Official SVS Owners/Support Thread. - Page 585 - AVS Forum | Home Theater Discussions And Reviews
 4425Likes
post #17521 of 26503 Old 08-11-2014, 11:30 AM
AV_mike's Avatar
Quoted: 115 Post(s)
Liked: 105
Originally Posted by Sdiver2489 View Post
Just curious if anyone has found that calibrating with the sub PEQ before running Audyssey netted much better results than just Audyssey.
If you have some response peaks, due to room position/modes, then using the PEQ to reduce them could help Audyssey to provide a better overall correction.
I base this on my own experience, not with in-built SVS PEQ - but using a MiniDSP with my SB2000. Let me try to explain:-
I found a position within my room that gives a generally flat, extended response from the SB2000, apart from two peaks at approx 45Hz and 55Hz (they actually merge and raise the level between the peaks).
All the other possible positions give large dips and peaks.
I initially ran Audyssey (XT32) on its own. When I measured the corrected response using my calibrated mic and REW it clearly showed that Audyssey only corrected the response ABOVE 45Hz, it totally ignored the frequencies below 45Hz. I believe the two peaks caused Audyssey to calculate the low frequency roll-off as being at 45Hz. It boosted the output above 55Hz in an attempt to produce a smooth response.
Needless to say the results were awful. No bottom end.
I then connected up the MiniDSP and used some PEQ to reduce the two troublesome peaks.
Audyssey was run from scratch again. What a difference. The sub now plays almost flat from 15Hz to 100Hz. Audyssey is now able to interpret the frequency response and apply some useful correction.
So if you've got some nasty peaks, then I would use the PEQ - but don't try to fill in severe dips, as that will just soak up amplifier power.
Independent measurements are required to determine if PEQ is appropriate, but I think it can help.
Regards, Mike.
mnc likes this.
AV_mike is offline
post #17522 of 26503 Old 08-11-2014, 11:45 AM
Sdiver2489's Avatar
Quoted: 184 Post(s)
Liked: 116
Regards, Mike.
I had a really wide resonance from 40Hz to 70Hz that was above the overall sub level when measured. I placed two PEQs spaced apart to tackle this resonance down and then ran XT32 and it was a huge difference. Before that, like you, I had no/little low end.
I am tempted to try a minidsp to see if I can do even better with it stacked on top of XT32 but that's probably overkill.
Sdiver2489 is offline
post #17523 of 26503 Old 08-11-2014, 12:22 PM
mnc
mnc's Avatar
Quoted: 753 Post(s)
Liked: 566
Regards, Mike.
What a great, informative post! Thank you!
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #17524 of 26503 Old 08-11-2014, 12:34 PM
cchunter's Avatar
Quoted: 534 Post(s)
Liked: 832
Originally Posted by tommaazz View Post
What is the size of your room with sb13ultra in it? I have 2xsb12 and i am playing with thought of selling one and getting sb13ultra and keep one sb12 to smooth the response...i just need a little more impact down low...my room is around 1600cubic feet
Just a tad under 2000 cub ft.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RF7II's, RC-64II, RS-52's Cherry
SVS Dual SB13 Ultra's
Oppo UDP-203 Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #17525 of 26503 Old 08-12-2014, 09:36 PM
Teremei's Avatar
Quoted: 540 Post(s)
Liked: 231
How does the SB-2000 perform compared to the PC12-NSD? I looked at the "curve" graph. I don't understand it totally but it measures in db and frequency. It looks like the SB2000 rates just a couple or a few db above the NSD all the way. At one point I remember someone saying at a certain db you can hear it but I don't remember that number. Like I said I don't know exactly how to read it.
It is a pretty small room. Anyway the reason I might upgrade is that I fear there won't be a PC-2000 until after my one year. I would eventually be happy with a PC-2000 and SB-2000 combo. Having the SB-2000 essentially replace the Klipsch RW12d. But is the SB-2000 enough of an upgrade over the PC12? I know it is over the Klipsch.
Upstairs Living Room - LG 65EG9600: Klipsch R-20B Soundbar
Basement - Sony 75x940d: Klipsch Reference series II speakers, 2 subwoofers, Denon x4000
Teremei is offline
post #17526 of 26503 Old 08-13-2014, 06:38 AM
AllenA07's Avatar
Quoted: 701 Post(s)
Liked: 571
Wanted to see what all your thoughts were about laying a PC12+ on it's side. Not sure I'm in love with the idea, but I'm working on moving into a dedicated theater room and doing this would save a lot of issues, because then the sub would fit under the screen.
