Official SVS Owners/Support Thread. - Page 582 - AVS Forum | Home Theater Discussions And Reviews
 4082Likes
post #17431 of 26056 Old 07-30-2014, 04:30 AM
JewDaddy's Avatar
Quoted: 184 Post(s)
Liked: 92
Originally Posted by retro124 View Post
yes sealed mode means all 3 ports sealed with foam cap and before you play it change on Sub amp from 16hz to sealed mode!!!! Mode ca be 20Hz, 16Hz or sealed on sub amp). Then rerun Audysey if you have AVR able to do it and you are ready to play in sealed mode!!!
Thanks for the help Retro. I prefer the new sealed mode sound and it's closer to what I'm looking for. I do have a few questions I'm hoping either you or someone else on this thread can help with. I have a 7.1 surround setup and I ran the MCACC on my Pioneer Elite SC-75 Receiver, which is their version of Audyssey. When it was finished, it had my Fronts and Center set to Large, with my Rears and Surrounds set to small. I've ran this before with the PB-12 Ultra and it always sets my fronts and center to large. I've always changed it back to small. Is this correct?? My Center is an AXIOM Audio VP-150 and my Towers are Axiom Audio M60's. Also, I have my speakers set to 100HZ. That's where the calibration put them. Not sure if that should be changed either.
Now there's some options I'm not exactly sure about and would like to get an opinion on where I should set them with my current setup. One of the options it gives me right before running the calibration is whether or not my speakers are THX. It says, "THX Speaker" and I can choose on or off. I kept it at off because I'm not sure if they are and what exactly that would do. The other setting I wasn't sure of deals with the subwoofer. There's an option after the calibration called "THX Select 2 SW" which is set to yes. Should I have the PB-12 set for THX Select 2? Whether I should or shouldn't, what exactly do I gain or lose from this. Thanks for the help!
JewDaddy is offline
post #17432 of 26056 Old 07-30-2014, 12:00 PM
cableguy301's Avatar
Quoted: 75 Post(s)
Liked: 64
Noah.. on blue ray disc .. watched it last night Wow.. awesome bass track and lots of them....
added bonus great movie as well..
I think a new standard for testing out your subs for movies
enjoy the show
cableguy301 is offline
post #17433 of 26056 Old 07-30-2014, 12:20 PM
Horace Clark's Avatar
Quoted: 23 Post(s)
Yes. I agree. The SB13-Ultra performed very well.
Horace Clark is online now
post #17434 of 26056 Old 07-30-2014, 12:58 PM
cchunter's Avatar
Quoted: 513 Post(s)
Liked: 793
I also watched Noah last night. The bass was Wow!! SB13 performed flawlessly. Some very bass heavy scenes to say the least. Main volume was at -10.
5.1 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RB-75's Cherry, RC-64II, RS-52's Cherry
SVS Dual SB13 Ultra's
Oppo UDP-203 Sony PS4 Panamax 5300PM
cchunter is offline
post #17435 of 26056 Old 07-30-2014, 03:08 PM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
Had a movie going and decided to run into the kitchen and skip the previews. Whole place started vibrating I was like . I ran back to the TV to find it was the Noah preview. Watched the preview 3 times. Can't wait to get my hand on the movie. Impressive.
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
post #17436 of 26056 Old 07-30-2014, 03:42 PM
retro124's Avatar
Quoted: 1137 Post(s)
Liked: 881
All receivers automatically set up front speakers as large some people like it like this but since you have very nice sub I will change them to small. I did it to all my speakers and all are set to 80Hz for now. I need to play with it little more but 80Hz is good start point. Well if your speakers have THX label I will turn it ON if not leave it off. I just don't know what to tell you about "THX Select 2 SW" try Pioneer forum I never owned Pioneer AVR and on Denon X4000 what you do is choice if you have 1 or 2 subs and all is done by Audysey.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is offline
post #17437 of 26056 Old 07-30-2014, 04:39 PM
eljr's Avatar
Quoted: 1066 Post(s)
Liked: 8062
must be that fire and brimstone stuff
tomrowe125 likes this.
eljr is offline
post #17438 of 26056 Old 07-30-2014, 07:05 PM
JewDaddy's Avatar
Quoted: 184 Post(s)
Liked: 92
Thanks. I'll try 80hz to see if there's a difference. I asked about that on the Pioneer forums but no answer yet. I'll just keep it on for now. Lastly, I've never adjusted the phase on the sub. Pretty sure its at 0. Should that be something I adjust??
