done well, but to me, shakers are a gimmick to excite kids on amusement park rides (the only place I have actually felt a shaker). IMO the infrasonic experience of home theater should not come from an amusement park gimmick but rather from a high quality subwoofer driving realistic infrasonic levels and shaking the whole room, not just the chairs.
There is one person on this forum in particular (popalock) who has built two separate subwoofer systems to accomplish exactly that - one has 16x18" subwoofer drivers and the other has 2x24" subwoofer drivers (currently under construction). They can produce powerful output down into the 10Hz range where it can be felt but not heard. People who have experienced the 16x18" subwoofers claim the experience they generate is physically palpable like no other sound system and personally I believe them.
A shaker is just not going to feel like reality IMHO.
CherylJosie is offline
post #2555 of 2563 Old 12-24-2014, 08:37 AM
tezster's Avatar
Quoted: 241 Post(s)
Liked: 175
I've had my wireless Buttkicker installed for a couple of months now, and thought I would share some of my observations:
FYI this for a BK wireless advance kit.
  • Most importantly, if you can attach the BK directly to the frame of the seat, DO IT. I initially had it attached to the supplied platform that sits underneath a sofa leg. I thought the tactile feeling it provided was ok, but there's a significant improvement when I then mounted directly to the seat itself. In my case, my BK was bottoming out in extreme LFE sequences (such as the sine wave sweep in Edge of Tomorrow, or the plane crashing in Olympus has fallen, etc.); this no longer happens, at least not at the volume levels I listen to (around ~-14Mv at most). Having said that, when my BK was on the mounting platform, it was on a center leg, underneath the middle seat. Some of the energy was being transmitted to the floor, and my feet were close enough that I could feel the vibrations. I'm guessing this is why some people would attach these things to a riser in a more dedicated/elaborate HT setup.
  • The BK is not a substitute for a good subwoofer. Obviously, you can't replicate the feeling of 18" subs pressurizing the air. But at the end of the day, it gets you closer to experiencing the full range of a movie's soundtrack. For those with more modest setups in the subwoofer department (like me), there's a very real possibility of "overpowering" the sub. It's almost like you get addicted to the tactile sensation to a certain degree, and you end up waiting for the next "Buttkicker" moment, so it's important to set it to a level that creates a balance with the rest of the audio. I found that over several weeks, I gradually lowered the intensity of the BK, after I got over the initial euphoria of the sensation, having tuned it like it was an amusement park ride. Proper integration is important.
  • I've found that the different parts of my sofa vibrates to varying degrees depending on the frequency of the LFE signal. Higher frequency LFE signals vibrates the seating areas more, whereas lower frequencies are felt more on the backrest. In this way, there is a certain sonic quality to the effect. When I mute my entire system except the BK and watch a bass-heavy scene, I can almost imagine what higher frequencies are being played.
Overall, I'm very pleased with the BK, and I'm glad I added it to my setup.
tezster is offline
post #2556 of 2563 Old 12-24-2014, 02:49 PM
derrickdj1's Avatar
Quoted: 471 Post(s)
Liked: 344
Nice review. A hpf on the Buttkicker may help and shift the power higher. Some people report no loss of tactile sensation.
post #2557 of 2563 Old 12-29-2014, 08:56 AM
NickTheGreat's Avatar
Quoted: 305 Post(s)
Liked: 202
I hadn't heard of a wireless BK. Verrrrrrry intriguing . . .
NickTheGreat is offline
post #2558 of 2563 Old 01-03-2015, 12:33 PM
tezster's Avatar
Quoted: 241 Post(s)
Liked: 175
It definitely helps not having another cable run to worry about (especially one going to the back of the room). I placed my BK amp under the sofa, so everything is out of sight. It makes for a nice surprise with guests when I start playing a movie
tezster is offline
post #2559 of 2563 Old 01-04-2015, 10:42 AM
Movie78's Avatar
Quoted: 529 Post(s)
Liked: 108
Hi ALL!
Can i use a old Pioneer receiver to power up 6 Aura base shakers?
Movie78 is offline
post #2560 of 2563 Old 02-24-2015, 07:58 AM
FantaXP7's Avatar
Quoted: 40 Post(s)
Liked: 35
So I've just upgraded in a way, got the butt kicker amp, butt kicker wireless kit, chair mount and the lfe model butt kicker used on ebay. The chair mount kit is nice for now, I do not want to mount to couch just yet as I have a new couch on the way. I will say though that with the chair mount kit I see these shakers as good or better than the clarks, so I can't imagine what it will be like once mounted.
It came with the low pass filter which I need to install...anyone have advice on how to do so? The wireless module picks up all kinds of interference.
And for rubber feet. I sold mine along with my clark synthesis transduscers which were of the same brand and cost a lot. Anyone try out these http://www.amazon.com/Reliable-Hardw...er+rubber+feet ?
FantaXP7 is offline
post #2561 of 2563 Old 02-27-2015, 05:28 AM
Skylinestar's Avatar
Quoted: 843 Post(s)
Liked: 143
Can anyone recommend a good sofa "leg/isolator" to isolate the 3-seater sofa from the floor?
Skylinestar is offline
post #2562 of 2563 Old 02-27-2015, 07:01 AM
sdolen's Avatar
Quoted: 20 Post(s)
http://www.supplyhouse.com/DiversiTe...ad-2-x-2-x-7-8
Boomassiv likes this.
sdolen is offline
post #2563 of 2563 Old 07-10-2015, 09:28 AM
gnolivos's Avatar
Quoted: 26 Post(s)
Has anyone figured out a way to wire a Potentiometer or similar device to control/attenuate the level of shake of each transducer individually?
The Moderno Theatre! Slideshow (here, and here!)
Pixar screenplay slideshows here!
gnolivos is offline