I seem to recall a handful of people did this and ran the sub behind their couch.
My Theater: The Ugly Theater
AllenA07 is offline
post #17527 of 26503 Old 08-13-2014, 06:51 AM
Mongo171's Avatar
Quoted: 983 Post(s)
Liked: 1411
Try it and see if you like it.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #17528 of 26503 Old 08-13-2014, 10:51 AM
mnc
mnc's Avatar
Quoted: 753 Post(s)
Liked: 566
Ask SVS.
mnc is offline
post #17529 of 26503 Old 08-13-2014, 04:41 PM
Niroe64's Avatar
Quoted: 18 Post(s)
Liked: 45
Originally Posted by retro124 View Post
From what I read about it infamous grenade scene in World War Z ( is very hard scene for sub), is the one scene with port chuffing trouble, few people before said that here also, I need to watch it to find out if I will have this also.
Only scene I have discovered that Chuffs with my pb 2000, running 3 db hot with dynamic eq on. Must be right on the threshold though becasue if I turn the subs gain down just one notch it doesn't do it at all.
AVR Onkyo 818
Fronts Klipsch RF-62II's
Center Klipsch RC-62II
Sides Klipsch RB-51's
Sub SVS PB 2000
Blu-Ray Sony Ps3 Screen Samsung UN46D8000
Niroe64 is offline
post #17530 of 26503 Old 08-13-2014, 05:40 PM
Kini62's Avatar
Quoted: 1723 Post(s)
Liked: 1539
You should try "Oz the Great and Powerful" final witch fight scene. It turns my PC12+ into wheezing asthmatic. Which is disappointing.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #17531 of 26503 Old 08-13-2014, 05:55 PM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 55
Do you have any in room response graphs of your sub ?
jwtallguy is offline
post #17532 of 26503 Old 08-13-2014, 05:57 PM
retro124's Avatar
Quoted: 1289 Post(s)
Liked: 997
Are you running your sub extra hot? What is set up on AVR and on sub?
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Projector and scren shopping now :D
Apple Mac mini, Sony PS3,
retro124 is offline
post #17533 of 26503 Old 08-13-2014, 05:58 PM
retro124's Avatar
Liked: 997
Will try it over weekend to find pit if I will have it also.
Denon X6200W
retro124 is offline
post #17534 of 26503 Old 08-13-2014, 06:35 PM
Kini62's Avatar
Liked: 1539
No graphs, no measuring devices, just set up be ear and feel.
Def Tech SC8000
Kini62 is offline
post #17535 of 26503 Old 08-13-2014, 06:38 PM
Teremei's Avatar
Quoted: 540 Post(s)
Liked: 231
I'm gonna give that a try. I don't remember chuffing. Then again I do run a Klipsch RW12 paired with my PC12. If any sub is going to chuff, it's gonna be that one. I'm curious now. I mean I have multi XT32 with dual sub EQ on the denon so maybe that helps. I'm gonna watch that scene again.
Teremei is offline
post #17536 of 26503 Old 08-13-2014, 06:39 PM
Kini62's Avatar
Liked: 1539
Don't know if it's hot or not. Used to have the sub gain at -5db and the AVR sub level at -4db. Ran it that way for quite a while in 16hz tune, then after getting used to the increased output I started to notice the chuffing which at first I probably thought was bass or sound affects. I never had a big ported sub before.
I've since turned the sub gain down to -10db and added the Def Tech Super cube in the opposite corner to help make up for the reduced output. It's pretty good now but bass heavy movies with content below 20hz will still set it to chuffing at the levels I like to listen to.
Def Tech SC8000
Kini62 is offline
post #17537 of 26503 Old 08-13-2014, 06:48 PM
Teremei's Avatar
Quoted: 540 Post(s)
Liked: 231
The PC12-Plus is an extremely good sub. If you are getting port chuffing at less than reference volume. I feel something might be wrong with it. A quick call to SVS might be a good thing to do.
Teremei is offline
post #17538 of 26503 Old 08-13-2014, 06:52 PM
Kini62's Avatar
Liked: 1539
They would just tell me to turn the gain down so it doesn't chuff.
Sure I can set it that way but then I would have no bass at lower listening levels.
If I had the funds I would replace it and the def tech with a pair of sealed subs. As it stands my only feasible option is to add another plus or maybe and ultra down the road.