JewDaddy is offline
post #17439 of 26056 Old 07-30-2014, 07:12 PM
retro124's Avatar
Liked: 881
I will leave it like it was. Only what you can do if you want to have more bass when your system is completely calibrated you can adjust volume on sub or on receiver for sub little more then set up is, some people like me like it little more hot then Audysey or your system will set it up.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
retro124 is offline
post #17440 of 26056 Old 07-30-2014, 07:14 PM
JewDaddy's Avatar
Quoted: 184 Post(s)
Liked: 92
I turned the volume directly on the sub itself up four notches after the calibration was finished
JewDaddy is offline
post #17441 of 26056 Old 07-30-2014, 07:20 PM
retro124's Avatar
Liked: 881
when I calibrated my PC12-Pluses my AVR set them up -18db so a raise volume on each 3db up so now I'm -15db on both, I called before SVS and asked them what I can do and they said this is what will work great and it does.
I have both set up for 16hz.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
retro124 is offline
post #17442 of 26056 Old 07-30-2014, 07:24 PM
Kini62's Avatar
Quoted: 1549 Post(s)
Liked: 1400
According to Audyssey users that will screw up the calibration/equalization.
You need to set the sub gain so that Audyssey comes back with a result of around -5db or so, then if you want more bass raise the output in the AVR, NOT on the sub.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #17443 of 26056 Old 07-30-2014, 07:29 PM
retro124's Avatar
Liked: 881
Oh really, many people told me it is doesn't mater it is just easier do it with remote on AVR then on sub.
I did not know if you do it on sub it will screw up calibration.
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
retro124 is offline
post #17444 of 26056 Old 07-30-2014, 07:45 PM
Batman61405's Avatar
Quoted: 171 Post(s)
Liked: 137
This thing is a beast!
Polk CS20
Polk Tsi 500's
Polk Tsi 200's
Denon 1713
Samsung 37'' LCD
Panasonic DMP-BDT 210
SVS PB-2000
Auralex Great Gramma/MoPAD
Logitech Harmony One
Batman61405 is offline
post #17445 of 26056 Old 07-30-2014, 08:06 PM
joseph10704's Avatar
Quoted: 258 Post(s)
Liked: 99
Originally Posted by Batman61405 View Post
I commented on you video.But you did not comment back.I have to ask what film's have you watched so far and what is your thought's about this subwoofer.I cant wait to get mine soon.But it would be nice to know your thought's.
joseph10704 is offline
post #17446 of 26056 Old 07-30-2014, 08:18 PM
Quoted: 171 Post(s)
Liked: 137
Apologies for not commenting back. My review will be up sometime tomm. Stay tuned.
joseph10704 likes this.
Polk CS20
Polk Tsi 500's
Polk Tsi 200's
Denon 1713
Samsung 37'' LCD
SVS PB-2000
post #17447 of 26056 Old 07-30-2014, 08:19 PM
JewDaddy's Avatar
Quoted: 184 Post(s)
Liked: 92
When I called SVS about the initial startup, the guy I spoke with said its better to have the volume higher on the sub itself rather than the AVR. For example, He recommended that if my sub was at -12db and after calibration the AVR had the sub at -10, to go ahead and turn the sub volume up and then counteract it on the AVR. Not sure if that makes sense
JewDaddy is offline
post #17448 of 26056 Old 07-31-2014, 11:29 AM
Chopin_Guy's Avatar
Quoted: 102 Post(s)
Well after spending more time with my SB13 lot's of listening with material I know well, I will be sending it back to SVS for a PB13. I was holding out hope it would provide a satisfying experience in my large room, but it's lacking in the lower octave. This is certainly no knock against the SB13 -- I knew I was taking a gamble with SB13 given my room is 6,200ft^3. This is a wonderfully powerful, articulate, and dynamic subwoofer -- and should be considered by anyone who has the appropriate room or listening habits. However, in my large space it's an unbalanced presentation as above 50hz the SB13 is great -- below 50hz everything simply gets lost in my room.
Owned a rosenut BASH PB13 years ago -- will look forward to seeing the difference the PB13 will make -- especially in the movie department...
Music is enough for a lifetime, but a lifetime is not enough for music.
