Polk PSW505 vs. Velodyne CHT15 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-06-2004, 11:17 AM - Thread Starter
xb1032's Avatar
Liked: 26
Has anyone heard a direct comparison between these two subs. I have the PSW505 and while it's a nice sub but I need something more powerful for my room size. I've moved the sub around and while it sounds good for music I am not able to shake the house during movies as I was before in my old house(old room size was 19*12 directly connected to the kitchen whis is about 10*12. The new room is about 20*18 open to a kitchen which is about 20*14. The new room has a 9ft ceiling with a cathedral ceiling). I am most interested in the Velodyne CHT15 because I want to buy local.
xb1032 is offline
post #2 of 5 Old 01-06-2004, 02:18 PM
fireshoes's Avatar
How about a second PSW505? :)
fireshoes is offline
post #3 of 5 Old 01-06-2004, 06:13 PM
Sorny's Avatar
Do you have a CompUSA near you? A HSU STF-2 is more potent than either sub you are looking at, and probably around the same price or lower. $400 gets an STF-2.
I'd be concerned that 1 subwoofer might not be enough for that room size though... Honestly, a VTF-3R or something of that caliber is probably better suited to your room size.
Sorny
Sorny is offline
post #4 of 5 Old 01-07-2004, 09:49 AM - Thread Starter
xb1032's Avatar
Liked: 26
I do have a Compusa very close but i don't think they have home audio but I can check. The only issue that I have with Compusa is that I'll want to try out the sub and I believe they have a silly restocking fee on anything in the store.
I did think about another PSW505 but I'm not sure if 2 of these subs are powerful enough.
xb1032 is offline
post #5 of 5 Old 01-07-2004, 10:16 AM
Ddavidson's Avatar
If your looking down at CompUSA and see they have the HSU STF-2 you can also ask when they get the bigger HSU STF-3. The STF-3 is basically a VTF-3 MK2 in max output mode without the option of variable tune and glossy Piano Black. If your in the market it's definitely worth a listen because IMO it will easy out perform the other commercially available subs at this price level.
Ddavidson
Ddavidson is offline
Closed Thread Subwoofers, Bass, and Transducers
