Auralex Subdude Owners Thread - Page 44 - AVS Forum
post #1291 of 1318 Old 12-02-2013, 10:41 PM
AVS Club Gold
tigerhonaker's Avatar
Originally Posted by npat3 View Post
Ok, I decided to just call Auralex and was told that the Dubdude II would work...as I suspected, all that is necessary is to separate the floor from any points of contact with the sub. I ordered it this morning.
Very good I hope it (Helps) with your issues.
It did mine as well as many other members here for sure.
Terry
kkirsche likes this.
tigerhonaker is offline
post #1292 of 1318 Old 12-09-2013, 11:22 AM
npat3's Avatar
I just wanted to report back that I tried the Subdude II and it resolved my subwoofer rattle issue. Also, I know there is a lot of debate on this thread about whether these products affect sound quality, and I am not qualified to contribute to that discussion. However, subjectively, it seems to have resulted in a slightly cleaner audio experience simply due to a reduction in wall vibrations. This actually allowed me to turn the volume higher on the sub.
npat3 is offline
post #1293 of 1318 Old 12-09-2013, 11:46 AM
AVS Club Gold
I'm glad they worked out for you as they have for many of us.
I know for sure they made a noticeable difference in my application.
I'm sure you are glad now you went ahead and tried them for yourself.
One can read all they want to but in the end trying something for one's self is the key to the final answer.
Terry
post #1294 of 1318 Old 01-25-2014, 08:59 PM
mbroadus's Avatar
Quoted: 202 Post(s)
Liked: 79
I'm thinking of buying a sealed sub (SVS SB2000) and since it doesn't have a down firing port, would use the feet or not when putting it on a subdude?
mbroadus is online now
post #1295 of 1318 Old 01-25-2014, 10:29 PM
AVS Club Gold
You can use them or not sitting it on the Subdude.
Terry
post #1296 of 1318 Old 01-26-2014, 04:05 AM
fatbottom's Avatar
Quoted: 481 Post(s)
Liked: 209
Pretty expensive for closed cell foam pads and a bit of MDF..
Use a piece of marble that was free salavged from the scrap heap.
Krell Evolution 900e x 7
Bose Jewel speakers.
Jealous of my speakers?
fatbottom is online now
post #1297 of 1318 Old 01-26-2014, 08:58 AM
mbroadus's Avatar
Quoted: 202 Post(s)
Liked: 79
Terry
That's what I was thinking.
post #1298 of 1318 Old 01-26-2014, 10:55 AM
AVS Club Gold
Just keep in mind there are Members on here that don't like the products.
Terry
post #1299 of 1318 Old 01-26-2014, 05:32 PM
mbroadus's Avatar
Quoted: 202 Post(s)
Liked: 79
Terry
Oh well...I've had one for many years because I have wood floors and live in a town house so I share a wall with neighbors.
post #1300 of 1318 Old 01-26-2014, 11:02 PM
AVS Club Gold
I cannot see how it will be a negative for you.
It sure IMO can't hurt your situation at all and I think will help.
Terry
post #1301 of 1318 Old 01-27-2014, 07:07 AM
Bill Fitzmaurice's Avatar
Liked: 1768
The energy that radiates from a sub is sourced by the movement of the cone, not by the movement of the cabinet panels. If the cabinet panels vibrated sufficiently within the subwoofer frequency pass band to cause even a soft wood floor to vibrate you wouldn't be able to listen to it. The primary value of isolation devices is to their manufacturers and retailers, in how effectively they can separate uninformed buyers from their cash. rolleyes.gif
If you do have a soft floor the acoustic output of the sub can cause it to vibrate, and the sub might then vibrate atop the floor. if rubber feet alone don't prevent that a piece of this cut to size will do the trick:
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=202015909&R=202015909#.UP66YGeYUYc
It also can help with a sub that dances across a hard floor when it's cranked louder than you should probably be running it. wink.gif
Bill Fitzmaurice is online now
post #1302 of 1318 Old 01-27-2014, 08:19 AM
AllenA07's Avatar
Quoted: 110 Post(s)
Liked: 114
I picked up a Gramma Great this weekend, and I'm very curious to hear the results. I've had problems for a while with rattles so my only real hope here is that I get some of those cleared up. I've got a BIC F12 right now, but the reason for such a big one is sometime this summer I'll be moving up to an HSU VTF-15H.
AVR: Denon 2112
Speakers: EMP Tek e55ti, Center- EMP Tek e56ci, Side Surrounds- EMP Tek e55wi, Rear Surrounds- SVS Prime Satellites, Sub- SVS PC12 Plus
Display: BenQ w1070 on a 92in fixed screen
Blu-Ray Player: Sony BDP S6200;
Playstation 4
AllenA07 is online now
post #1303 of 1318 Old 01-27-2014, 09:57 AM
AVS Club Gold
If you have the time and think about it I as well as some other Members will be interested to read what you think.
So Post away once you test out your New Auralex Great Gramma.
