Official SVS Owners/Support Thread. - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4118Likes
post #91 of 26124 Old 09-23-2006, 07:00 AM
darthbrooklyn's Avatar
Thanks for the advice guys.. Going to try spinning it with some low Hz sweeps this afternoon after the wife leaves.. He he
darthbrooklyn is offline
post #92 of 26124 Old 09-23-2006, 07:24 AM
WolfsBane's Avatar
If you have pets, make sure they are not in the room. They seem to hate the high level tone sweeps for the subs.
Welcome... to the house of Rock and Jazz !
WolfsBane is offline
post #93 of 26124 Old 09-23-2006, 08:50 AM - Thread Starter
Big Bri's Avatar
Just did a routine calibration of my speaker levels, and found that I had to knock my LFE pre-out on my AVR down from -3.0 db to -5.0 db. My PB Plus/2 has been up and running a couple months now. I initially set it up to run about 5.0 db hot over the rest of my speakers, and I guess over the last couple months its broken in quite a bit. Just an FYI for those of you who haven't calibrated in a while. I expected it to brake in, just not that significantly.
Strong men also cry.
Big Bri is offline
post #94 of 26124 Old 09-23-2006, 02:19 PM
r:o:b's Avatar
i actually called svs asking about brake in period. THey told me there isnt one, just to run the sub a little quiter than normal untill you get adjusted to it...
r:o:b is offline
post #95 of 26124 Old 09-23-2006, 03:11 PM
gmoney80's Avatar
i love my 20-39 pci fantastic value, best subs in the business, but now looking for bigger and deeper i will probably buy and ultra. can't wait to try one of those bad boys out
Xbox One GAMERTAG:trickygmoney80
gmoney80 is offline
post #96 of 26124 Old 09-23-2006, 04:02 PM
tvsurfer's Avatar
I have one of those Kill-A-Watt deals to measure power consumption and measured my SVS sub at 18 watts a normal levels and ~26 watts at full tilt reference levels...double-checked it even. I thought something was wrong with the meter, but my receiver was pulling 76-125 watts, my PC 150 watts at idle, Sony laptop - 47 watts so I think the meter is ok. Could the SVS be this efficient?
tvsurfer is offline
post #97 of 26124 Old 09-23-2006, 04:21 PM
cschang's Avatar
Quoted: 130 Post(s)
Liked: 167
what kind of material was playing through the sub when you took the measurements?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #98 of 26124 Old 09-23-2006, 04:41 PM
Buckeyefan's Avatar
Quoted: 14 Post(s)
Keep in mind, that meter is reading consumption, and not amplifier output. Also keep in mind that is a class D amp, which doesn't generate a lot of heat. They run 90% efficient, where a class A/B amp as in your receiver is roughly 50% efficient.
A large, ported box should be extremely efficient, espeically with a BASH amp.
Try your meter on a hair dryer on high, an iron heated up, and toaster oven heated up. Also try it on a simple lamp with a 100 watt bulb.
Report back if you don't mind.
A man meets a genie. The genie tells him he can ask for whatever he wants, but his mother-in-law gets double of what he gets. The man says give me a million dollars and beat me till I'm half dead.
Buckeyefan is offline
post #99 of 26124 Old 09-23-2006, 08:01 PM
tvsurfer's Avatar
I played Tupac Shakur "Hail Mary" lots of ~20Hz bass. I totally forgot about the benefits of a BASH amp so I guess these result really aren't a surprise.
Those are all good suggestions to test, but I borrowed the Kill-A-Watt from a buddy and already gave it back so no more testing. The box did say 0.2% accuracy. I tried it on my brother's color laser printer while printing: 850 watts max. My 50" LG plasma takes 49 watts turned off (!) and 450 watts while on.
tvsurfer is offline
post #100 of 26124 Old 09-23-2006, 08:06 PM
Kipp Jones's Avatar
Its not watts you want to be concerned about, its amps that you want to pay attention to.
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #101 of 26124 Old 09-23-2006, 08:06 PM
hdmi4ever's Avatar
Quoted: 18 Post(s)
No matter how efficient the amp is, it can't output more power than it takes in!
hdmi4ever is offline
post #102 of 26124 Old 09-23-2006, 09:31 PM
Kipp Jones's Avatar
PB2+ owner here. Just upgraded my drivers to the 12.3, wow!!! If you have not upgraded, go for it....Art????????????
Here is my gear.
Kipp
post #103 of 26124 Old 09-23-2006, 11:09 PM
DrPainMD's Avatar
Liked: 27
the little trash can .... is that the pci model?
super dirty , super clean , pow
DrPainMD is offline
post #104 of 26124 Old 09-23-2006, 11:37 PM
Kipp Jones's Avatar
LOL, its for the fireplace ashes.
