KLIPSCH Question??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-29-2004, 06:31 AM - Thread Starter
jdant's Avatar
I have Klipsch RF-3's, RC-3, RS-3's, and a RSW 10 sub running off a Denon 3805. Should I set the RF-3's to small or LARGE. On the RF-3 spec page at http://www.klipsch.com/product/produ...section=specs, it states the RF-3's go from 37Hz-20kHz±3dB. Let me know what to put these at.
I ran the auto EQ on the DENON 3805 and it set the RF-3's to Large and it also set my RS-3's (rear speakers!!) to large.
Any help would be greatly appreciated!!
Klipsch Man
jdant is offline
post #2 of 9 Old 11-29-2004, 06:44 AM
zeusdog's Avatar
I have a very similar setup and I have my reciever set to large,gives a more fuller sound but switch between the two setups to decide what you think sounds better...
"Stop trying to hit me and hit me"
Matt
zeusdog is offline
post #3 of 9 Old 11-29-2004, 01:05 PM
klipsch's Avatar
Quoted: 183 Post(s)
Liked: 94
mine are set to large using my receiver...click my profile to see what I have...
klipsch is offline
post #4 of 9 Old 11-29-2004, 03:14 PM
Karp's Avatar
Quoted: 12 Post(s)
Liked: 32
I would set them to small and play with the crossover settings till you have the sound you like. Start with 80Hz and then drop it down to no higher than 50Hz. While your mains will go down that low, it is easier on the receiver if it doesn't have to drive the speakers in the lower ranges. In addition, your woofers will be able to more accurately reproduce the remaining sound. Let your subwoofer do what it was made for.
No matter where you go, There you are ;)
Karp is offline
post #5 of 9 Old 11-29-2004, 03:15 PM
DMF
DMF's Avatar
If the RSW-10 can reproduce anything below about 40 Hz, you should set all other speakers to SMALL. Otherwise the sub won't get any signal to produce bass below 37 Hz that the other speakers can't reproduce.
Btw, the title of this thread is not good. This question is about setting up a system with subwoofer. It has nothing to do with the brand of speakers or receiver. And it should be in the Subwoofer forum.
No matter where you go. ... There you are.
DMF is offline
post #6 of 9 Old 11-29-2004, 03:43 PM - Thread Starter
jdant's Avatar
Thanks for the threads guys!! DMF(aka-avsforum police) I will try turning the RF-3's to small and see if the sub goes lower. Lata
Klipsch Man
jdant is offline
post #7 of 9 Old 11-29-2004, 05:49 PM
Kipp Jones's Avatar
Ease up, the guy is new. :rolleyes: :rolleyes: :rolleyes:
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #8 of 9 Old 11-29-2004, 05:59 PM
DMF
DMF's Avatar
Consider it tough love.
DMF is offline
post #9 of 9 Old 11-30-2004, 09:31 PM
Kipp Jones's Avatar
Kipp
Closed Thread Subwoofers, Bass, and Transducers