--Sergei Rachmaninov
Time is a great teacher, but unfortunately it kills all its pupils.
--Hector Berlioz
Chopin_Guy is offline
post #17449 of 26056 Old 07-31-2014, 11:29 AM
Chopin_Guy's Avatar
Quoted: 102 Post(s)
--Hector Berlioz
post #17450 of 26056 Old 07-31-2014, 01:09 PM
Kini62's Avatar
Liked: 1400
The proper way to do what your describing is to up the gain on the sub and then RERUN Audyssey. You may need to do this several times until Audyssey sets the sub channel at around -5db or so.
Then if desired up the sub trim level on the AVR to add more bass if needed.
Def Tech SC8000
Kini62 is offline
post #17451 of 26056 Old 08-01-2014, 01:58 AM
Bond 007's Avatar
Quoted: 2513 Post(s)
Liked: 1988
This approach is not "the proper way" and should not be posted as gospel. It is fine to do it that way but many people also think its fine to adjust the sub volume at the sub after running the room correction software in the AVR. Preferable even.
TomC1315 likes this.
Bond 007 is online now
post #17452 of 26056 Old 08-01-2014, 04:48 AM
cchunter's Avatar
Quoted: 513 Post(s)
Liked: 793
Hmm ok so first you say it's not the proper way then turn around and say it is fine to do it that way?
5.1 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #17453 of 26056 Old 08-01-2014, 04:54 AM
Bond 007's Avatar
Liked: 1988
"Proper" as in the ONLY correct suggested way. It would suggest that any other way would be "improper".
post #17454 of 26056 Old 08-01-2014, 05:33 AM
retro124's Avatar
Liked: 881
Yesterday I talked about setting and adjust sub volume. It is better to do it on sub or AVR? Find this very helpful, you can do it on both, if you want to add sub volume just little after Audyssey is done do it on AVR ( but not all the way to +12db) but if you really like more bass for all what you watch and listen it is better to adjust it also sub volume on sub a little ( skip 75db matching step before Audyssey start calibrated and try to leave it on 82db or around what you preffer)
Very helpful read it:
http://www.avsforum.com/forum/showth...?highlight=#f4
Denon X6200W
SVS 2x PC12-Pluses
Emotiva XPA-200
retro124 is offline
post #17455 of 26056 Old 08-01-2014, 09:06 AM
Kini62's Avatar
Liked: 1400
It is according to the Audyssey experts. I don't have an Audyssey equipped AVR I'm just passing on what those that do have it say is the proper way.
Def Tech SC8000
Kini62 is offline
post #17456 of 26056 Old 08-01-2014, 03:31 PM
Quoted: 258 Post(s)
Liked: 99
I need anyone help .Ok as you all know well some of you.I own Klipsch RF-7 II setup hooed up with a center RC-64 II And for the surround's they are RS-62 II .Now before i added the surround a few days ago.I had a good amount of bass with just haveing the 3.0 setup .The RF-7 II were giveing me a big amount of bass.But right now i feel adding the surround's gave me just more surround sound's now and less bass.I thought i could get the bass back with looking in the setting's of my marantz receiver but i find the bass i had before is a little gone.My question really is if adding the surround's can i lose some bass i had before with adding the surround's.Mind you i do not onw a svs sub just yet and i plan i getting a pb13-ultra for usre now.But yeah can someone please give me some help.
post #17457 of 26056 Old 08-01-2014, 11:04 PM
cchunter's Avatar
Quoted: 513 Post(s)
Liked: 793
Either way doesn't matter as long as you stay at 0 or in the negative after audyssey calibration. If your in the plus after calibration then turn sub gain up! Easy peezy!
5.1 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
cchunter is offline
post #17458 of 26056 Old 08-02-2014, 05:34 AM
Bond 007's Avatar
Liked: 1988
Pretty much. But not everyone has Audyssey. And if youre in the plus after calibration you should really turn up the sub and rerun the room correction software. That will accomplish what you stated in the first sentence.
post #17459 of 26056 Old 08-02-2014, 04:00 PM
Tom Riddle's Avatar
Quoted: 494 Post(s)
Liked: 419
Where do you have your crossovers set?
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #17460 of 26056 Old 08-02-2014, 05:08 PM
Quoted: 258 Post(s)
Liked: 99
I think m center speaker and surround are set to 60htz .Should i change them to a different setting.I dont have a bass so yeah maybe that's why.
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
