Official SVS Owners/Support Thread. - Page 196 - AVS Forum | Home Theater Discussions And Reviews
 3803Likes
post #5851 of 25662 Old 08-22-2010, 03:10 PM
JAMES MCHUGHES's Avatar
Quoted: 153 Post(s)
Liked: 52
Originally Posted by ransac View Post
I have to dwell on this set up for a while. If you start your own thread, others can help out. You do have what appears to be an incorrect statement with 'From the receiver rear surrounds speaker wire goes into the high level of the sub than speaker wire from low level of sub that goes to my mythos' How did you use speaker wire from the low level outputs?
I tend to stay away from making sub recommendations as it will always start a lot of 'Get this instead, it's better or cheaper' posts.
What I did was ran speaker wire from the rear surrounds connection on back of the receiver and they went to the high level of my SC2. Than ran another speaker wire from the low level of my subwoofer and connecting to my Mythos Gem. Sorry if that sounded a little confusing I almost confused my self trying to type it....lol. And this is what I did for both rear channels SC2 to each mythos which than calibrated them at fullband than changed the crossovers to 40 Hz. Other wise my Mythos were my weakest link in my system and they would always calibrate at 120 or 150 Hz
JAMES MCHUGHES is offline
post #5852 of 25662 Old 08-22-2010, 03:51 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
The low level outputs are RCA connectors and should use coax cable, not speaker wire. I have an endless honey-do list to complete, so post this in your own thread and others can straighten this out with you. People with similar setups as yours should also chime in.
Randy
ransac is offline
post #5853 of 25662 Old 08-22-2010, 04:01 PM
Quoted: 153 Post(s)
Liked: 52
Ransac
I just sent you a private message....
post #5854 of 25662 Old 08-22-2010, 08:59 PM
ParadigmDawg's Avatar
Originally Posted by pepar View Post
This will depend entirely on your room and the placement of the subs. The AS-EQ1 is intended to integrate two (or three or four) subs into a room, or to correct one sub in a difficult room. An important feature that enables it to do that is that it can set two different sub distances.
I'm sure that it would improve your system. Whether you need it or not is sort of up to you. As you probably know, SV Sound has a 45-day return policy.
Jeff
Thanks pepar,
I got the 2nd sub on Friday and man...do I love it. My wife named them Zeus and Poseidon.
I will likely give the AS-EQ1 a try, if it gets better than it is now, it will be crazy but as you can see below, I have a difficult room and the distance from the LP is about 4 ft off.
ParadigmDawg is offline
post #5855 of 25662 Old 08-23-2010, 11:09 AM
Juan's Avatar
Well, just ordered my PB12-Plus and can't wait. Now to find something to fill the space my Samson 1000 and Art 351 EQ is taking up in the credenza with some other new toy.
Juan
My HT
Juan is offline
post #5856 of 25662 Old 08-23-2010, 05:56 PM
ferrari fan's Avatar
Quoted: 18 Post(s)
Congrats on the PB12-Plus Juan. I've had mine for 3 weeks and love it. That extra space you want to fill ? How about an amp ? Specifically the
Emotive XPA-3. It will easily power your fronts and center, while your reciever can power the surrounds.
http://emotiva.com/xpa3.shtm
ferrari fan is offline
post #5857 of 25662 Old 08-24-2010, 09:22 AM
Juan's Avatar
I will probably stick with using the amps in my Pio SC-05, but I think you just gave me an idea. I think I am going to get a two channel amp to put in there and use it for the 3rd zone.
Juan
My HT
Juan is offline
post #5858 of 25662 Old 08-26-2010, 03:12 PM
vincent_y79's Avatar
Hi All,
New to the forum and I hope I'm in the right thread for requesting opinions on getting a set of SVS speakers. I recently purchased an Onkyo tx-nr808 and was considering matching that to some S series speakers (STS, SCS and SBS) and I'm still deciding between the PB12 and PC12.
Well anyway, my question is the 808 a good match to the S series?...or perhaps I should consider other speakers.
vincent_y79 is offline
post #5859 of 25662 Old 08-26-2010, 03:32 PM
mojomike's Avatar
Liked: 30
Hi Vincent. A better place to discuss the main speakers is the speaker forum. As far as your sub decision, the performance of the PB and the PC are very similar. Choose based on which form you find more esthetic or which fits your room better.
mojomike is offline
post #5860 of 25662 Old 08-26-2010, 03:47 PM
Thanks for the subwoofer tip between the PC and PB.
I just wasn't able to find an official SVS speaker thread there without going to specific models. I'll go and check it out there
post #5861 of 25662 Old 08-26-2010, 07:09 PM
Quoted: 18 Post(s)
Vincent....also go to this forum specifically for SVS speakers.
http://forum.blu-ray.com/speakers/98...rs-thread.html
post #5862 of 25662 Old 08-30-2010, 06:43 PM
dunkman23's Avatar
So my sub came in today. The low bass is definitely there. However the thump/ punch isnt there. My room is about 1700 cubic feet.
And Im using a Pioneer VSX-21txh, if it matters.
Is this sub just have the low bass? I can hear it throughout the house also. But I just cant feel it.
