Official SVS Owners/Support Thread. - Page 618 - AVS Forum
post #18511 of 18516 Old Today, 07:30 AM
neutro's Avatar
Quoted: 97 Post(s)
Liked: 495
Originally Posted by DaJoJo View Post
does ur sub have a dB scale on it ? have to set volume to -6dB for it to be at half power. use the LFE out to the left line input from the sub. check if the LFE of yammie avr is set to LFE+Fronts. and the trim level on 0dB and sub adjustment also to 0dB.
The digital display is only on the Plus and Ultra models. It has to be noted that the "volume" setting is in fact only an attenuation of the line-level input. The recommended setting is max (0 dB) unless (like many) your AVR is not able to reduce the signal enough to get the appropriate level for this sub. If you use the sub in a small room, in all likelihood you'll have to set the volume lower.
On the 1000- and 2000- series sub, the volume knob is the amp's gain. If you set it to the max, you may experience too much noise. Somewhere between 10 and 2 o'clock is the recommended starting position.
It's also to be noted that the volume (on any model) setting has no bearing on the max output that you'll be able to reach with the sub.
DaJoJo likes this.
neutro is online now
post #18512 of 18516 Old Today, 07:37 AM
DaJoJo's Avatar
Quoted: 292 Post(s)
Liked: 758
Originally Posted by mnc View Post
Why didn't you get the Black Oak finish then?
Originally Posted by 4fit? View Post
He did. See pics in this post. I believe he was just stating that he definitely prefers the finish he got over the gloss finish.
You are right, my bad!
yes i did
i do like the black oak finish a lot better then this plastic look gloss stuff. it makes the sub look more natural and i just like wood and natural things more then plastic and unnatural stuff.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz
center RC-64-II 200W 59Hz-24KHz
sides 2xRS-62-II 150W 50Hz-24KHz
rears 2xRB-81-II 150W 44Hz-24KHz
Yamaha RX-A3040, YST-SW800 Sub 1000W RMS 6 Ohm 18-170 hz / SVS PB13-Ultra 1000W 14-200hz
Audioquest 1.6mm wire / Samsung UE-ES8000S TV+evo 2014 / Sony Playstation 3/ AC PlayonHD2
DaJoJo is online now
post #18513 of 18516 Old Today, 07:41 AM
DaJoJo's Avatar
Quoted: 292 Post(s)
Liked: 758
ah that explains a lot, thanx. the -6dB setting on my sub is allready too much bass for me . my room is 6x6.5 meters, not that small i guess . for amp gain it is best to have the volumeknob at half power, so it won't distort and least amount of noise indeed.
post #18514 of 18516 Old Today, 07:49 AM
DaJoJo's Avatar
Quoted: 292 Post(s)
Liked: 758
Originally Posted by bear123 View Post
Something is definitely not right. I would try turning the sub gain up to around 3/4 and run YPAO. See where the AVR sets your subwoofer level trim. If it is above zero, turn the gain up on the sub some more and re-run YPAO. The goal is to set the gain on the sub in such a way that YPAO will set the subwoofer trim around -8 or -9. Auto calibration almost always sets the subwoofer quieter than most people prefer, so this gives you room to turn the sub up 6 dB or so, to -2 or -3. Of course, this should be done AFTER you have performed the subwoofer crawl, to ensure the sub is in an optimal location for good bass at your main listening position. If you cannot get YPAO to set the sub down to -6 to -9 even with the gain maxed out, then a Y splitter might help, or there might be an issue with the sub or the AVR. Good luck!
Also, if you are able to get the sub setup properly this way, play some bass heavy music nice and loud. Not super low deep bass, but some nice punchy bass. Reverse the phase on the sub. If the bass weakens, the phase was correct, switch it back. If the bass noticeably improves, it was out of phase and is now correct.
agree. with a sub with gain adjust as the one he has it better to decide whether he want to turn it up 3/6/9 dB and then run the ypao on volume setting that end up with -3/-6/-9 dB then after this he can set it to his liking and have the end result be that the trim is at 0dB so that the gainknob on the sub is at the lowest possible setting and has least amount of noise and distortion.
post #18515 of 18516 Old Today, 08:18 AM
cchunter's Avatar
Quoted: 236 Post(s)
Liked: 535
yes i did
I also have the black oak finish with my Ultra and it matches very well with my Klipsch 7's and 64.
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Sony BDP-S790, PS3
Panamax 5300PM
Samsung UN60F7100 3D LED
cchunter is online now
post #18516 of 18516 Old Today, 08:19 AM
cchunter's Avatar
Quoted: 236 Post(s)
Liked: 535
Dajojo have you tested your Ultra out on any bass heavy movies yet?
Denon 4520
SVS SB13 Ultra
Sony BDP-S790, PS3
Panamax 5300PM
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
