Official SVS Owners/Support Thread. - Page 612 - AVS Forum
post #18331 of 18346 Old 10-19-2014, 09:03 PM
joseph10704's Avatar
Quoted: 78 Post(s)
Liked: 39
Originally Posted by retro124 View Post
Hey man, good to see you with new driver installed. This baby is big, nice picture, why did you posted here, needs to be on Klipsch one!!! It is a first time I saw RF-7II's drive out, thanks for posting. So all is working jus fine now again?
Yeah everything is working wonderful.It sound's wonderful the RF-7 II just the other day i was blasting my setup and my next door neighbors was like screaming at me lol.She was like turn that s@#$ lower.And i was like no not if you going to talk to me like that lady.LMAO I am getting sick of her kids playing basketball on my property.I keep telling her that her kid's can get hert.I am a landlord and the lady just does not listen what so ever.It's like none stop there trowing a basket ball and it can bounce and hit one of my window's in my apartment building.Then what lol.But yeah she got mad at me for playing my music on a saturday.I was like no way lady it's the week end get the hell out of here lmao.
joseph10704 is online now
post #18332 of 18346 Old 10-19-2014, 11:19 PM
peruzzi's Avatar
Originally Posted by neutro View Post
The main differences are:
* finish: the SB-2000 is either black ash patterned vinyl, or glossy piano black (a more expensive option though), whereas the SB12-NSD is either charcoal black vinyl or glossy piano black (again, more expensive).
* output: the SB-2000 has a beefier amp that adds 3-4 dB to the output above 30 Hz. Below 30 Hz the two subs are basically identical.
Depending on how much you value the various finish options and the mid-bass output, it could be worth $300 more but I for one think the SB12-NSD is a pretty nice sub if the alternative is 50% more expensive.
SB 2000 is black ash ($956), SB-12NSD is charcoal black ($637) and actually i dont care about finish.
If subwoofer is on the volume 1\3 - 1\2 of maximum (I dont listen louder), are SB2000 and SB-12NSD exactly the same?
peruzzi is offline
post #18333 of 18346 Old Yesterday, 08:01 AM
neutro's Avatar
Quoted: 82 Post(s)
Liked: 481
If you don't mind about finish and don't plan on reaching the SB12-NSD's limits, then yes I believe you'd get the exact same results with the $637 sub
Although if this is your first serious sub, you may find yourself listening louder and louder as a result of your purchase
peruzzi likes this.
neutro is offline
post #18334 of 18346 Old Yesterday, 09:07 AM
teddyc23's Avatar
Originally Posted by Sdiver2489 View Post
1. Leave it, it can be used to adjust phase via distance setting.
2. I do not go that high but whatever you like is fine by you . You won't hard the subwoofer, you just may reach its limits more often. I can think of a couple reasons why you like to boost the SVS hotter
- The SVS does not have a peaked response and therefore you can tolerate more boost before the midbass dominates
- You may be hearing deep bass for the first time and wanting more of a good thing
Anyway, you might want to try it on something a bit less starting out and then continue to raise if it still doesn't meet your preferences after a couple days.
Thanks for your help. I may back it down to +6db and do some testing.
Teddy
teddyc23 is offline
post #18335 of 18346 Old Yesterday, 06:00 PM
Vader424242's Avatar
Quoted: 16 Post(s)
Liked: 32
Originally Posted by teddyc23 View Post
I just purchased an SVS PC12-NSDsubwoofer. This is replacing a Polk PSW505. I noticed a few thingsAudessey related I was wondering if anybody had any advice.
I have found I like the SVS around +9db above the calibration. I was wondering if anyone else likes running there SVS sub this hot? I do not listen at reference level, but I do like it somewhat loud on occasion. Should I worry about running the sub this hot?
Teddy
Hi Teddy,
I am in much the same boat, as Audyssey set my sub AVR trim to -10.5, and I had to raise it +4.5dB just to get a flat calibration (as determined using an SPL meter and calibration BD). I goosed it a further 5dB to run it hot (I do not use Dynamic EQ). In your case, +9dB from where Audyssey set it is not that unreasonable (I am at +9.5dB), as Audyssey tends to set LFE several dB cold relative to the sats in the first place. How hot should be measured from a flat calibration, so your best bet is to get an SPL meter and good calibration disk to find out just how hot you are running. Good luck!
