Help with Definitive Supercube III - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-06-2006, 05:48 AM - Thread Starter
kiddodoc2002's Avatar
I recently bought a supercube III but when I plugged it in.......it had no power and since it came without the manual, is it possible that it has a blown fuse? Can someone help me. It doesn't have an off/on switch and the light is off. Have hooked it up but nothing. Any help would be greatly appreciated.
kiddodoc2002 is offline
post #2 of 5 Old 09-06-2006, 06:05 AM - Thread Starter
Checked the fuse and looks intact.
post #3 of 5 Old 09-06-2006, 07:03 AM
cecaa850's Avatar
If you've verified that the fuse AND power cord (and outlet) are OK, then you're looking at a trip to the shop for your sub. Is it still under warranty?
120@20@14'
cecaa850 is offline
post #4 of 5 Old 02-13-2007, 11:34 AM
avsuser2007's Avatar
How do you like your supercube III
avsuser2007 is offline
post #5 of 5 Old 02-13-2007, 04:08 PM
Kensmith48's Avatar
Quoted: 53 Post(s)
Have you tried a dvd or music? It takes a lfe signal to turn it on.
Kensmith48 is offline
