Official SVS Owners/Support Thread. - Page 628 - AVS Forum
Old 11-25-2014, 01:03 PM
Kini62's Avatar
Quoted: 293 Post(s)
Liked: 417
Originally Posted by mantaraydesign View Post
Thanks for your advice!
I am using the Pure Direct mode with the receiver. I am not using the back speakers. Just have a pair of bookshelf speakers and the PB12 Plus.
I like my PC12+ better in sealed mode for music as well. I currently run my towers as large and the sub as LFE +main. I find in my room I get a better sound at the low to moderate volumes I normally listen at.
Depending on the capabilities of your speakers 80hz is a good place to start. Maybe even go to 100hz or higher to see if the mid bass is better from the sub or the speakers.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 11-26-2014, 05:22 AM
neutro's Avatar
Quoted: 142 Post(s)
Liked: 521
Pure Direct mode won't use your subwoofer as it completely bypasses the crossover.
Also depending on your bookshelf speakers it could be adequate to use a higher crossover frequency.
lflorack likes this.
neutro is offline
Old 11-26-2014, 05:24 AM
neutro's Avatar
Quoted: 142 Post(s)
Liked: 521
neutro is offline
Old 11-26-2014, 08:19 AM
Liked: 0
I'm upgrading from BK Monolith.
Should I get
PC 2000
or
PB 2000
jamb0 is offline
Old 11-26-2014, 08:53 AM
Mongo171's Avatar
Quoted: 123 Post(s)
Liked: 737
Should I get
PC 2000
or
PB 2000
Both about the same, sound-wise. Depends on budget and form.
Life without bass is not worth living.
Mongo171 is offline
Mongo171's Avatar
Quoted: 123 Post(s)
Liked: 737
Should I get
PC 2000
or
PB 2000
Mongo171 is offline
Old 11-26-2014, 08:55 AM
Liked: 0
They're at same price.
I see that they use same element, same amp etc.
And the PC seems to do 16hz, while PB does 18hz?
Usage is 80% music and 20% movies.
jamb0 is offline
Old 11-26-2014, 09:04 AM
Gurba's Avatar
Quoted: 154 Post(s)
Liked: 70
The Pure Direct in Yamaha might use the subwoofer if you have extra bass active.
Gurba is offline
Old 11-26-2014, 09:07 AM
Gurba's Avatar
Quoted: 154 Post(s)
Liked: 70
Should I get
PC 2000
or
PB 2000
I have owned the PC12-NSD and PB12-NSD DSP and the PCs were far easier to calibrate in my room and played 3hz deeper. So I sold the PBs and have a PC-2000 on order.
Gurba is offline
Old 11-26-2014, 09:31 AM
Mongo171's Avatar
Quoted: 123 Post(s)
Liked: 737
Thumbs up
The difference between 16 and 18Hz can't be heard, only measured. I am biased towards the water heaters. Plays music well and digs down for movies. Good luck in your choice, grasshopper.
Matt2026 likes this.
Mongo171 is offline
Old 11-26-2014, 12:42 PM
B 26354's Avatar
Quoted: 20 Post(s)
Liked: 133
As always, Neutro is spot on.
Regarding Gurba's proposal... it's definitely an interesting thought, but I just now checked it out, and it doesn't.
My AVR is a Yamaha RX-A2010.
Configuring the fronts to "Large" on the A2010 allows the use of "Extra Bass", which sends the front speakers' full-range signal to my SVS SB12. On the SB12, I have the Low Pass filter set to "Disable" (on its 400W Sledge amp, about 180Hz or so), so all low-frequency signals are sent to it, but the output frequencies start to loose amplitude at about 130Hz, and are completely gone at 180Hz.
Configured as above, switching the A2010 to "Pure Direct" mode completely bypasses those configurations... and when the source is only 2-channel, no signal is sent to the sub at all. Of course, if the source is multi-channel, and has actual content in the .1 channel, it will receive that signal... but my assumption is that we are only discussing the processing of a 2-channel source here.
If the fronts are configured to "Small", the A2010 has myriad processing modes (I tend to prefer "Straight", although I occasionally use "Nine Channel" if I want to engage my surrounds). Needless to say, in all of those modes, it sends the low-frequency crossed-over portion of the 2-channel signal to the sub.
But again, switching it from any of those modes to "Pure Direct" results in a "pure" 2-channel signal being sent solely to the front speakers, and no signal is sent to the sub at all.
Hope this helps!
B 26354 is offline
Old 11-26-2014, 12:53 PM
Gurba's Avatar
Quoted: 154 Post(s)
Liked: 70
Hence the "might".
Gurba is offline
Old 11-26-2014, 02:12 PM
B 26354's Avatar
Quoted: 20 Post(s)
Liked: 133
Hence the "might".
