Subwoofer cable length - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2004, 10:00 PM - Thread Starter
mdbridges's Avatar
How long can a subwoofer cable be before the signal degrades? Can a 50 foot cable be used?
mdbridges is offline
post #2 of 4 Old 12-01-2004, 11:15 PM
DMF
DMF's Avatar
Sure. "Degradation" takes the form of attenuation. To counteract, just turn up the gain a bit. At 100 ft I'd start to be careful.
If you go that long you might want to look into DIY cable from RG-6 coax.
No matter where you go. ... There you are.
DMF is offline
post #3 of 4 Old 12-03-2004, 07:28 AM
sagedidj's Avatar
FWIW, I've got a homebrew 40+ foot cable made from Radio Shack microphone cable (!) which works just fine. I would imagine 50 feet of decent cable would be fine. You might look at http://www.partsexpress.com for either pre-made or raw cable.
sagedidj is offline
post #4 of 4 Old 12-05-2004, 10:15 PM
Gshepherdogs's Avatar
I'm running a 50ft cable from Cobalt Cable. Absolutely no problem whatsoever.
Gshepherdogs is offline
Closed Thread Subwoofers, Bass, and Transducers
