wiring two recievers to one sub, possible?... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-04-2004, 09:07 PM - Thread Starter
slick316's Avatar
a friend of mine is considering this. he has a set of klipsch satelites and a 10" sub (i think its the reference series 10"). his computer is also located in the living room (apartment). he has a set of bookshelves hooked up to a stereo reciever going to his pc sound card. he was wondering if he can have the reciever thats connected to the pc connected to the sub at the same time the sub is connected to his home theater, make sense?
he has HT reciever connected to the sub using the rca line out and was wondering if he can utilize the high level on the sub amp for the pc reciever. i'm assuming he wants to connect the reciever going to his pc to the klipsch sub high level inputs, then from the high level inputs to the speakers, or something like that. i am starting to not understand now :( simply put, if you can understand what i typed, is it possible?
slick316 is offline
post #2 of 6 Old 12-04-2004, 09:18 PM
DMF
DMF's Avatar
I suppose it's possible, but I wouldn't do it.
Tell him to consider cascading the PC sound card into receiver with the digital out (if the card has one).
No matter where you go. ... There you are.
DMF is offline
post #3 of 6 Old 12-04-2004, 10:41 PM
SIMJEDI's Avatar
Agreed, just hook the PC up to the reciever digitally.
peace
SIMJEDI is offline
post #4 of 6 Old 12-05-2004, 08:17 AM - Thread Starter
slick316's Avatar
i dont think the receiver that he is using for the pc has a digital input, i'll have to check though.
slick316 is offline
post #5 of 6 Old 12-05-2004, 10:22 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Only do this with a switch never but never have 2 live sources on one speaker. you are looking for a possible MAJOR DISASTER!!!
RCbridge is offline
post #6 of 6 Old 12-05-2004, 10:35 AM - Thread Starter
slick316's Avatar
i'm sure he doesnt want that. what is a switch? like a speaker switcher? maybe it would be best if he just leaves it alone, he's adament though.
second option, a small, cheap, and i mean cheap sub that will work for his pc setup. $100 anyone?
slick316 is offline
Closed Thread Subwoofers, Bass, and Transducers