Def Tech SC8000
Kini62 is offline
post #17539 of 26503 Old 08-13-2014, 06:54 PM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 55
Theres a real good chance your in a spot that you get very little effect from 20 hertz and down as I do currently at my mlp. Now I still can hit 115 db at 20 hz and 108 @15 hz in my spot but if I move my mic forward 3 feet I get a boost that pulls 15 hz up to 113 with no port noise and down to 10 hz @ 107
post #17540 of 26503 Old 08-13-2014, 07:00 PM
Kini62's Avatar
Liked: 1539
Could be. The only thing I have done is move around the room or across the 4 seats (sofa) while playing some low bass tracks off youtube. I can't hear or feel much difference within the main listening positions or in front or in back of them. There is some build up in the two rear corners.
I'm sure if I were to graph it I would be surprised at what the response actually is. But that is not something I want to mess with. The rabbit hole is much too deep.
Def Tech SC8000
Kini62 is offline
post #17541 of 26503 Old 08-13-2014, 07:08 PM
retro124's Avatar
Liked: 997
Well yes it is hot. When I run Audyssey both Pluses are set -17db and AVR was set up -5.5db so I add 3db so now is -2.5db and I never had chuffing problem, not sure if running dual subs will help that probably little because subs don't need to work that hard. Need to watch World War Z to find out but many movies what I watched no problem at all. Both subs are set to 16hz mode.
Denon X6200W
retro124 is offline
post #17542 of 26503 Old 08-13-2014, 07:14 PM
Kini62's Avatar
Liked: 1539
I'm sure dual subs would help since just adding my def tech helped.
I did not have any chuffing in the WWZ grenade scene and that was when running only the PC at -5db gain on the sub.
It's only certain scenes in certain movies. I can run many of the youtube bass test tracks and not get chuffing. There are a few that give the sub fits though.
Time for a pair of reaction audio BP215s. (Nah, too big). Down the road another cylinder and maybe run them in sealed mode.
Def Tech SC8000
Kini62 is offline
post #17543 of 26503 Old 08-13-2014, 07:19 PM
retro124's Avatar
Liked: 997
I will see and let you know, also sealed mode Is mode what I need to try. I had factory 20hz then when I decide to kept both subs I talked to Ed from SVS and he said set them to 16Hz and I love it, maybe sealed mode will be even better need to check it. i'm very busy ar work those days so no time to play that much, hopefully next week will be slow.
Denon X6200W
retro124 is offline
post #17544 of 26503 Old 08-13-2014, 11:27 PM
kendog's Avatar
Quoted: 20 Post(s)
Liked: 25
I have a pc13u on its side behind our seating position, works well.
kendog is offline
post #17545 of 26503 Old 08-14-2014, 05:04 AM
KK in CT's Avatar
Quoted: 101 Post(s)
Liked: 73
Are there any disadvantages to purchasing one of the subs in their outlet? I'm interested in the PB-2000, and they have one listed now that states there is no damage (which would be the one disadvantage I could think of). From what I can tell, you still get the same warranty and guarantees as you would if you purchased a new one.
LG OLED65E6P | Oppo UDP-203 | Denon X5200W 7.2.4 | Darbee DVP-5000 | Emotiva XPA-3 | Sony PS4 | Xfinity X1
KK in CT is offline
post #17546 of 26503 Old 08-14-2014, 05:08 AM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 55
Nope, buy away!
post #17547 of 26503 Old 08-14-2014, 07:19 AM
Mongo171's Avatar
Quoted: 983 Post(s)
Liked: 1411
The Outlet is there for Returns. They fully test the sub and give it the full return policy and warranty as a new one.
Mongo171 is offline
post #17548 of 26503 Old 08-14-2014, 11:50 AM
KK in CT's Avatar
Quoted: 101 Post(s)
Liked: 73
Well, after one more chat session with Jack at SVS, I had the info I needed and have placed my order for a PB-2000. I will finally have dual subs. Really looking forward to getting this. So far I'm very impressed with the customer service at SVS.
KK in CT is offline
post #17549 of 26503 Old 08-14-2014, 12:04 PM
jwtallguy's Avatar
Quoted: 119 Post(s)
Liked: 55
Duals are such an upgrade once setup properly. Congrats.
post #17550 of 26503 Old 08-14-2014, 12:09 PM
Mongo171's Avatar
Quoted: 983 Post(s)
Liked: 1411
I didn't know it was Christmas already?!?!?
Congrats!
Mongo171 is offline
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
