Loud hum from subwoofer - AVS Forum | Home Theater Discussions And Reviews
Old 11-29-2004, 11:09 AM - Thread Starter
bshor's Avatar
Hello,
I've had my Energy EXLS8 Sub for probably about 5 years now. It's worked very well for me over that time.
Now, however, there's a strange and very loud hum emanating from the sub whenever I turn the output dial to anything higher than zero in any application: DVD, TV, etc.
No other speaker in my 5.1 setup exhibits this problem. I'm using an Onkyo 801NR receiver.
What could be going on? Is the Energy sub shot?
bshor is offline
Old 11-29-2004, 11:14 AM
thebland's Avatar
Quoted: 1495 Post(s)
Liked: 847
Have you changed anything in your system, changed the outlet, anything new (even if any appliance was plugged into that circuit) that may have caused this.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
Old 11-29-2004, 12:21 PM
Morbius's Avatar
Jeff's correct.
A loud hum is indicative of a "ground loop".
There are any of a number of ways for you to inadvertently cause a ground loop - like
changing how components are plugged in.
A ground loop is often difficult to localize. The cause may be due to some appliance
that is not part of the audio system - but is plugged into the same branch circuit as
the audio system.
Good Luck.
Dr. Gregory Greenman
Physicist
Morbius is offline
Old 11-29-2004, 01:13 PM
Micah008's Avatar
I had a similar problem, and it was because the amp went bad in my sub. Same problem existed when I plugged it into a totally different room, which probably wouldn't have happened with a ground loop.
Micah008 is offline
Old 11-29-2004, 02:03 PM
SoccerGuy's Avatar
I had the same problem. I checked all my outlets with an outlet checker. Unplugged all components and still was getting humm. Turns out that my cable was not grounded. I recently upgraded to digital/HDTV cable, and the installer forgot to ground. Hooked up the ground wire. Fixed my subwoofer humming and the banding on my projector.
SoccerGuy is offline
Old 11-29-2004, 02:14 PM - Thread Starter
bshor's Avatar
Thanks everyone, I figured out the problem.
I had wedged the sub against the wall (not much maneuvering room in my apartment), and the sub cable eventually was just flexed too far and gave out. After checking the cable out closely, a few pushes were enough to break off the end of the cable; it had probably been barely attached.
Anyway, I tried using a basic RCA cable to test the connection, and the sub works. Now off to get a cheap, decent cable for the sub ...
Anybody have experience with PartsExpress.com's Dayton Subwoofer Cable? $12 sounds good...
Thanks again for the suggestions!
bshor is offline