Terry
BTW,
I have 4 of those under my 4-Subs.
post #1304 of 1318 Old 01-27-2014, 12:05 PM
mbroadus's Avatar
Quoted: 202 Post(s)
Liked: 79
Thanks Bill...I will try the sub without the subdude to see if I can tell a difference. I would have a difficult time explaining the laws of physics to my wife but she sleeps well and night knowing the subdude is doing its job! wink.gif
post #1305 of 1318 Old 01-27-2014, 01:02 PM
AllenA07's Avatar
Quoted: 110 Post(s)
Liked: 114
Terry
BTW,
Might be a week or two before I've got a impression of the thing, but I will post my feelings on it. I'm not really expecting a improvement in quality to be honest, I would just be happy if it took away some of the resonance issues I have. If the BIC F12 causes my place to rattle, the HSU VTF-15 is liable to cause my room to collapse. smile.gif So hopefully this clears up the problems. Any improvement to sound quality is going to be a plus at this point.
AVR: Denon 2112
Playstation 4
post #1306 of 1318 Old 01-27-2014, 01:12 PM
AVS Club Gold
In my case my HT is actually over my 2 1/2 car garage.
So it is sitting on a wood floor covered with carpet.
So the Subs. are sitting on the floor as well.
Before the Auralex Pads were added under all the Subs the dishes in the kitchen cabinets would rattle and vibrate.
Along with other things as well ....
Once these Auralex Pads were installed those dishes Stopped for the most part rattling.
Am I saying the Auralex Sound Deading Pads are the absolute answer for everyone, no I am not.
But in my situation they have help resolve some issues to my, (Satisfaction).
Terry
post #1307 of 1318 Old 01-27-2014, 01:43 PM
Liked: 1768
If the Subdud did what your wife would really like it to do it would cart the sub out to the curb just as the trash pickup was passing by. biggrin.gif
post #1308 of 1318 Old 01-27-2014, 02:04 PM
Tack's Avatar
Quoted: 455 Post(s)
Liked: 920
Damn, Bill. On the main page, the summary of your post was "If the Subdud did what your wife would really like it to do it would....."
Tack is online now
post #1309 of 1318 Old 01-27-2014, 06:24 PM
mbroadus's Avatar
Quoted: 202 Post(s)
Liked: 79
post #1310 of 1318 Old 03-03-2014, 05:39 AM
mattg3's Avatar
Quoted: 85 Post(s)
Liked: 114
Well I beleve a lot of opinions are valid so Im going to try this thread since last one pretty much said the subdude product would not help.Im not looking for sub performance upgrade but just the ability to use a sub on second floor of a condo and not get my neighbors below and beside me all upset.Will the subdude product do this for me and are their proven statements that it really keeps subs performance in a condo unit and not all over the building? thanks
Matt
mattg3 is offline
post #1311 of 1318 Old 03-03-2014, 06:21 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1205
The means for accomplishing what you desire is well known, and does not involve products like the Subdude. Doing what you want involves far heavier lifting involving a very serious construction project.
http://www.audioholics.com/room-acoustics/a-guide-to-sound-isolation-and-noise-control
arnyk is offline
post #1312 of 1318 Old 04-30-2014, 07:46 PM
eurovw89's Avatar
would I benefit from this on a carpet/padding on a concrete slab in my basement?
eurovw89 is offline
post #1313 of 1318 Old 04-30-2014, 09:15 PM
lovinthehd's Avatar
Quoted: 721 Post(s)
Liked: 1142
Think about that....what could the possible benefit be?
"I realize that somebody playing free music isn't as commercial as a hamburger stand. But is it because you can eat a hamburger and hold it in your hand and you can't do that with music? Is it too free to control?" - Don Van Vliet (aka Captain Beefheart) discussing commercial success in the music biz
lovinthehd is online now
post #1314 of 1318 Old 04-30-2014, 09:16 PM
eurovw89's Avatar
i dont know thats why I am asking
eurovw89 is offline
post #1315 of 1318 Old 04-30-2014, 09:35 PM
lovinthehd's Avatar
Quoted: 721 Post(s)
Liked: 1142
The benefits reported only come from those with poor wood flooring from what I can gather. Concrete flooring with carpet I can't imagine what the auralex thingy would have any further benefits.....other than perhaps raising your sub a bit (which in the larger scheme of room measurements is meaningless)
post #1316 of 1318 Old 05-01-2014, 12:21 AM
AVS Club Gold
I don't think in your case you would get much if any benefit from it.
Terry
post #1317 of 1318 Old 05-01-2014, 07:10 PM
eurovw89's Avatar
Thank you LovintheHD and Terry, that was what i was looking for. Couldn't find stating really anything about concrete....thanks again
eurovw89 is offline
post #1318 of 1318 Old 05-02-2014, 03:47 AM
McStyvie's Avatar
Liked: 78
You can make your own for less than ten bucks at the hardware store, worth a try at that price.
McStyvie is offline
Auralex , Auralex Subdude 15 X 15 X 2 Inch Isolation Riser
