JL Audio Fathom 13" Sub - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 80Likes
Old 03-05-2007, 11:17 AM
John F. Palacio's Avatar
Originally Posted by jmcomp124 View Post
How long are the stock power cords?
6 feet. They are standard OSHA cords so you can change it to fit.
"Information is only as good as the accuracy of the source"
John F. Palacio is offline
Old 03-05-2007, 11:29 AM
jmcomp124's Avatar
Thanks for the power cord info John? Do you know what guage it is (12awg, 14awg??). With 2500 watts it could suck some pretty huge power. Wouldn't each f113 require it's own 20A dedicated circuit? Even with 20A it peaks at 120x20 =2400Watts. I have 2 dedicated 20A circuit outlets but they will be 12 ft away from the subs. I would need 2 power cords that are 12 ft long. Good thick well shielded ones can get expensive.
I have a PS-Audio juice bar with a 10AWG 6ft teflon shielded power cord from b-p-t. Using this I can split the single 20A outlet into several (using the juice bar). The juice bar will be close enough for the stock power cords to reach. But this method would give only 20A x 120v = 2400 watts. Wouldn't this limit the performance of the dual f113s during the most intense bass scenes?
Any thoughts would help.
-Jai
jmcomp124 is offline
Old 03-05-2007, 11:31 AM
RMK!'s Avatar
Quoted: 1618 Post(s)
Liked: 1492
Originally Posted by frockc View Post
i have the gramma which is 23x15 and it fits... but i think i might stop using it... msmith_jl said the ruber feet are there to provide the right amount of dampening...
I agree with Mr. Smith but mine are on carpet over slab. I find the shaking floor is a very desirable effect. I also don't mind a few sympathetic vibrations. The scenes are usually so intense that I don't really notice. I do notice these during sine wave sweeps but I'm not playing those much anymore.
Opinions are not facts.
RMK! is online now
Old 03-05-2007, 11:57 AM
frockc's Avatar
yea for 50 buxs i gave it a shot... i just tried the tripod emerging scene with both the gramma pad and non gramma pad... i like it without although itz not a huge noticable diff either way i like that it feels a little more real with it just on the wood floor...
also in that scene when the tripod emerges and slams down on the car in front of cruise i am pushing the sub pretty hard at like -12~-11MV sub calbrated to 75dB at 0MV i can't tell if itz farting(bottoming out a little) don't know how to describe it... i'm not sure itz not like a really vibrating sound i'm just really unsure if that is just a note playing i'm not used to hearing with my old sub or bottoming out... my living is open to my kitchen and dinning room on my first floor town home and stairs open to the upstairs of the room... my sub is located in the front left corner which seemed to give the best response out of the 4 places i tried... so maybe itz just to much open space....
frockc is offline
Old 03-05-2007, 12:42 PM
RMK!'s Avatar
Liked: 1492
That is very strange. I have played that scene many times with single and now dual F113's and never had anything but a clean BIG boom and shake. Also my space is 8,000cf open to much more, so I don't think open space is the issue.
RMK! is online now
Old 03-05-2007, 12:52 PM
b curry's Avatar
Quoted: 320 Post(s)
Liked: 160
Do you mean detachable IEC-type as OSHA is the Occupational Safety and Health Administration?
b curry is online now
Old 03-05-2007, 12:55 PM
frockc's Avatar
i may just be noticing something now that i didn't notice before... i just might not be used to such detail from a sub... i actually just got off the phone with one of the JL engineers and since i really only notice it from up close next to the sub he thinks it might just be some suspension noise since its such a high excursion sub... it may just be something else rattling in the
i know itz diff not bottoming out because that would be more of a metal sound...
rmk could u try playing the end scene from pulse if u have it... and tell me how that scene sounds when u really push it...
frockc is offline
Old 03-05-2007, 01:01 PM
b curry's Avatar
Quoted: 320 Post(s)
Liked: 160
-Jai
It's a long thread but its been covered before near the front end . The cord is 12 AGW I believe. A single 15A circuit is ok for one. Check post #'s 733 and 745.
Old 03-05-2007, 01:21 PM
jmcomp124's Avatar
Thanks a lot. Answer's clear. If I have 2 20A circuits use both and get longer power cords if need be.
Old 03-05-2007, 01:32 PM
frockc's Avatar
well i replayed the pulse scene and really pushed it... i put it up to -5MV and 0MV and i really think it was bottoming out... it made a kinda of tapping sound very noticable from my listening position... not sure if that is normal because itz just getting pushed to hard or maybe the sub is defective???
frockc is offline
Old 03-05-2007, 01:39 PM
msmith_JL's Avatar
Frockc:
Would you characterize the level at which it is happening as a realistic listening level or are you pushing it to the limits just to see what happens?
If you back the level down by 2 dB does the noise still happen? 1dB?
It is possible to run a Fathom into limits that sound like what you're describing, but I can assure you that the woofer is not bottoming. Bottoming out that driver requires way more power than the f113 has in that enclosure and sounds like a gunshot when it happens (very loud).
msmith_JL is offline
Old 03-05-2007, 02:26 PM
frockc's Avatar
ok well maybe itz not bottoming out... but it just doesn't sound normal... i played it at about -7MV or -8MV and watched the sub... then i pushed it up to about -5MV and the noise starts to happen slightly... by slightly i mean it makes the sound as the cone is traveling kinda at the end not throughout the whole cone travel... when i push it to -3MV or 0MV then itz like the sound happens through out the cone travel...
i was watching the JL symbol and it doesn't seem to be hitting max exursion of 4 inchs during this...
i would normally watch the movie around -10MV... i think i have heard this noise in some other movies but never pushed the sub harder in those movies...
frockc is offline
Old 03-05-2007, 02:35 PM
jmcomp124's Avatar
Can you describe what exactly this noise sounds like? Buzzz, thud, knock??
