CT-80 vs. CHT8 - AVS Forum | Home Theater Discussions And Reviews
Old 12-05-2004, 02:50 PM - Thread Starter
spongebob's Avatar
Quoted: 38 Post(s)
Hi Bruce,
My budget, room size, and personal tastes (Don't like low, low wall shaking bass) has me looking for a used 8" Velodyne.
What's the difference between the CT-80 or the CHT-8. which is better?
thx
bob
spongebob is offline
Old 12-05-2004, 02:53 PM
JimRoberts100's Avatar
If these two subs follow the same numbering system of the other velodyne subs, then they are the same sub - just a part number change.
I have the Velodyne CT-150 which was changed to the CHT-15 in the new part number system.
JimRoberts100 is offline
Old 12-06-2004, 03:09 AM
ranster's Avatar
Bob,
I'm a big fan of velodyne, but you may want to save your money for a better alternative.
I would recommend the new DPS series or a used SPL 8" sub.
I'm currently using a CHT8 for extension of my JBL towers in HT applications. An upgrade to one of the subs I mentioned is on my xmas wish list.
Good luck,
Randy
ranster is offline