Kipp
post #105 of 26124 Old 09-24-2006, 06:20 AM
hdmi4ever's Avatar
Quoted: 18 Post(s)
Upon further reading, it seems the low wattage used by your subwoofer (and receiver) at reference levels is probably accurate and is due to the exponential nature of sound. With sound, the power has an exponential relationship to the perceived volume, such that the difference between 2 watts and 20 watts is perceived as the same as 20 watts vs. 200 watts.
Maybe your system only has capacity for a 20% increase in perceived volume before you max it, but that last 20% would require a multiple of the power that you were using at reference levels.
post #106 of 26124 Old 09-24-2006, 06:39 AM
DrPainMD's Avatar
Liked: 27
There's a store near me which sells fireplace equipment, and they have a sign outside and it says "We Kick Ash".
DrPainMD is offline
post #107 of 26124 Old 09-24-2006, 09:28 AM
Pradeep's Avatar
I was thinking more of a chunder bucket
Pradeep is offline
post #108 of 26124 Old 09-24-2006, 10:45 AM
tvsurfer's Avatar
I probably could have turned it up louder, but it was already rattling the walls. The 20x14 room gave out before the sub (corner loaded) so maybe I wasn't maxing it out as I thought, explaining the low consumption. I just bought a kill-a-watt of my own from ebay so now I can test at my own pace.
tvsurfer is offline
post #109 of 26124 Old 09-24-2006, 11:14 AM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
What you are reading is the RMS wattage use. Since an audio signal, especially to a sub, is more not there than it is there, your average power useage is very low. If you want to see how much it can draw, run a 20Hz sine wave at full volume. Then you should see power consumption close to the full capability of the amp
Randy
ransac is offline
post #110 of 26124 Old 09-24-2006, 11:49 AM
ThomasV555's Avatar
Here is my gear.
Kipp,
That sub blends in very nicely. No wires either, near-field well done.
Do you use it as an end-table for drinks and stuff?
This bloody Redcoat said I was a terrorist.
Somewhere along the way I become an Elitist who looks down on the
cheap bastards who call themselves my AV Hobbyist peers.
I am not prepared.
ThomasV555 is offline
post #111 of 26124 Old 09-24-2006, 12:07 PM
billybob_jcv's Avatar
Kipp, I noticed you have your center on the floor under your screen. How's the vocals from that set-up?
If you think this post was dumb, you really should read my blog=> http://bumpedhishead.blogspot.com/
billybob_jcv is offline
post #112 of 26124 Old 09-24-2006, 02:33 PM
Kipp Jones's Avatar
Originally Posted by ThomasV555 View Post
Kipp,
Thanks. My goal was an uncluttered appearance. I do not use it for anything other than a sub. It hides nice behind the couch considering its size.
Kipp
post #113 of 26124 Old 09-24-2006, 02:35 PM
Kipp Jones's Avatar
Actually very well. That is a Klipsch RC-7. I actually plan on mounting it to the wall but have been too busy to get to that. Soon.
Kipp
post #114 of 26124 Old 09-24-2006, 11:05 PM
BTT917's Avatar
Wouldn't they be directly related, as long as the comparisons are done at the same voltage?
BTT917 is offline
post #115 of 26124 Old 09-25-2006, 12:11 PM
ameyers's Avatar
Here is my gear.
How does SVS handle the upgrade and how much is it? Thanks for the info!
ameyers is offline
post #116 of 26124 Old 09-25-2006, 12:18 PM
jvgillow's Avatar
It's $169 per woofer, and you have to switch out the drivers yourself. All you should need is a drill with a philips screwdriver bit, or even a hand screwdriver if you are very patient.
Jeremy Gillow
jvgillow is offline
post #117 of 26124 Old 09-25-2006, 12:40 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
I don't know if they still do, but in the beginning, SVS even provided the bit.
Randy
ransac is offline
post #118 of 26124 Old 09-25-2006, 12:41 PM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 38
Well ladies...it's official...the Ultra is gone!!
Ok, time to look into a replacement!!! will the following contenders please rise:
muahahahahhahahahahah
MUAHAHAHAHAHAHAHHAHAHAHHAHHA
ps- see that little nice SVS sign on the wall? person with the biggest bid gets it!! LOL
ssabripo is offline
post #119 of 26124 Old 09-25-2006, 12:48 PM
jvgillow's Avatar
A dark shadow falls over Shervin's theater room as he laughs with diabolical insanity. The walls shake with fierce intensity as the SVS placard in the background falls to the ground.
Jeremy Gillow
jvgillow is offline
post #120 of 26124 Old 09-25-2006, 12:53 PM
ssabripo's Avatar
Quoted: 66 Post(s)
Liked: 38
"...run biatches, run!!!"
ssabripo is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