Old 03-05-2007, 02:37 PM
frockc's Avatar
the noise is just much higher then the low sounds that are coming from the sub... i'd call it a tapping kinda sound... itz constant when up at those higher volumes... i tried it with finding nemo darla sound and that sound really isn't there.... i don't know if itz just the much lower freq of pulse or what... but itz very easy to hear on pulse...
i can just say it doesn't seem normal and itz not there when the volume is a few dbs lower...
frockc is offline
Old 03-05-2007, 02:39 PM
jmcomp124's Avatar
Are there any curtains, loose paper etc around the sub? During the demo, the sub was pushing so much air that a curtain got sucked in front and there was a rapid whirring sound. It was dark so I thought it bottomed out or something for a second and it happened to be the curtain. It could also be something else taking off in the room.
Old 03-05-2007, 02:42 PM
jmcomp124's Avatar
You may want to turn off all your other speakers if you have not already done so. Have another person in the room who can also listen for it and try repeating the test. Try to find out if it is indeed coming from the sub. Moving it away from the primary location will help you identify if the sound also has moved with the sub. If this noise is > 100Hz, you will be able to isolate it.
Old 03-05-2007, 02:45 PM
Yes. They are abreviated to OSHA cords for simplicity.
frockc's Avatar
i'm pretty sure itz coming from the sub... i mean it could almost be the sub distoring... i heard it from my listening position and then when i walk up right next to it i can tell itz coming from the sub... anyone have pulse that could try???
frockc is offline
Old 03-05-2007, 02:52 PM
-Jai
Don't know for sure, but it is heavy. Definetely heavier than 18 ga. Feels like 14ga or even 12ga. You are way overconcerned about the power. Wait till you trip a breaker, then worry.
Old 03-05-2007, 02:57 PM
frockc's Avatar
ok i recorded it on my handheld digital cam... i'm gonna see if i can get it online somehow...
frockc is offline
Old 03-05-2007, 03:17 PM
JPBOSS's Avatar
Went into a high-end store in Appleton Wisconsin this past weekend. Spoke with the manager and he stated he did not have a Fathom in stock but could get one because JL just released that upper-end JL car audio dealers could order them. However returning home to Atlanta today I got a call from my local JL dealer that I buy my car audio from and he also sells and installs home theater lines as well. However he told me that he just got off the phone with his regional JL sales rep that told him he could not order the Fathom for me and told him to have me call another store on the other side of Atlanta to see about purchasing it. I felt kinda bad for my local guy because he had to give me the phone # of a competing store. That's kinda sad if you ask me. In fact it pissed me off so much I immediately called and ordered a Klipsch RT-12d. Granted, I realize that it's not a Fathom f113 but I can do without that extra 5%(if it's even that) of SQ and saved roughly $1500.00. I love JL audio as that is what totally powers my car. (1) JL 10W7 in JL box, JL 500/1 amp, JL 450/4, JL Evolution ZR-650csi components and JL Evolution XR-650cxi rear stage. However, the difficulty and extreme cost in purchasing the home sub has turned me off. I am sure the Fathom's are a force to be reckoned with but this is JL first attempt at the home market and I would think that they would be a little more competively priced and be a little more attainable, especially for their die-hard car audio consumers that will be the first to line up to buy the Fathom's but I am not going to drive 75 miles in some of America's toughest traffic to buy something I could easily drive down to my local store and purchase if it was available.
I am sure it doesn't mean a hill of beans but this was one sale that was lost due to restrictive marketing/sales practices.
JP
JPBOSS is offline
Old 03-05-2007, 03:18 PM
jmcomp124's Avatar
What is your ELF control set to?
Old 03-05-2007, 03:19 PM
frockc's Avatar
-5dB
frockc is offline
Old 03-05-2007, 03:28 PM
frockc's Avatar
i have it as a .mov but itz 27mb... anyone know how to shrink that down??
frockc is offline
Old 03-05-2007, 03:30 PM
jmcomp124's Avatar
Does anyone know what the bandwidth of the ELF control is?
Is the ELF control simply a single band fixed at 25Hz parametric EQ?
Try setting it to "0" and this should make it worse or problem to appear earlier.
Let us know. I am curious about this now.
Old 03-05-2007, 03:44 PM
jmcomp124's Avatar
My f113 is on it's way!! It arrives on Friday. Thanks to all the folks who helped me with the pricing info. It made a huge difference.
Old 03-05-2007, 04:03 PM
frockc's Avatar
ok itz posted on my myspace....
that sound quality isn't great but that is about what i'm hearing...
http://vids.myspace.com/index.cfm?fu...oid=2013075239
here it is as a file figured it out...
test1.zip 305.9658203125k . file
frockc is offline
Old 03-05-2007, 04:36 PM
vinyl's Avatar
Sounds like the amp has turned into a woodpecker.
Most people don't know what they want...but, they're pretty sure they haven't got it. ©
vinyl is offline
Old 03-05-2007, 04:37 PM
frockc's Avatar
so that is diff not normal???
frockc is offline
Old 03-05-2007, 04:44 PM
Richard Mayer's Avatar
That doesn't sound normal. There's definitely something wrong with your sub. I'm sure JL Audio will replace it.
Richard Mayer is offline
