Official SVS Owners/Support Thread. - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 3803Likes
Old 03-29-2007, 01:17 PM
swerveddy's Avatar
Originally Posted by javry View Post
So which movie did you watch first?
I tested "Flight of the pheonix" from the sandstorm chapter.
The previous reigning giant of LFE was Titan A.E. followed by WotW (imo).
When I didnt even have the gain turned up past 1/3 and overall volume wasn't too loud n the woofer looked to be at its limits (no portnoise or audible artifacts to report though) and fairly strong output.
For those who can pick this dvd up in the bargain bin, i would suggest it, great demo material.
swerveddy is offline
Old 03-30-2007, 04:32 AM
slowfaller's Avatar
I just pulled the trigger on a pb10-nsd. I was at barretts home theater and listened to the klipsch rw12d and although it was nice it's $699. I then went to my brother's house and listened to his pb10-isd. For the money I'm sold on SVS. I'm excited as this is replacing a dayton sub-120.
I'll have to let you know how my switch-a-roo goes. My wedding is 2 months away and my fiancee hasn't been too happy that i've been looking at subs so i'm going to switch it out and not tell her. If she doesn't notice by sight hopefully she'll notice when we watch a movie and she feels it. hehehe
Chris.
slowfaller is offline
Old 03-30-2007, 10:08 AM
Bailman's Avatar
What would be the signs/symptoms in dual not co-located PB12/+2's?
Bailman is offline
Old 03-30-2007, 10:10 AM
bgillyjcu's Avatar
Drop in normal SPL would be the first thing I'd think of.....get out the SPL meter and compare the numbers with what you used to get...
Twitter @ Clefoodandbrews
bgillyjcu is offline
Old 03-30-2007, 10:22 AM
mojomike's Avatar
Liked: 30
Turn of the main speakers and just listen to the subs. Listen for any bad sounds.
mojomike is offline
Old 04-04-2007, 11:51 PM
jvgillow's Avatar
Anybody feeding a PB10 off a sound card sub/LFE output? I've got an Audigy2 that's going to be driving a 2.1 system just attempting to narrow down what my sub potentials are going to be. I _think_ that the Creative cards do a decent job of handling subwoofer crossover but I've never verified that.
Jeremy Gillow
jvgillow is offline
Old 04-05-2007, 12:35 AM
fretman4god's Avatar
The audigy2's do a great job with bass. I loved my desktop for that reason. Killer response from a computer soundcard. You'll love it.
Bass IS the best...
fretman4god is offline
Old 04-12-2007, 07:30 PM
ghotihead's Avatar
Just pulled the trigger on a PB12-NSD/2 to go along with the Rocket 850s, 200 and 300s I ordered yesterday. Guess how excited I am?!
ghotihead is offline
Old 04-12-2007, 07:35 PM
jhan1000's Avatar
Schwing!!!
Life is good.
jhan1000 is offline
Old 04-12-2007, 07:43 PM
DrPainMD's Avatar
not very?
super dirty , super clean , pow
DrPainMD is offline
Old 04-14-2007, 09:20 PM
wagsgt's Avatar
Hello would you think the SVS PB12-NSD/2 would be too much for my room?
Room is 11X19 and is in the bottom floor of a townhouse.
wagsgt is offline
Old 04-16-2007, 01:07 PM
Hiroyuki Sakai's Avatar
I'm going to get my PB10 replacement woofer/3.0 set svs bookie tomorrow due to cosmetic issues on the cone of the driver and decided to pull the driver now and take a snapshot of the woofer,amp and enclosure. Just to reduce the hassle tomorrow and get it shipped asap.
Whomever raises their hand against the water lords, Loses that hand. Vaska "The Witcher"
Hiroyuki Sakai is offline
Old 04-16-2007, 01:09 PM
continue...........
The woofer was heavily built and freakin heavy. I pulled the driver on the 1st PB10 to re-seat the wires to the conectors and man was it a pain to get it back and screwed to the enclosure.
Old 04-16-2007, 02:16 PM
Patdeisa's Avatar
Bassheads will say there is no thing as too much...
I've got a PB10 in a room about that size (open to the rest of the bottom floor of a townhouse). Within the room, I've gotten up to 105 dBs (at listening position, ref - 6dB for the sub) on the Darla scene in Finding Nemo, which is more than enough for me. If you like things loud, I think a PB12 alone would do the trick, but it depends on how low and loud you want to go (and how much insulation is between you and your neighbor).
Patdeisa is offline
Old 04-16-2007, 03:46 PM
wagsgt's Avatar
I like alot of bass but I was thinking NSD/2 might just be too much for that room since its in a townhouse. I saw a practically brand new NSD/2 for similar price as the PB12 but it looks like it will just be too much. Thanks
wagsgt is offline
Old 04-16-2007, 04:32 PM
Patdeisa's Avatar
For the same price, then by all means go for it. It'll be nice to have if you ever get a larger place. I didn't want to convince you that you shouldn't get it, just that you may not need all of it.
