Hsu VTF-2 Sub Owners- - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-03-2004, 08:45 PM - Thread Starter
kgoetz97's Avatar
I've seen Hsu's great deal on the VTF-2 and I'm considering going ahead and getting it but I have some concerns. I'll be putting it in a 18x20 room with 22 foot ceilings and entirely open on one side and partly open on a 2nd side (opens to foyer/dining room and kitchen/sunroom). Is this going to be able to provide enough impact for this room? What are some room sizes that current owners have? Should I look to get the VTF-3?
Now, normally, I would just go ahead and buy it and try it but we're building our house so the room is not even done yet! I'm just getting things together for my family room and saw the sweet price on this highly regarded sub.
TIA
Life is good...
kgoetz97 is offline
post #2 of 4 Old 01-03-2004, 10:39 PM
Ddavidson's Avatar
You might want to actually check stock with Hsu on Monday as they are having a model change to the new improved 250w Piano Black VTF-2 MK2, so the current special is a closeout deal. I know from the Hsu forum that stock was pretty limited at that price.
That is a decent sized room. Impact and SQ are very subjective so what may be my preference may not be yours. Both my VTF-2 and my VTF-3 are in smaller rooms but I am no where near both of the subs limits. Positioning the subwoofer right next to the listening couch would be the ideal position to "keep impact" in such a decent sized room. However FWIW in Tom Nousaine's large room (7500 cu ft) 13 x 23 x 18 ft with large openings (not a small room either) the corner loaded VTF-2 using a 10% distortion limit, averaged a maximum output (at 1/3 spacing between 25-63Hz) of 109.70dB while it measured 20Hz at 93dB and 25Hz at 99dB under the same conditions that Tom uses in his room.
If you really want more headroom in that big room without spending a lot more $$$ or because of WAF you can not put a subwoofer close to the couch - although seriously - in that room I would still look at this position first ....... I would take a good look at the (shipping on Monday) Hsu STF-3 which is a VTF-3 MK2 without the glossy paint and variable tuning. In direct comparison to the VTF-3 MK2 it has the same enclosure, same driver, same orientation, same Bash amplifier (I am not sure I believe the less 50w story from Hsu - 300w vs 350w) Due to the Piano Black finish the VTF-3 MK2 will now not ship till at least the 12th Feb.
Ddavidson
Ddavidson is offline
post #3 of 4 Old 01-03-2004, 11:18 PM
Hawkson's Avatar
since that is a large space i would look at the HSU 1220. that is HSUs best sub, and it has the smallest footprint of any sub that i know.
Hawkson is offline
post #4 of 4 Old 01-04-2004, 05:20 PM - Thread Starter
kgoetz97's Avatar
Thanks for the replies guys....I'm leaning towards just waiting and seeing what else pops up, especially since I don't have to have anything until this summer!:D
Life is good...
kgoetz97 is offline
Closed Thread Subwoofers, Bass, and Transducers
