Down-Firing vs Front-Firing - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-06-2004, 04:41 PM - Thread Starter
tallman's Avatar
Is there an advantage/disadvantage to each design such as in the SVS PB10 and PB12
tallman is offline
post #2 of 6 Old 12-06-2004, 07:21 PM
DMF
DMF's Avatar
I don't think that there's much audible advantage in sealed subs. The down-firing driver does provide some physical protection.
In ported subs, the difference is down-firing ports. Can do a very effective job of suppressing port noise. Eliminates port noise complaint. Like this one:
http://www.outlawaudio.com//products/lfm1.html
No matter where you go. ... There you are.
DMF is offline
post #3 of 6 Old 12-06-2004, 10:22 PM - Thread Starter
tallman's Avatar
I have to get a larger Sub but my problem is that it will be on the side of the seating area.
Hence a front firing sub will not be directed towards the seating area, in that case would a downward firing sub offer better sound dispertion ?
tallman is offline
post #4 of 6 Old 12-06-2004, 11:21 PM
DMF
DMF's Avatar
Bass isn't directional, but with a side-firing driver some positions will be closer to the driver than others the same distance from the sub. Not so on a down-firing sub.
Not sure what the net effect is, but I guess the latter could be said to have better dispersion.
DMF is offline
post #5 of 6 Old 12-06-2004, 11:36 PM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
Do you have kids? I worry about my front firing driver being damaged by my kids. So far so good though....knock wood.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #6 of 6 Old 12-07-2004, 04:39 AM - Thread Starter
tallman's Avatar
Kids are older so that is not a problem. What I am liking is that there is no grill that can fall off or tabs that can break off
The down-firing units seem to be more solid, perhaps it is the lower center of gravity
tallman is offline
Closed Thread Subwoofers, Bass, and Transducers
