Subwoofer Smashed Question - Look at Picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-05-2004, 06:29 PM - Thread Starter
TMaxxTim's Avatar
I saw a subwoofer that looks like this:
Subwoofer
Is there any real damage to the woofer itself...its a 250 watt JBL so I'm thinking it may just pop back out, but I'm by no means an audio expert so anybody's opinion would be GREATLY appreciated! Thanks!
Tim
TMaxxTim is offline
post #2 of 8 Old 01-05-2004, 07:01 PM
SpruceMoose's Avatar
it should still work fine. my 9-year-old pushed in the dome on one of my double advents a few months ago, and i didnt notice it for a week. i was able to push the dent out by hand by working against the points of the dent. took a few minutes. you could also use a drop of super glue on a pin head as a puller. i would try the finger method first.
sm.
enjoy the toys!
SpruceMoose is offline
post #3 of 8 Old 01-05-2004, 07:03 PM
Peter M's Avatar
Quoted: 162 Post(s)
Liked: 177
A vacuum cleaner is another option.
Peter M is offline
post #4 of 8 Old 01-05-2004, 07:13 PM - Thread Starter
TMaxxTim's Avatar
that's GREAT! This is like a $250-$300 subwoofer I'll get for about $80 or $90 on eBay just because of that!!!! Ya just gotta know where to look for these things! (not to mention the fact that the seller didn't put the model number of the item in the title, it just says "brand name subwoofer" it has all the info inside the description!!!
TMaxxTim is offline
post #5 of 8 Old 01-05-2004, 08:42 PM
Ranger Tim's Avatar
There is no way to tell from the photo if the voice coil was damaged by the blow to the dust cap. 99% of the time it's not a problem, but sometimes....
There may be torn paper on the cap, but you could replace it if need be. How does one smash a dust cap on a downward facing driver anyway?
Ranger Tim
The first half of my life I concentrated on making music. I intend to spend the rest of it listening.
Ranger Tim is offline
post #6 of 8 Old 01-05-2004, 09:10 PM - Thread Starter
TMaxxTim's Avatar
I'll let you guys know how it turns out. A downward facingdriver seems like a much easier one to crush or damage to me being that you are placing it down and it it was a display model or whatever it seems like it oculd have easily gotten crushed in repackaging or something of that sort. It also doesn't have a protection cover on it I believer like some other Yamaha sub's I've had before.
TMaxxTim is offline
post #7 of 8 Old 01-05-2004, 09:53 PM
TV
TV's Avatar
Just noticed there are some CVT 12" cerwin vegas on ebay for 169 and JBL S120s for 349. Both supposedly new in box. Those would both be excellent values assumign they are indeed new and in perfect operating condition.
Tom V.
SVS
TV is offline
post #8 of 8 Old 01-06-2004, 01:17 AM
JohnR_IN_LA's Avatar
I eyed those Cerwin Vegas that they sell out of LA on EBAY, they just looked old and ugly ... i guess you cant complain about the price, but I couldnt find any reviews or input on whether they sucked or not ...
Also, they seemed to have an older feature set. Are they any good?
JohnR_IN_LA is offline
Closed Thread Subwoofers, Bass, and Transducers