Any recommendations if I am doing something wrong?
o yea, and the subwoofer is in the left hand corner of the room.
dunkman23 is offline
post #5863 of 25662 Old 08-30-2010, 06:53 PM
mojomike's Avatar
Liked: 30
Start by moving it out of the corner. It's sounds as though you are getting too much room gain emphasis of the deeper bass and it is overwhelming the mod-bass where the punch comes from.
mojomike is offline
post #5864 of 25662 Old 08-30-2010, 08:14 PM
dunkman23's Avatar
thanks how far away from the corner should it be?
also, is it better putting the sub at the corner? or at the front ?
post #5865 of 25662 Old 08-30-2010, 08:29 PM
TheFactor's Avatar
Liked: 106
Since its not working good were its at I would first try moving it a few feet if possible forward and if you dont get good results then I would move it to your front stage thats were I put my subs and there even off center and its a sweet spot for my room . Just keep trying different areas especially since your sub is light enough to move around and you'll find the sweet spot. Also you could try doing the good old bass crawl
TheFactor is offline
post #5866 of 25662 Old 08-30-2010, 08:30 PM
mojomike's Avatar
Liked: 30
All rooms are different and finding the best location for the sub is a system of trial-and-error. Also, you can try the crawl for bass technique. Place the sub at you seating area, then crawl around the room to find where the bass sounds best. Then put the sub in that spot where the bass sounded best, and voila, it should now sound very similar at your seating area. Sometimes you may also have to experiment with the crossover, the phase, and the levels. If all else fails, you then need to measure the frequency response and you might have to resort to EQ. Actually, almost all setups can benefit from bass EQ.
mojomike is offline
post #5867 of 25662 Old 08-30-2010, 09:29 PM
dunkman23's Avatar
where can i find an affordable Subwoofer EQ?
post #5868 of 25662 Old 08-30-2010, 10:33 PM
mojomike's Avatar
Liked: 30
The most sophisticated low-priced EQ unit is the Behringer Feedback Destroyer Pro DSP 1124P. They sell new for under $100, but can be bought for less.
mojomike is offline
post #5869 of 25662 Old 08-31-2010, 01:58 PM
dunkman23's Avatar
If i do purchase the Behringer 1124p, what additional wires do I need to hook up to my receiver and subwoofer?
Im assuming the Behringer does not use RCA cables?
post #5870 of 25662 Old 08-31-2010, 02:11 PM
mojomike's Avatar
Liked: 30
You can use an RCA-to-1/4" jack converter.
mojomike is offline
post #5871 of 25662 Old 08-31-2010, 03:06 PM
dunkman23's Avatar
ok thanks. Im assuming i need 2 of them. Receiver to EQ, EQ to Subwoofer.
I did some googling earlier. What are the XLR plugs people are talking about for the Behringers? do these work also? is the quality much better?
Im assuming its RCA to XLR?
post #5872 of 25662 Old 08-31-2010, 08:34 PM
This is what I always used.
http://www.zzounds.com/item--ARTDTI
post #5873 of 25662 Old 09-01-2010, 09:22 PM
Juan's Avatar
Man, this PB12-Plus is is one heavy beast, and looks bigger than I thought even though I measured. I thought it would be too big when I set it up, but my wife likes it better the the cylinder and thinks it is fine.
Juan
My HT
Juan is offline
post #5874 of 25662 Old 09-01-2010, 09:33 PM
TheFactor's Avatar
Liked: 106
Congrats your going to real enjoy it and yes they are big !
post #5875 of 25662 Old 09-02-2010, 09:40 AM
Juan's Avatar
Thanks, and I am already enjoying it. Thinking about getting an Antimode to add to it and see what difference it makes.
Juan
My HT
Juan is offline
post #5876 of 25662 Old 09-04-2010, 08:54 AM
Quoted: 153 Post(s)
Liked: 52
I just bought a used PB12-NSD subwoofer but the guy forget to put the power cord in the box when shipped. Is there a certain power cord I need to use for my sub ?
post #5877 of 25662 Old 09-04-2010, 09:26 AM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
I needed a longer power cord for my PB-12 Plus and this is what SVS recommended I purchase:
http://www.americord.com/catalogsear...1134&x=28&y=13
I bought a 15ft. one and have not had any issues whatsoever.
Mathematics is the reason for the season.
Nickff is offline
post #5878 of 25662 Old 09-04-2010, 09:43 AM
Quoted: 153 Post(s)
Liked: 52
Thanks Nick
Yes this looks like the same kind of cord im using but just shorter and is long enough.
I actually have mine plugged into my Panamax 5100 power and conditioner im assuming thats fine
post #5879 of 25662 Old 09-04-2010, 12:56 PM
Nickff's Avatar
Quoted: 277 Post(s)
Liked: 169
Thanks Nick
My sub isn't close enough to my APC unit, so I just have it plugged into a Tripplite surge protector. I don't see a reason there would be an issue being plugged into your Panamax. If it is also an UPS unit, then just make sure the power draw isn't too much.
Nickff is offline
post #5880 of 25662 Old 09-04-2010, 01:19 PM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
My 6 subs are plugged in to 5 differing 600s Richard Gray power conditioners (along with my other equipment) in the 'star configuration RG recommends'. They are fed with 2 separate 20A lines.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
