Auralex Subdude Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #541 of 1410 Old 06-14-2009, 08:45 AM
soloz2's Avatar
sweet, didn't know you could order custom sizes. I bet that cost a pretty penny.
soloz2 is offline
post #542 of 1410 Old 06-14-2009, 09:19 AM
vili's Avatar
It wasn't too bad. I got a quote from a local company for like $380 plus shipping...ridiculous. Got a quote from Sweetwater and paid less than half that shipped.
vili is offline
post #543 of 1410 Old 06-14-2009, 09:55 AM
soloz2's Avatar
not bad at all. Two Subdude HD's would be $120 shipped, and then not the ideal size anyway.
soloz2 is offline
post #544 of 1410 Old 06-14-2009, 09:55 AM
Kevin A's Avatar
My situation is I have an SVS pc12-nsd sub in my home theatre set-up. The room is upstairs (over the garage) and has pergo flooring over a standard particle board subfloor. The sub is producing wonderful, room-filling bass for both HT and music-listening experience. My issue is the 'booming' resonance that is heard (felt?) in the remainder of the house. I contacted SVS & explained the situation and asked their advice." As I suspected, according to Jack at SVS, ..."most of the bass is transferred via the actual sound and not through the physical vibrating of the floor by the sub....you can experiment with putting something under the sub to de-couple it a bit and see what it sounds like downstairs." Good, practical advice and so I've ordered the Auralex Subdude (15" x 15) and will give it a try & see if it has an impact on the 'noise' factor downstairs.
It'll be interesting to see if the subdude provides a difference. I'll report what I find.
Kevin A is offline
post #545 of 1410 Old 06-14-2009, 10:35 AM
Audixium's Avatar
Quoted: 30 Post(s)
I think you'll still hear it, but at least pictures won't keep falling off the wall and breaking the glass anymore , a big plus in my case .
Audixium is offline
post #546 of 1410 Old 06-14-2009, 06:04 PM
maxht's Avatar
I am using Subdude. Previously, it was meant for my Velodyne DSLR4000. It did minimise the boominess of my Velodyne. Bass is firmer. Then, I bought the SVS PC-12Plus. The Subdude is a little smaller (15" x 15") since the diameter of PC-12Plus is 16". A little protruding.
It does not isolate the bass as it is meant to isolate vibration. Sound still pass through and fills my home just like Audixim mentioned. Now, I am doing acoustice treatment to minimize it.
Bass, please. Shaken, not stirred.
maxht is offline
post #547 of 1410 Old 06-14-2009, 06:09 PM
Kevin A's Avatar
Originally Posted by maxht View Post
I am using Subdude...Then, I bought the SVS PC-12Plus. The Subdude is a little smaller (15" x 15") since the diameter of PC-12Plus is 16". A little protruding.
Yeah, I think part of the 'downstairs' effect may be due to some of the vibration of the wood floor radiating through the floor joists that span the house. I'm anxious to hear if it makes any improvement to the situation.
Kevin A is offline
post #548 of 1410 Old 06-15-2009, 08:00 PM
sketch2099's Avatar
at construction sites where equipment creates structure-born vibration issues, they just place these pads under the machinery and it works great
http://www.acousticalsolutions.com/p...FRZM5Qod9gmqpg
anyone care to comment on how it would compare to a subdude?
sketch2099 is offline
post #549 of 1410 Old 06-15-2009, 08:28 PM
Jakeman02's Avatar
They are 1/4 and 3/8" thick, the foam supports on the subdude are around 2" thick an the rest of the area is covered with the same type foam. I'm sure they would have some effect but at around twice the price I'd stick with the subdude.
Jakeman02 is offline
post #550 of 1410 Old 06-16-2009, 07:05 AM
mcjasonb's Avatar
Liked: 113
every sub needs a subdude.
Nearfield rig: Laptop -> JDS Labs ODAC -> Emotiva Mini-X -> Pioneer SP-BS22-LR & SW8-mk2Headphone rig: laptop -> JDS Labs ODAC -> Emotiva Mini-X speaker taps -> modded AKG Q701H.T.: PS3 - Yamaha RX-V2500 - Infinity Alpha 50's - Alpha center - Harmon Kardon HKB6 rears, Epik SentinelMy last.fm profile
mcjasonb is offline
post #551 of 1410 Old 07-13-2009, 11:29 AM
generalhead's Avatar
anywhere you can find one for under $49?
generalhead is offline
post #552 of 1410 Old 07-13-2009, 11:37 AM
mcjasonb's Avatar
Liked: 113
i found the GRAMMA at a local Guitar Center for $50, i would assume the Subdude would be less than $50 there since the bigger GRAMMA is $50 there.
mcjasonb is offline
post #553 of 1410 Old 07-13-2009, 07:34 PM
MayhemNJ's Avatar
Quoted: 14 Post(s)
Whats the difference between the Gramma and the Subdude?
