Wiring Gurus help, Bass Shaker & Sound Card? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-30-2004, 04:34 PM - Thread Starter
skilzygw's Avatar
Hi I just received my parts express order. I received 2 bass shakers and the parts express 70W SUBWOOFER AMPLIFIER
Part Number 300-784
Ok I have the shakers in a series connected to the subwoofer outs( Red and a Black Cable)
The problem is how do I connect a SB Live 5.1 card to this amp?
The amp has
A high level input Left & Right ( which uses bare speaker wire)
A High Level output Left & Right ( which uses bare speaker wire)
A low level out ( 2 bare wires)
A low level in ( Red & White RCA Cable)
Ok so what do I do? How do I connect a SB live 5.1 to this amp?
This is the amp
http://www.partsexpress.com/pe/showd...number=300-784
skilzygw is offline
post #2 of 8 Old 11-30-2004, 05:49 PM
DMF
DMF's Avatar
You will use low-level In, connected to the .1 (sub) channel of your card. You will need appropriate connectors and adapters. Look at the sub amp manual to see if you need to use one or both Ins.
No matter where you go. ... There you are.
DMF is offline
post #3 of 8 Old 11-30-2004, 07:23 PM
mtstans's Avatar
I don't think sound cards have low level outputs? At least not a SB.
I'm doing a stereo system in my office too and I'm actually using my digital outs to go to a receiver and then a reciever to the stereo. Will full range out going into low level in hurt things?
I think what you have to do is use the analog output of your sound card. Looks like you would need a 1/8th jack y splitter into 2 rca female ends. And then from there run 2 rcas into your your line level input (red white rca plug) of your sub. And then run your speaker wire from your sub to your speakers.
However, I don't think you can do surround sound with this type of setup, because of the in put out put set up on the sub amp.
Which gets me to thinking about what setup I'm going to run on mine. Does anyone know if it's harmful to run from asound card to a amp or receiver since in fact the sound card is a small amp its self, and has power coming off of it?
I'm not an expert and prolly know the least on here, but I hope this helps get you going.
Matthew
mtstans is offline
post #4 of 8 Old 11-30-2004, 07:30 PM
DMF
DMF's Avatar
Gee, Matt. If you don't know anything why did you contradict me?
DMF is offline
post #5 of 8 Old 11-30-2004, 07:38 PM
mtstans's Avatar
Didn't mean to step on your toes brother. Was just expanding the information at hand, and present another question in the same ball park. Like I said I didn't think that the SB live had low level outs? I could be wrong though. I thought it only had digital out, front analog out, rear analog out, etc..
Sorry =(
mtstans is offline
post #6 of 8 Old 11-30-2004, 09:44 PM
mshe's Avatar
You can connect the Line Level Front/HeadPhone out to your amp. You might need to pick up a F-mod to filter out the higher frequencies... unless the amp you bought has an onboard filter.
mshe is offline
post #7 of 8 Old 11-30-2004, 09:58 PM
DMF
DMF's Avatar
The SB Live does indeed have low- (aka line-) level outputs. I don't know any audio card (or on-board set) that doesn't, or to restate it, I know of only one modern audio card that has an on-board speaker amp and the SB Live ain't it.
The card has 6 analog out channels in (if I recall correctly) three stereo mini-pin sockets. One of those is for the sub. No need for filters, but he probably needs cable adapters.
DMF is offline
post #8 of 8 Old 12-01-2004, 11:29 AM - Thread Starter
skilzygw's Avatar
thanks for the rgeat replies.
The sb live has 3 outs:
A rear out. A front out. and a center/sub out that also doubles as a digital out(configured in softaware)
I have a 1/8th plug to rca adapter. When playing a movie it works great. Except for the fact that i need a line splitter so i can plug a speaker and my sub at the same time to the same card output.
Anyway for movies the card works fine when set to 5.1.
BUTTTTTTTTTTT Games when the card is set to 5.1 does not send any signal to the center/sub out on the sb live. I have only tried Medal Of Honor Allied Assault.
So what i had to do was set it to 4 channel audio and use the rear out as the sub.
I guess these older games dont support 5.1? I have yet to try half life 2 and doom III.
All in all when the shakers work they're great.
skilzygw is offline
Closed Thread Subwoofers, Bass, and Transducers
