Anyone upgraded their older SVS with the "improved" driver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-25-2004, 05:39 PM - Thread Starter
steve shisler's Avatar
Wondering if anyone who had one of the original SVSubwoofer's and bought the "improved" driver can give me a hands on review as to whether there was a clear difference with the new driver.
I've had my 20-39 cs passive unit for more than 3 years now and am thinking about dropping the $130 to go with the improved driver. Obviously I'm not at all unhappy about what I've got, but I'm about to go through a significant receiver upgrade to get into 7.1 and started thinking about this upgrade as well.
Any first hand experience or reviews would be great.
steve shisler is offline
post #2 of 6 Old 11-25-2004, 07:40 PM
DMF
DMF's Avatar
Does it have to be an SVS 20-39 cs or can we discuss any sub driver upgrade in your thread?
No matter where you go. ... There you are.
DMF is offline
post #3 of 6 Old 11-25-2004, 08:21 PM
Jesse S's Avatar
I did it for my 20-39CS. It increases the capability in the 20-25hz range by about 2-3db and greatly reduces the tendency to bottom out when pushed too far. The sound of the improved driver is fuller where the original had a slightly lean sound in the 30-50hz range. Lots of people still want the old driver, I've been offered the same $60 that SVS offered by others after the fact. If you can get that it makes the upgrade a no-brainer.
Jesse S is offline
post #4 of 6 Old 12-02-2004, 02:05 PM
Sean_O's Avatar
I wonder what SVS does with all of those 'old' drivers?
Sean_O is offline
post #5 of 6 Old 12-02-2004, 02:20 PM - Thread Starter
Well SVS won't do anything with mine as they were only taking the old units back for a very limited window 3 years ago when they first came out with the "improved" unit.
I did not take advantage of their buy back plan at that time as I had just purchased my unit and didn't think the wife was going to go for me dropping more money when I had just bought the darn thing.
I installed the new unit a few days ago and it definitely is a stronger woofer. This size and weight of the magnet appeared to be at least 33% larger than the original. It was worth the upgrade dollars spent. The wife claims not to notice a difference, but what does she know.
The original driver will likely make it's way to ebay shortly. Anyone interested?
post #6 of 6 Old 12-02-2004, 08:33 PM
Jesse S's Avatar
I had lots of offers at home theater forum. Try there.
Jesse S is offline
Closed Thread Subwoofers, Bass, and Transducers