MayhemNJ is offline
post #554 of 1410 Old 07-13-2009, 07:38 PM
mcjasonb's Avatar
Liked: 113
the GRAMMA is just a bigger size. the Subdude is 15x15. the GRAMMA is 23x15.
my sub is 21x14.5, so i went with the GRAMMA. awesome product, really tightened things up, and lessened most of the rattles in my room.
mcjasonb is offline
post #555 of 1410 Old 07-13-2009, 07:40 PM
MayhemNJ's Avatar
Quoted: 14 Post(s)
Thanks Jason....I think im going to pick up the Gramma..Looks like a perfect size for the Sentinel...I have it on a hardwood floor and the whole house is shaking
MayhemNJ is offline
post #556 of 1410 Old 07-13-2009, 07:43 PM
mcjasonb's Avatar
Liked: 113
yup, perfect fit. i'd rather have the mat underneath be bigger instead of having the sub look like it's floating in mid air like the Subdude would do.
mcjasonb is offline
post #557 of 1410 Old 07-13-2009, 10:38 PM
ZivkoF's Avatar
Quoted: 23 Post(s)
Liked: 31
I agree GRAMMA is bigger and you might have two for big subwoofers
ZivkoF is offline
post #558 of 1410 Old 07-14-2009, 07:13 AM
Stew4msu's Avatar
Or you could use the Great GRAMMA, which is what I did.
Stew4msu is offline
post #559 of 1410 Old 07-14-2009, 09:06 AM
ZivkoF's Avatar
Quoted: 23 Post(s)
Liked: 31
Yes if it fits under subwoofer, but one Great GRAMMA wont be enough for 36x24x36 (HxWxD) subwoofer and two GRAMMAS are .
ZivkoF is offline
post #560 of 1410 Old 07-16-2009, 06:57 PM
The lack of deals to be found on the Subdude is irritating me. I can't find it any cheaper than the GRAMMA. Somebody needs to produce these for less than $50.
post #561 of 1410 Old 07-16-2009, 07:47 PM
mcjasonb's Avatar
Liked: 113
why?
mcjasonb is offline
post #562 of 1410 Old 07-17-2009, 03:47 AM
why?
First, the GRAMMA also costs $50, but it's bigger. The smaller size should be cheaper.
Second, I doubt it costs more than $20 to manufacture.
Third, I'm cheap.
post #563 of 1410 Old 07-17-2009, 05:15 AM
mcjasonb's Avatar
Liked: 113
Third, I'm cheap.
to me the GRAMMA was well worth the $50 i paid. retail on the GRAMMA is supposed to be $60.
mcjasonb is offline
post #564 of 1410 Old 07-17-2009, 05:28 AM
Jakeman02's Avatar
Third, I'm cheap.
Both the Subdude and Gramma have been the same price for as long as I've been in the game which as been several years and the price hasn't changed, which can't be said about many items. Personally I think it's a completely fair price considering the cost of running a business. By the time one paid for the materials to construct one, gas, tax and other expenses I'd venture to say you'd be right at $50 not to mention time involved and they don't use ordinary foam. It's very VERY dense stuff. Most foams would cave under the weight of my 85lb sub but doesn't budge with the sub dude.
If you want to try and construct one by all means go for it but I doubt you'd beat the price by much if at all and maybe come out worse by the time you added everything up and probably not get the exact same quality material used in the process plus the time involved, whatever that's worth to you vs one click ordering.
post #565 of 1410 Old 07-17-2009, 06:30 AM
I went to a guitar shop yesterday that had the GRAMMA with a ticket saying "Reduced Price $49.99 regularly 59.99". But when I spoke with an employee he said in slightly different words that that's just marketing, they've always sold them for $50. He said he could order in a Subdude, but it would also be $50.
post #566 of 1410 Old 07-17-2009, 06:39 AM
I'm not one to say that the something is right just because that's how it's always been.
All of the overhead you mention would be the same for both. But the GRAMMA uses more materials, meaning it costs more to manufacture. If the GRAMMA can be sold profitably for $50, it only makes sense that its little brother could be sold profitably for less.
I don't have nearly the resources available that Auralex has at their disposal. I'm sure I could not personally construct one for less. But there has to be another company that makes room treatment materials like Auralex that could offer some competition.
post #567 of 1410 Old 07-17-2009, 06:41 AM
On the other hand for all I know they might start with the same exact materials just having less waste for the GRAMMA.
post #568 of 1410 Old 07-17-2009, 01:05 PM
mcjasonb's Avatar
Liked: 113
just buy one... it's worth it. so many people have stated that to them it was worth the 50 bucks, but if you don't feel that it is, then oh well.
mcjasonb is offline
post #569 of 1410 Old 07-17-2009, 01:36 PM
nathan_h's Avatar
Quoted: 1317 Post(s)
Liked: 861
FYI, Auralex is the budget provider. Other than people selling packing foam and calling it acoustic foam, they are the low cost provider for this kind of thing.
Most of the cost of a product like this at this price point is from the overhead factors mentioned. The difference in materials cost between the two sizes is probably a $1 or so.
Buy my Triad LCR or corner speakers or check out my current theater & gear.
Listen to the best movie review podcasts: the /filmcast and the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is online now
post #570 of 1410 Old 07-17-2009, 01:42 PM
mcjasonb's Avatar
Liked: 113
that's probably true. think about what material there is. MDF, foam, the fabric that covers the mdf, and a little glue. the GRAMMA is only 8" bigger. how much more can that little extra really cost.
mcjasonb is offline
Auralex , Auralex Subdude 15 X 15 X 2 Inch Isolation Riser