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is online now
post #18336 of 18346 Old Yesterday, 06:17 PM
garywade1978's Avatar
Quoted: 14 Post(s)
Originally Posted by garywade1978 View Post
What is the difference in ported vs sealed? I've narrowed my choices down to these 2 and the Goldenear. Anyone known which one is better?
Real generally, Sealed has a slower rolloff in the deep low frequencies but less output power in this region. Ported has a steep roll off after the tuning frequency and has more output in this region.
In general, in small rooms (sealed) sealed subs work well. The room adds gain which tends to complement the slow roll off and because the
room is small you can get all the output you need down to very low frequencies.
For larger rooms they almost always need ported subs for more max output. You may not get the extremely deep frequency extension of sealed subs in small rooms but you get output in spades.
Ported subs have larger box volume which makes them overall bigger. This reduces the WAF. Sealed subs can be made in small enclosures which can more easily be hidden if cosmetics is a big concern.
Thank you for your response. My room is 14x24 with 7' ceiling. Is a ported too much? How about the GoldenEar? Is SVS that much better?
garywade1978 is offline
post #18337 of 18346 Old Yesterday, 06:35 PM
retro124's Avatar
Quoted: 284 Post(s)
Liked: 222
Not at all, your room is a nice size ported will do great there. What sub or subs are you thinking about?
Denon X4000
Klipsch RF-82II's , RC-62II , RS-52II's , RB-81II's
SVS 2x PC12-Pluses
Emotiva XPA-3
Sony KDF-60XS955
Apple Mac mini, Sony PS3
retro124 is offline
post #18338 of 18346 Old Yesterday, 07:27 PM
Quoted: 14 Post(s)
I am leaning toward the pb2000, I think its $800. GoldenEar 5 subwoofer. Tough choice considering I can't hear the SVS. GoldenEar sub sounded great but im reading bad things about there subwoofer. Everything I've read about the SVS, says its the best subwoofer in that price range.
post #18339 of 18346 Old Yesterday, 08:11 PM
RPGMasta's Avatar
I love my SB12-NSD in my 1400cu. ft. room. Just ordered some Elite bookshelves to audition before I decide on GoldenEar 5.1 with Triton 7 towers.
Sometimes our circuits get shorted by external interference,
Signals get crossed and the balance distorted by internal incoherence.
RPGMasta is online now
post #18340 of 18346 Old Yesterday, 08:19 PM
retro124's Avatar
Quoted: 284 Post(s)
Liked: 222
PB-2000 is for sure great sub, SVS have excellent reviews on great subs and customer services. Why not you can't try it?
Denon X4000
SVS 2x PC12-Pluses
Emotiva XPA-3
Sony KDF-60XS955
retro124 is offline
post #18341 of 18346 Old Yesterday, 08:51 PM
skinner84's Avatar
Hey guys,
Looking at getting an SVS Sub in the coming weeks. My system consists of an Anthem MRX 710 + Anthem MCA 30 Power amp, with Focal Aria 926 fronts. These speakers already put out an impressive amount of bass, but they obviously are lacking for Movies. I really like the look of the SB-13 Ultra, but wonder if it's worth the extra money over the PB-2000. Also not sure if my room is too big for a sealed Sub. Room is reasonably acoustic friendly - carpet, rectangular in shape. Opens up to a Kitchen/Dining area that is tiled.
Dimensions of the space are 4m x 6m x 2.7m which roughly translates to 2000cu ft. This doesn't include the kitchen/dining area which is roughly the same dimensions again on one side.
Would be great to get some recommendations.
Luke
skinner84 is online now
post #18342 of 18346 Old Yesterday, 08:58 PM
Quoted: 14 Post(s)
I live in Boston Ma. There's no SVS dealer near me. I know they have a 45 day return policy but it's a pain in the ass shipping back waiting on a refund. It's really a toss up. The Forcefield 5 is only a thousand bucks and the svs is 800, perfect world, I could demo them side by side. God knows this site has fed my movie room sickness into thousands upon thousands with no end in site. I was hoping to hear from someone that had one of the goldenear subs and also had the SVS.
post #18343 of 18346 Old Yesterday, 08:59 PM
Sdiver2489's Avatar
Quoted: 91 Post(s)
Liked: 57
Originally Posted by skinner84 View Post
Hey guys,
Luke
I don't think you can go wrong with the PB-2000, especially considering you could get almost two for the price of the ultra.
