Subwoofer with 2 inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-03-2006, 11:47 AM - Thread Starter
magawake's Avatar
My Dayton Sub100 has 2 subwoofer inputs (Left and Right).However, my reciever Denon Avr 2106 has only 1 subwoofer preout. I am not sure what to do with the extra sub input.
TIA
magawake is offline
post #2 of 16 Old 03-03-2006, 11:56 AM
PINKTULIPS7's Avatar
Quoted: 92 Post(s)
Liked: 43
Just Use Left Input To Sub........................ :d
PANASONIC TC-P55VT50
HARMAN KARDON AVR 7300**PARASOUND HALO A21 250W**EMOTIVA UPA-1 200W
L & R :> POLK RTI A9 500W**POLK CSI A6 200W**POLK RTI A3 150W**POLK FXI A6 150W
PANASONIC DMP-BDT 500**SVS SB-16 ULTRA 1500W [DUAL]
PANAMAX M5400-EX
PINKTULIPS7 is offline
post #3 of 16 Old 03-03-2006, 11:56 AM
Vikram R's Avatar
Split the subwoofer output with a Y-adapter, one to the left channel, one to the right.
Vikram R is offline
post #4 of 16 Old 03-03-2006, 11:59 AM - Thread Starter
magawake's Avatar
Wow! thanks for the quick replies.
What happens if I just use Left? Do I have to get a splitter?
magawake is offline
post #5 of 16 Old 03-03-2006, 12:44 PM
Macfan424's Avatar
Originally Posted by magawake
...What happens if I just use Left? Do I have to get a splitter?
You'll get about 3dB more gain with a splitter, or at least you did with the previous model. As I understand it, that doesn't affect the sub's maximum output, though, so it is not especially important. Still, splitters don't cost much (usually under $5.00), so why not?
Macfan424 is offline
post #6 of 16 Old 03-03-2006, 03:49 PM - Thread Starter
magawake's Avatar
Cool, got the splitter.
magawake is offline
post #7 of 16 Old 03-03-2006, 03:50 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
splitter useless
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 16 Old 03-03-2006, 03:53 PM
PLincoln's Avatar
Originally Posted by sivadselim
splitter useless
truth..absolutly no reason to use the splitter...or not to use the splitter if you already own one. it has zero impact on system performance
PLincoln is offline
post #9 of 16 Old 03-03-2006, 04:03 PM
Targus's Avatar
no, you won't.
Targus is offline
post #10 of 16 Old 03-03-2006, 04:12 PM
PLincoln's Avatar
there is an entire thread dedicated to this...someone use search PLEASE and dont start this argument all over again.
PLincoln is offline
post #11 of 16 Old 03-03-2006, 04:16 PM
PLincoln's Avatar
PLincoln is offline
post #12 of 16 Old 03-03-2006, 05:14 PM
Macfan424's Avatar
You're right, but, as noted in at least one of those, different sub manufacturers have different recommendations. The OP specifically asked about the Dayton, and my answer was based on the instruction sheet I got with my older version of that brand. I use a splitter with it, but not with my SVS PC+.
post #13 of 16 Old 03-03-2006, 05:53 PM
PLincoln's Avatar
i'm not trying to single you out...it was just more than I could take the first time around. the bottom line its that there is zero improvement in performance. yes some amps sum the input and you get the 3db boost...but its not like your gaining free headroom. once you recal the speakers the sub will just be 3db lower at the receiver end of things.
OP...but anyways...enjoy the sub. you got a great bang for the buck ...
PLincoln is offline
post #14 of 16 Old 03-04-2006, 06:32 AM
Targus's Avatar
still no.
Targus is offline
post #15 of 16 Old 03-04-2006, 07:01 AM
PLincoln's Avatar
Originally Posted by Targus
still no.
ok
PLincoln is offline
post #16 of 16 Old 03-04-2006, 07:37 AM
PLincoln's Avatar
"How do I hook up Velodyne subwoofers to my single (mono) sub out jack?
The signal sensitivity of the auto on/off circuit can be altered by the input hookup. If you use both inputs (connected by a "Y" cable or splitter cable) the unit will see greater signal at the inputs and turn on at a lower signal level. With only one input connected the unit will require greater signal levels to turn on automatically."
PLincoln is offline
Closed Thread Subwoofers, Bass, and Transducers
