JL Audio Fathom 13" Sub - Page 232 - AVS | Home Theater Discussions And Reviews
 44Likes
post #6931 of 6943 Old 05-23-2015, 03:12 AM
dean122601's Avatar
Quoted: 23 Post(s)
Just hooked up my fathom 12 and I am having some issues.
I can not get the automatic room optimization to work. I follow the book and it still won't work. Anyone with any experience with this?
dean122601 is online now
post #6932 of 6943 Old 05-23-2015, 03:58 AM
giogt600's Avatar
Liked: 8
When you put the mic in the main listening position.....you may have to turn up the sub a bit to get it to register with the mic.
giogt600 is online now
post #6933 of 6943 Old 05-23-2015, 03:59 AM
dean122601's Avatar
Quoted: 23 Post(s)
I will try that. The calibrate light doesn't e be turn on. Normal?
post #6934 of 6943 Old 05-23-2015, 06:08 AM
giogt600's Avatar
Liked: 8
Power on the sub making sure it's not in auto mode. Once you've connected the mic....make sure the level mode is set to variable...start with master level at 12 o'clock.... LP filter to off.... e.l.f. trim to 0.....then press the calibrate button and yes it should light up mate. If the sequence of sounds it emits stops quite quickly and the calibrate light starts flashing about once every second then the level is too low and needs turning up a bit. Hope you have success but beyond doing that....if there's still no joy....it could be a phone call to your dealer.
Gio
dean122601 likes this.
post #6935 of 6943 Old 05-24-2015, 06:09 PM
dean122601's Avatar
Quoted: 23 Post(s)
Gio
It still didn't work. I will call dealer on Tuesday. The sub sounds great how much better does the JL calibration make it?
post #6936 of 6943 Old 05-24-2015, 06:23 PM
CIH USER
Franin's Avatar
Quoted: 819 Post(s)
Liked: 520
Just to give you an idea I bypass mine. I let Audyssey xt32 do the work.
Frank
_________________________
Frank
Franin is online now
post #6937 of 6943 Old 05-24-2015, 07:30 PM
giogt600's Avatar
Liked: 8
I don't honestly think performing the the JL A.R.O. is absolutely crucial in the current version of these wonderful subs. I think maybe once the V2 version of the fathoms come out it might be more of an effective feature. For me it was just the case of......it's a feature of the sub that's there, so I used it before letting audyssey XT32 do its thing. Just like frank has said....I also know other owners that don't use it either and they seem perfectly happy with their subs. My thinking is....it's a feature of the sub and wether you want to use it or not....it should work. For all we know it may just turn out to be a faulty mic that's not registering with the sub.
Ether way.....once you've contacted JL Audio I'm sure they'll soon sort it for you.
Gio
post #6938 of 6943 Old Yesterday, 05:33 AM
AvidHiker's Avatar
Liked: 42
It really depends on what your room requires in terms of correction; that said, most untreated rooms will need more. I found it did help eliminate a lot of bloat in the sound by going after the primary room mode. But, as others have already said, the more advanced processors are far more capable. Correcting both modes and ringing (time domain) brought my F112 (now two of them) to another level. Since I'm running 2.1 sound with an analog preamp, I use an external processor (dspeaker 8033c) to feed the Fathoms, and it works wonders.
AvidHiker is online now
post #6939 of 6943 Old Today, 04:06 PM
dean122601's Avatar
Quoted: 23 Post(s)
So I am still having issues with the calibration system of my fathom 12. Called dealer and he says no problem will take care of it. So I asked the dealer if it would be an issue if I traded in for a fathom 13 and he said no problem. My question is would it be worth to trade up to the 13? Mostly home theater in my house Dealer working on a price right now just don't know if it is worth the extra money. Anyone have any insight on the comparison of the two? The dealer does not have two set up side by side so can't listen to both. Any help would be great.
post #6940 of 6943 Old Today, 04:16 PM
giogt600's Avatar
Liked: 8
I've listened to a pair of f113's on several occasions now at my favorite independent dealer and they sound awesome I can tell you that.
I don't think you'd be disappointed with owning the f112.....and for me.....going for the f112 over the f113 was more a choice made on actual size of the sub. The f113 was just a touch to big for my room and where I needed to locate it.
I would say it would come down to the size of your room really.....but you'll definitely love it.
Just think of it this way......whatever you like about the f112.....the f113 will just have more of it. It will dig deeper and have more impact I'd imagine but either way.....they are both top end quality subs and whichever you choose you'll be smiling I'm sure...!! :thumbsup:
post #6941 of 6943 Old Today, 05:05 PM
AvidHiker's Avatar
Liked: 42
The F113 will dig deeper, no doubt, at the expense of some utility in the mid-bass (likely only a concern if you cross over above 100Hz). If it were me, I'd save up for a second F112 if you have the room (or ditch the Fathom and consider a matched pair of sealed subs from an internet-direct company - there are a few competitive options out there, but none will match the fit and finish of the Fathoms). Dual subs, properly positioned, solve a lot of difficult room problems, making them easier to correct. I also concur on the size factor - my F112s weigh almost exactly 100lbs a piece, and I'm just able to comfortably carry them. They also seem to fit nicely pretty much anywhere I try to put them.
giogt600 and dean122601 like this.
post #6942 of 6943 Old Today, 05:46 PM
petetherock's Avatar
Quoted: 381 Post(s)
Liked: 129
Can you turn up the sub volume and do the cal? That worked for me.
Also the sonic signature is different, so do have a listen.
As posted, the F115 goes deeper, but loses mid bass.
petetherock is online now
post #6943 of 6943 Old Today, 06:03 PM
dean122601's Avatar
Quoted: 23 Post(s)
I tried that and no luck
