2 Jbl E250 Or Svs Pb10 Isd - AVS Forum | Home Theater Discussions And Reviews
Old 12-01-2004, 01:56 PM - Thread Starter
MIKE4211's Avatar
I'M TIRING TO DECIDE BETWEEN 2 JBL E250'S OR 1 SVS PB10 ISD THE ROOM IS ON THE SMALL SIDE AND I COULD GET BOTH FOR THE SAME PRICE THIS WOULD BE USED 95% OF THE TIME FOR MOVIES
MIKE4211 is offline
Old 12-01-2004, 02:16 PM
PolkThug's Avatar
Speculating, the dual JBL's may have more output above 27Hz, and the single SVS will have more output below that point. Try to find a freq response for the E250.
PolkThug
PolkThug is offline
Old 12-02-2004, 06:41 AM - Thread Starter
MIKE4211's Avatar
THERE WAS A ARTICLE IN SOUND AND VISION THAT SHOWED THE OUTPUT ON 2 E250 AT 121DB AT 62HZ , 100DB AT 40HZ AND 80DB AT 2OHZ WILL THIS KIND OF SHARP FALL OFF MAKE THE SOUND VERY BOOMY FOR MOVIES OR IS THAT MAINLY A PROBLEM FOR MUSIC
MIKE4211 is offline
Old 12-02-2004, 07:11 AM
PolkThug's Avatar
Exactly what I thought. Judging by those numbers, looks like the E250 has weak low end but lots of midbass output. I would definitly go with a single PB10, or you will be missing out on some of the good low-bass material.
PolkThug
PolkThug is offline
Old 12-02-2004, 07:51 AM
thebland's Avatar
Quoted: 1493 Post(s)
Liked: 846
1 sub. I would choose 1 SVS. There is nothing to gain by using 2 wimpy subs over 1 good sub.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
Old 12-02-2004, 09:21 AM - Thread Starter
MIKE4211's Avatar
POLK , I SEE YOU HAVE 2 PB10 HAVE YOU TRIED JUST ONE , AND HOW DO YOU LIKE THE SVS COMPARED TO THE POLKS YOU HAD
MIKE4211 is offline
Old 12-02-2004, 04:54 PM
PolkThug's Avatar
Here is the difference between 1 or 2 SVS PB10's. (see pic)
Subs are stacked in the corner, mic is 12 feet away in the listening position (my seat).
PolkThug
PolkThug is offline
Old 12-02-2004, 04:57 PM
Moderator
Moderator
Woodrow's Avatar
For the love of god, quit typing in caps....:)
Woodrow is offline