You aren't going to be getting much room gain with the open room so I do not see much in the way of benefits for you going with the ultra sealed.
Sdiver2489 is offline
post #18344 of 18346 Old Yesterday, 09:19 PM
tang7969's Avatar
Quoted: 27 Post(s)
Liked: 45
It's actually really easy to demo an SVS sub. Just keep all of the packaging and if your not happy call SVS and they will send a return shipping label to your email print it out and box up the sub.Just ask SVS to have Fed Ex pick it up from your house.
-46" SAMSUNG-ENERGY RC-50'S-ENERGY RC-LCR-ENERGY RC-10'S-PSA XV15se-PIONEER ELITE SC-25-OPPO BDP 103Dhttp://www.avsforum.com/g/a/1459339/default/
tang7969 is online now
post #18345 of 18346 Old Yesterday, 09:35 PM
DocCasualty's Avatar
Quoted: 34 Post(s)
Liked: 210
I've never heard a GoldenEar, so take this FWIW. I do have a PB-2000 in a >7000 cu ft room and it rocks. Chest thump, floor rumble, tight bass, etc. SVS pays for the return if it doesn't work for you.
"Dave, this conversation can serve no purpose anymore. Goodbye." - 2001:ASO
DocCasualty is offline
post #18346 of 18346 Old Yesterday, 10:09 PM
retro124's Avatar
Quoted: 284 Post(s)
Liked: 222
Well then it is easy you buy it try it if you like it keep it if you want to try better SVS sub or just return it call SVS they will prepare all for you. This is easy man, pain in the ass is companies where you have to pay shipping back then you really need to done some serious thinking not with SVS, Their customer servise is outstanding. You can also get 2 subs from them at same time let say PB-2000 or maybe bigger PB12-Plus and compare them side by side and then just send it back what you don't like. Shipping is fast I get it from them in 3 days and refund take 2-3 days no worries there at all.
Denon X4000
SVS 2x PC12-Pluses
Emotiva XPA-3
Sony KDF-60XS955
retro124 is offline
post #18347 of 18346 Old Yesterday, 10:11 PM
Quoted: 14 Post(s)
Thanks for everyones help. I think I will buy the pb-2000. I will update after I received the subwoofer.
post #18348 of 18346 Old Yesterday, 10:25 PM
jwtallguy's Avatar
Quoted: 32 Post(s)
Liked: 27
Hello, I have heard both and the choice is very easy, pb2000 is 3 times the sub.
The FF5 is decent if the size is taken into consideration but not when compared the pb2000 as the under 30 hertz is 2-3 times the output and it also doesnt have the 5 year warranty and customer service svs comes with.
jwtallguy is offline
post #18349 of 18346 Old Today, 03:45 AM
bear123's Avatar
Quoted: 180 Post(s)
Liked: 701
I would not curse at you. I would just call the police. Best way to deal with inconsiderate jack a$$es often times. If you still live in an apartment complex, there is a level of respect and consideration one should have. Once someone becomes a homeowner, there is a level of freedom that comes with it in regards to doing what you want, when you want, as loud as you want. But playing your high output stereo so loud that people scream and curse at you? Same thing with stomping around and jumping, banging, slamming doors etc etc. Learn some respect and you won't get those reactions.
AVR:       Yamaha RXV-375
Display:  Panasonic  TH-50PC77U
LCR:       Hsu HB1.2  HC1.2
Sub:       (2) PSA XV15se
Blu Ray:  Sony BDP-S5100
Apple TV
Harmony 650
miniDSP
bear123 is online now
post #18350 of 18346 Old Today, 05:09 AM
TurboTropic's Avatar
I've joined the SVS club. Picked up a used SB12-NSD last night to replace a 6 week old Polk PSW10 for my modest basement home theatre. Really looking forward to using it.
TurboTropic is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
