PB12 Problems - JBL - Subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-06-2004, 06:10 PM - Thread Starter
TMaxxTim's Avatar
I have a PB12 Subwoofer, i got it open box about a week ago and just got around to hooking it up. I paid $100 for it. It has the 2 LED lights that light up in the front just fine, however there is no bass any way I hook it up. When I turn it on I don't hear a "click" as I have with my old subwoofers, is this normal? What do you think my best route would be. Being that I only paid $100 for it, would it be worth buying a new amp board for it, I hear that is the problems with most of these...would I still have the same problem in the future (the amp blowing), or would a new one make a difference. Is this really that great of a subwoofer to be spending another $100 for a board on it, or should I look elsewhere...its hard to find a 250w woofer for this price. Any input is greatly appreciated
Tim
TMaxxTim is offline
post #2 of 7 Old 01-06-2004, 07:05 PM
Burtgtp1973's Avatar
i have the PB-12 and cant complain , especially after upgrading from a KLH 150 W 12"... LOL ,
i think if you can get this sub working for $200 .00 youll be happy you did. its a robust 250 W subwoofer . IMO ... cant go wrong for 2 bills . any more $ than that ... keeep loooking . HTH 'S
BTW , did you try wiring your fronts through this sub, that is how mine are wired , and it made a HUGE difference , i know its a kinda of a DUH question , but you never know ...
Hitachi 65" HD Widescreen
Denon AVR3801
Klipsch RF-35
Klipsch RC-35
Klipsch RS-35
SVS 20-39 PCi
Burtgtp1973 is offline
post #3 of 7 Old 01-06-2004, 07:10 PM - Thread Starter
TMaxxTim's Avatar
Yeah, I tried it both ways...there's nothing...I'll go ahead and try to purchase a amp. Do local shops usually ahve them in stock or is it something they'd have to order...and it would end up being more?
TMaxxTim is offline
post #4 of 7 Old 01-06-2004, 07:38 PM
SledBC's Avatar
I looked into this sub but after seeing about 20 Non working units being sold on ebay in the last month, im looking elsewhere.
PS: This is what part of the alphabet would look like if Q and R were missing.
SledBC is offline
post #5 of 7 Old 01-06-2004, 07:58 PM - Thread Starter
TMaxxTim's Avatar
I've read on this forum that its an Amp problem...I don't really know much about audio...but if the driver is good then getting a replacement amp should fix the problem being that it was a faulty or a not well manufacturer'd amp before. Getting a new different one would solve this problem therefore making it a great find! I like this sub however they go for about $160-$200 on eBay and thats working...after reading this I don't think I'd want to get one with the original amp for fear that it might be broken!
TMaxxTim is offline
post #6 of 7 Old 01-06-2004, 08:25 PM
Our parts phones are open from 8:00 am to 5:00 pm Monday through Friday at 818-894-8850. The best times to call are between 8:00 am to 12:00 pm and 2:00 pm to 5:00 pm. (Pacific Standard Time)
this is the parts department at JBL ... give em a hollwer and see what they say , like i said ... if you can make this work for 200 its WELL worth it . !
Denon AVR3801
Klipsch RF-35
Klipsch RC-35
Klipsch RS-35
SVS 20-39 PCi
post #7 of 7 Old 01-06-2004, 09:10 PM - Thread Starter
TMaxxTim's Avatar
What's your opinion on my returning this one and purchasing a Yamaha SWT-315 instead...My speakers and reciever are Yamaha and I've never had a problem with them, or is this JBL superior to anything Yamaha could produce?
TMaxxTim is offline
Closed Thread Subwoofers, Bass, and Transducers
