Speaker and Sub purchase question? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-09-2004, 07:32 AM - Thread Starter
Beefcake's Avatar
Hi All, I'm definitely a noob and have found some good info over the net on speakers and placement and whatnot.
I just purchased some stuff from Cambridge SoundWorks here is MA, and I found this website too search it before buying. I listened to all of their speakers and definitely I'm happy with my purchase. I'm just looking to see what others think and how I did on the prices.
I ended up buying:
Center Channel - Classic Series CenterStage
http://www.cambridgesoundworks.com/s...age&type=store
Mains - M80 bookshelf (bi-wired)
http://www.cambridgesoundworks.com/s...zzz&type=store
Sub - Basscube 15e (should be just a 15" version of the Basscube 12s)
No Link, has 150W RMS amp. downward firing
Rears - make: Boston model: forgotten (i got these about 3 years ago)
My amp/receiver is an older (5 yrs+) Denon AVR-2500? it has DD 5.1 @ something like 70Wx5. Overall, a solid performer.
So, I got the center channel for $125 (from $300 - currently $150 on clearance), the sub for $255 (from $600 - on sale for $300), and the mains for $267 (orig. $400, but website had them for $320 + I found a 15% off coupon). So, I got the whole thing for $647.
How did I do? I feel like I got a great deal and a good sounding system. How does this stack up to others' experiences.
-Brian
Beefcake is offline
post #2 of 6 Old 07-09-2004, 10:21 AM - Thread Starter
Beefcake's Avatar
Bump.... any thoughts? Or am I totally below the level of this forum? I honestly don't know.
-Brian
Beefcake is offline
post #3 of 6 Old 07-12-2004, 08:05 AM - Thread Starter
Beefcake's Avatar
Thanks for the input everyone....bump
Beefcake is offline
post #4 of 6 Old 07-12-2004, 08:23 AM
hibernian1's Avatar
No one can tell you if you should be happy with your set up---only your ears can do that. I will say that you did a good just organizing it on a budget. Personally, I dislike Boston speakers which, to me, sound very muted. But if you're happy with it that's great. I do like Cambridge very much.
hibernian1 is offline
post #5 of 6 Old 07-12-2004, 08:26 AM
11427's Avatar
No,... you are not below the level of this forum! I would suspect that, like me, no one who has seen your post has listened to the speakers you bought. Looks like a pretty nice set-up to me.
Mark
11427 is offline
post #6 of 6 Old 12-04-2004, 08:21 AM
Snooptonydog's Avatar
Replying to your thread.
I am very happy with CS stuff too but am average joe. I have M80 bookshelves and think they are about the best you can get for a limited budget.
Center Channel - here is where you should consider upgrading maybe eventually since CS lets you upgrade and just pay difference in price.
You might want to consider CS "surrounds" Newton series becuz they are timbre matched with your mains and center which audiophiles say is good.
Snooptonydog is offline
Closed Thread Subwoofers, Bass, and Transducers