Patdeisa is offline
Old 04-18-2007, 02:16 PM
cbesper's Avatar
wagsgt, I recently purchased the SVS PB12-NSD/2 (about 2 months ago). I put it in my basement home theater which has a 7ft drop ceiling and is approximately 23ft x 18 ft (drywall walls). I like to watch movies loud too. This bass has absolutely no problem filling the room (the sub volume is at about 50% too). I'm sitting on solid concrete and I can FEEL the bass. When I'm upstairs the bass shakes the windows. It has no problem recreating that heavy bass that is typically only experienced in theaters... a real treat. I LOVE this sub woofer but I suspect that it would be overkill by most peoples standards/needs. Keep in mind that this is also a huge/heavy sub as well. Personally, I have not heard the PB12 so I can't comment there, but I will say that I probably could have been just as happy with something a little less powerful... that's me though. Regardless... I have no regrets !!!!!Good luck!
cbesper is offline
Old 04-19-2007, 03:14 PM
halo0's Avatar
I'm wondering if anyone in here has any opinions/experience with the difference between the regular cylinder series subs and the plus series. Specifically the 20-39 models. The PCi is $600 and the PC-Plus is $900. Is the plus really worth that 50% more?
halo0 is offline
Old 04-19-2007, 05:44 PM
Macfan424's Avatar
I'd say it depends on the size of your room and how loud you want your sub to play.
I haven't had both cylinders, but I do have a PC+ and a PB12. SVS says their boxes and cylindars sound alike. They certainly sound very much alike to me 99% of the time, but my 16-46PC-Plus plays deeper and a bit louder if pushed to its limits.
The Plus series has a more powerful amplifier and a more robust driver. It also has variable tuning points. All this translates into very worthwhile benefits to demanding users, but may not be worth the price difference to many others, especially those with average sized rooms and moderate listening habits.
Email SVS to get a definitive answer. They know their products better than we do. Tell them your room size, placement options and listening preferences. My experience has been that they are very helpful and honest.
Macfan424 is offline
Old 04-19-2007, 06:17 PM
halo0's Avatar
Let's just assume that I'm of the mind that you can never have too much output or extension. I'm more interested in the concept of whether, in any given room size, the plus is worth 50% more dollars than the PCi. I happen to have a large room now, but I may be moving soon and I'm not sure what my new place will be like. It's very hard to come to a conclusion on this question, based on the info provided on the SVS site, as they don't seem to list max SPL numbers anywhere. Freq response graphs are nice, but they don't tell the whole story.
Maybe thinking of it this way would be better. What if I had an essentially infinite space to fill? Would I be better off buying n*2 PC-Plus cylinders, or n*3 PCi's for the same price?
halo0 is offline
Old 04-19-2007, 06:42 PM
gvg45's Avatar
I would wait and get 2 new PC Ultras!
gvg45 is offline
Old 04-19-2007, 06:44 PM
Macfan424's Avatar
I'd say 2 PC-Pluses.
In fact, given everything you just said, I'd recommend you invest in a Plus and not look back. People rarely regret buying something better than they need, but frequently wish they'd spent a little more when something falls short.
As for SPL, from what I've gleaned, the Plus is likely to give you 3-6dB more output than a comparable PCi. That translates directly into 50-100% more acoustical power, since, theoretically, two co-located identical subs will produce 6dB more output.
Unfortunately, it seems to be hard to get comparative data from a reliable independent source using the same testing criteria for both. And both have new, improved drivers, so older tests aren't definitive either.
Old 04-19-2007, 06:45 PM
ribbit's Avatar
his question would still apply ...
2 new ultras?
3 PC pluses?
5-6 PCi's?
Mike C
MKC International
SVSound Philippine Dealer
ribbit is offline
Old 04-19-2007, 06:46 PM
Macfan424's Avatar
Well, yes, that even a better option if you're not in a hurry and cost isn't a detriment.
Old 04-19-2007, 06:49 PM
halo0's Avatar
2 new ultras?
3 PC pluses?
5-6 PCi's?
Exactly. I guess what I really want to know is sort of a decibels per dollar number Which is the best value? Most grocery store shelf tags tell me cents per ounce, why shouldn't I expect the same from my subwoofer purchase?
halo0 is offline
Old 04-19-2007, 06:50 PM
Macfan424's Avatar
And the answer is likely to remain, fewer of the better version is probably going to yield better results... but not by an earthshaking ( ) margin.
Old 04-19-2007, 06:51 PM
madpoet's Avatar
I have 2 of the original CS Ultras. Amazing speakers, even if I am selling them
Someday maybe I'll actually WATCH my projector...
madpoet is offline
halo0's Avatar
That is a good point.
May I ask where you gleaned this info?
halo0 is offline
Macfan424's Avatar
... Most grocery store shelf tags tell me cents per ounce, why shouldn't I expect the same from my subwoofer purchase?
Good luck with that!
Old 04-19-2007, 06:56 PM
ribbit's Avatar
haloo, it's easier to get $/SPL ... but $/SQ cannot be measured, it is up to your ears actually.
Mike C
MKC International
ribbit is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
