subwoofer stand? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 09-17-2005, 07:17 PM - Thread Starter
scottielee's Avatar
hi,
are there any high quality subwoofer stands available besides asc subtraps? any experiences with them?
thanks!!!
scott
scottielee is offline
post #2 of 18 Old 09-17-2005, 07:19 PM
Kal Rubinson's Avatar
Quoted: 802 Post(s)
Liked: 567
Somewhat different but, also, somewhat effective and much cheaper are the Auralex Sub-Dudes (or Grammas).
Kal
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #3 of 18 Old 11-28-2005, 07:54 AM
RavenX's Avatar
Or you can spike them. It is cheaper and better overall.
RavenX is offline
post #4 of 18 Old 11-28-2005, 08:02 AM
Quoted: 802 Post(s)
Liked: 567
That depends on your floor construction and support. Concrete/solid floors are appropriate for spikes/coupling; wood/sprung floors are appropriate for Subdudes/isolation.
Kal
Kal Rubinson
post #5 of 18 Old 11-28-2005, 08:30 AM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
What is the need for spiking a sub? I have an SVS PB-10 which is considered a high quality sub right?... so why wouldn't it come with spikes if they were needed? My JBL E-100 floorstanding speakers did come with spikes. Anyone care to edjumacate me on this?
Smarty-pants is offline
post #6 of 18 Old 11-28-2005, 08:37 AM
Quoted: 802 Post(s)
Liked: 567
You might not need spikes depending on your situation, so why make everyone pay for them?
Kal
Kal Rubinson
post #7 of 18 Old 11-28-2005, 11:52 AM
Capfacsurf's Avatar
Why would spikes or stands be needed for a subwoofer?
With my system, In my room, to my ears......
Capfacsurf is offline
post #8 of 18 Old 11-28-2005, 12:04 PM
fergusonv's Avatar
I have would floors and after isolating my sub it made a world of difference.
fergusonv is offline
post #9 of 18 Old 11-28-2005, 12:23 PM - Thread Starter
scottielee's Avatar
thanks for all of your response. i was tempted by the Auralex Gammas but they are kind of ugly to me. i am pretty much sold on the Symposium platforms but they are expensive...
post #10 of 18 Old 11-28-2005, 08:21 PM
Quoted: 751 Post(s)
Liked: 628
I asked this as well. Guess no-one wants to answer. Maybe starting a new thread would get at least an explanation.
post #11 of 18 Old 11-29-2005, 03:24 AM
Fatman513's Avatar
scottielee, the Gramma is ugly, but Auralex makes the same type of product, just much better looking, called the Subdude.
http://www.sweetwater.com/store/detail/SubDude/
Fatman513 is offline
post #12 of 18 Old 11-29-2005, 06:15 AM
enigma1406's Avatar
I just received a subdude from sweetwater yesterday. They were out of stock for a while there but just recently got a shipment.
enigma1406 is offline
post #13 of 18 Old 11-29-2005, 08:41 AM
Quoted: 802 Post(s)
Liked: 567
It depends on the surface on which it sits. Spikes onto a non-resilient floor, such as concrete, will make the sub as stable and immoveable as possible. With a less rigid surface, such as wood flooring set across beams, a compliant base, like a SubDude, will give stable support and isolate the sub from the floor. This prevents the floor from resonating and making a spurious contribution to the sound.
Kal
Kal Rubinson
post #14 of 18 Old 11-29-2005, 08:47 AM - Thread Starter
scottielee's Avatar
thanks again for everyone's response.
is SubDude an earlier version of Gramma? SubDude is not listed on Auralex's website.
post #15 of 18 Old 11-29-2005, 09:17 AM
Fatman513's Avatar
You have to go to the Auralex Elite website: http://www.auralexelite.com/sound_is...on_subdude.asp
post #16 of 18 Old 11-29-2005, 09:24 AM - Thread Starter
scottielee's Avatar
thanks Fatman513!
post #17 of 18 Old 11-29-2005, 10:54 AM
pistolpete's Avatar
Great spikes here.
http://www.partsexpress.com/pe/showd...number=240-716
Peace comes not from goodwill, but from strength in the hands of good men.
pistolpete is offline
post #18 of 18 Old 12-02-2005, 07:28 PM
RavenX's Avatar
To isolate it from the ground, same as with any other speakers. You don't want vibrations to reverb back to your sub and make it sound muddy and distorted.
Note: You can use spikes on any ground. For wooden floors buy support disks or rubber feet in order to prevent damage of expensive floors or carpets.
RavenX is offline
Closed Thread Subwoofers, Bass, and Transducers
