Need way to extend subwoofer cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-03-2004, 01:21 PM - Thread Starter
FBlack's Avatar
I need to know if there is a way to attach 14 gauage two strand wire to the RCA input on the back of a subwoofer. Is there some sort of premade cable or connectors?
FBlack is offline
post #2 of 4 Old 01-03-2004, 03:31 PM
Hawkson's Avatar
ya
go to radio shack and get an RCA to wire connector (i dont know what its called, but it connects regular copper wire into an RCA cable.
are you using an old reciever and a new sub? is that why you need to use gauge cable instead of RCA to RCA?
Hawkson is offline
post #3 of 4 Old 01-03-2004, 06:22 PM
Larry Fine's Avatar
You shouldn't be feeding an RCA input with a speaker wire. You should be feeding the sub from either an RCA output (and shielded cable w/RCA's on it) or a speaker-level output to a speaker-level input using (what else?) speaker wire.
Larry
www.fineelectricco.com
My system (new larger pix!)
Larry Fine is offline
post #4 of 4 Old 01-03-2004, 11:05 PM
DallasHTS's Avatar
You could always buy some 75 ohm coaxial cable and put 2 RCA end connectors on it. This is essentially a subwoofer cable.
I work for Dallas Home Theater Store, Preston/635. - Chad
DallasHTS is offline
Closed Thread Subwoofers, Bass, and Transducers
