why does my sub need a y-adapter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-15-2004, 07:08 PM - Thread Starter
Sc0rp10n's Avatar
my main use is home theater (video) and i'm willing to pay well for good speaker wire. what would you recommend? my new equipment is a denon avr 3805 and paradigm 7.2 recommended system (it's a 5.1 setup).
also, why do some sub cables (i.e. monster on crutchfield) come with y-adapters? i thought i needed 1 cable that goes from my sub pre-out to the sub. or are there 2 inputs on the sub? i haven't received my speakers yet. just ordered them today.
Sc0rp10n is offline
post #2 of 11 Old 09-15-2004, 07:21 PM
YeuEmMaiMai's Avatar
buy wire from radio shack it is cheaper and of the same quality as any other copper wire.
Anyone who can hear the difference between $10 spool and insanely expensive wire is just that insane.
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #3 of 11 Old 09-16-2004, 09:22 AM
gschawla's Avatar
IMHO, I would stay away from radio shack cables, esp. the adapters they offer. I've purchased their y-adapter/premium subwoofer cable and they made my HSU VTF-2 sound like crap. Spend a few exta bucks and buy better cables/adapters to make your HT setup sound better.
GC
gschawla is offline
post #4 of 11 Old 09-16-2004, 10:40 AM
mygiantcircle's Avatar
from what I gathered, if you use the auto on/off feature on the sub, and if the sub would not turn on because the source signal is too low, then use the Y adapter.
Buy the cables from parts.com. I got some Dayton patch cords and King 12awg speaker wires...they are not expensive and of good quality
mygiantcircle is offline
post #5 of 11 Old 09-16-2004, 11:51 AM
Version's Avatar
You realy shouldn't need the Y adapter at all. Just run from your Sub output to the L/Mono input on the sub. Using a Y cable will boost the volume by doubling the signal (simplification I know) but it will not do anything different than turning up the volume.
mygiantcicle has about the only reasonable explaination for why you would need a Y cable.
As far as cables go... Absolutely better cables make a difference.
but don't get caught up in the marketing too quickly. In my experience a good solid well built cable can make noticable improvements wether it has a name brand on it or not.
My thoughts,
There are lots of do-it-yourself instructions on the net if you are so inclined. If you do a good job you'll get great cables and save a ton of money.
If you don't mind purchasing online, there are lots of online cables stores. Search for Bluejeans cables or better cables you should save some money.
If you would rather go to a local store you can't go wrong with any of the name brands like Monster or Acoustic Research but you will pay a pretty big premium for about the same thing.
Version is offline
post #6 of 11 Old 09-16-2004, 01:50 PM
Rche 1's Avatar
My thoughts,
A/R cables are alot cheaper than Bluejeans and Better Cables. And, are just as good of quality. www.accessories4less.com
Rche 1 is offline
post #7 of 11 Old 09-16-2004, 03:39 PM
M3 Pete's Avatar
I think you mean partsexpress.com
Sub cables carry only low frequencies, which are not very demanding on a cable. Therefore, any decent cable should do. THe AR cables at accessories4less should be fine, in fact I just ordered one from them, and the Dayton cables at partsexpress should be OK as well. If you get any noise or hum, however, you need better shielding, and I'd go to bluejeanscable.com or RAM (a forum sponsor), who sell quality cables at reasonable prices. Better Cables, also a forum sponsor, sells more esoteric cables for more money.
For speaker wire, the partsexpress Sound King 12 or 14 gauge is hard to beat (12 gauge is bigger than 14 gauge, bigger is better). If you are going in-wall, get the in-wall wire from partsexpress or accessories4less. I am using 14 gauge, because my runs are not very long. 12 gauge is as large as you would need to get no matter how long your runs are.
M3 Pete is offline
post #8 of 11 Old 09-16-2004, 05:27 PM
Stray's Avatar
You're going to notice that you're going to have to discover alot of things through "trial and error"
I find that the Y adapter was a night and day difference for my sub....Others think it's a waste.....
You can buy a cheap adapter and a monster adapter.......Try both, you can always take 1 back or both if you notice no difference.....
Some will tell you to hook the sub up to your receiver through speaker terminals......
You have to experiment to see what works best.....
Stray is offline
post #9 of 11 Old 09-16-2004, 05:43 PM
oops...brain fart!
:D
post #10 of 11 Old 09-16-2004, 06:51 PM
Since my sub has a variable cross over, I use the speaker terminal connection as I can blend in the sub to the speakers much better than using the fixed x-over the the receiver.
post #11 of 11 Old 12-01-2004, 07:22 AM
sixdoubleseven's Avatar
I picked up a subwoofer cable from Radioshak that had a built in Y adapter. Should I hook up both pieces of the Y to the sub or just pick one and attach it to the mono? Is that bad for the sub? Should I return it for a single cable?
Thanks, Dave
sixdoubleseven is offline
Closed Thread Subwoofers, Bass, and Transducers