Yah... I realized that you were simply speculating. The thought of its being possible threw me for a bit of a loop, though... which is why I had to immediately check it out, and let you know what I'd found.
Gurba likes this.
B 26354 is offline
Old 11-26-2014, 03:05 PM
Gurba's Avatar
Quoted: 154 Post(s)
Liked: 70
The thing is I had this issue With the subs playing along in Pure Direct. It took some time to figure it out.
Gurba is offline
Old 11-26-2014, 05:13 PM
johnnyknoxsvill's Avatar
Quoted: 17 Post(s)
Hey guys, Ive had my PB-2000's up and running for about 2 weeks. With in the past week one sub does not kick on right away when it gets signal. It will kick on at a random time which is really weird. I talked to SVS and they suggested removing the amp to check the connections for the LFE plug-in. Have any of you guys ran into this problem? if so what did you do to fix it.
I'm running these with a Pioneer VSX-1123 7.2 I'm not using a y-splitter each sub is on its own connection.
johnnyknoxsvill is online now
Old 11-26-2014, 05:22 PM
mantaraydesign's Avatar
Quoted: 24 Post(s)
A few days ago, I opened a thread regarding the Pure Direct mode. Please see this thread:
Bookshelf Speakers + Subwoofer Setup
mantaraydesign is offline
Old 11-26-2014, 05:24 PM
B 26354's Avatar
Quoted: 20 Post(s)
Liked: 133
Now I'm really curious. What was going on?
B 26354 is offline
Old 11-26-2014, 09:17 PM
NODES's Avatar
Quoted: 118 Post(s)
Liked: 63
There was someone else with a similar issue as yours, I cannot recall if it was in this thread though.
had 2 subs and one would turn on later then the other and it was due to the length of cable used to the sub.
NODES is online now
Old Yesterday, 02:53 AM
Gurba's Avatar
Quoted: 154 Post(s)
Liked: 70
I couldn't remember it earlier. When the PC soundcard was setup as a 7.1 the sub played in PD. When I set it to 2.0 only the fronts play. Weird thing but there you go.
Gurba is offline
Old Yesterday, 05:09 AM
neutro's Avatar
Quoted: 142 Post(s)
Liked: 521
Most likely YPAO set the sub levels differently on each of your subs (which is okay), and at lower levels only one wake up from standby because line level is higher. I have the same problem with my dual Plus. They're kind of overkill for the room so the levels are very low, and the one that is set lower sometimes doesn't wake up. I either turn it on manually or temporarily bump up the volume until it's on.
Didn't know there actually was a way to use the sub in Pure Direct mode on Denons.
You still haven't told us what bookshelves you're using; they may require a higher crossover.
Also with Pure Direct you won't get the benefits of Audyssey room correction so the sub will likely be more affected by room modes and the like.
neutro is offline
Old Yesterday, 09:53 AM
B 26354's Avatar
Quoted: 20 Post(s)
Liked: 133
Ahh... gotcha. Doesn't surprise me at all. I use my PC for ripping CDs, editing the WAV files to my liking, and then transferring them to a USB drive that's connected to my Oppo BD player... but I don't have any part of my AV system connected to either my PC or the Internet, and never have. I can't really say what the deal was... but using a PC's soundcard as any part of a "good" audio system has always seemed like a complete oxymoron to me.
B 26354 is offline
Old Yesterday, 11:55 AM
Gurba's Avatar
Quoted: 154 Post(s)
Liked: 70
I have the PC Connected to the AVR With an HDMI-cable. I Guess I'm part of the "it's all digital"-crowd.
Gurba is offline
Old Yesterday, 07:48 PM
Quoted: 17 Post(s)
It finally quit today, the blue light stays on but no sound. I will be contacting SVS tomorrow for a replacement. I know things happen but when you spend $1500 on subs you would expect them to work longer then a week I tried switching out cables, removing the amp to look for connection problems and nothing. I might just return them both and go with dual PB-1000's not sure yet
Old Yesterday, 07:56 PM
Quoted: 17 Post(s)
Also how would a single PB12-Plus compare to dual PB2000's?
Old Yesterday, 08:05 PM
mnc
mnc's Avatar
Quoted: 98 Post(s)
Liked: 77
For $1500, he could get a PC-13 Ultra from the outlet!
NHT speakers, Denon 4520, 65VT50
mnc is offline
Old Yesterday, 08:08 PM
john e monahan's Avatar
I have had my dual pb 2000s about two weeks with no problems. Thinking about using the 12v trigger to turn them on and off as I had a velodyne that had trouble with the signal sensing. I wouldn't trade my pb 2000s for anything.
sidevalve
john e monahan is offline
Old Yesterday, 10:06 PM
NODES's Avatar
Quoted: 118 Post(s)
Liked: 63
I know what you mean....I got my fedex package today oh boy and does it pound.
NODES is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
