Official SVS Owners/Support Thread. - Page 687 - AVS | Home Theater Discussions And Reviews
post #20581 of 20603 Old Yesterday, 12:47 PM
AllenA07's Avatar
Quoted: 130 Post(s)
Liked: 139
Originally Posted by Sdiver2489 View Post
I don't have dual pluses (I have just one) but I am a big proponent of trying to EQ with the PEQs first and then running Audyssey. My results were night and day better this way.
That's really my question, does the peq on board the plus and Ultra give enough flexibility to get the job done. I don't have SubEQ so I'll be doing a lot of this by hand. I'll probably be going with the Ultra, so there will be some additional complications from me not having matching the subs. SVS has told me the plus and Ultra will play nicely together so I trust them.
Just figure that if I go with an Ultra I'll be out almost $3000 in subs, I don't want to skimp on the last $100.
TomC1315 likes this.
AVR: Denon 2112
Speakers: EMP Tek e55ti, Center- EMP Tek e56ci, Side Surrounds- EMP Tek e55wi, Rear Surrounds- SVS Prime Satellites, Sub- SVS PC12 Plus
Display: BenQ w1070 on a 92in fixed screen
Blu-Ray Player: Sony BDP S6200;
Playstation 4
AllenA07 is offline
post #20582 of 20603 Old Yesterday, 01:25 PM
kendog's Avatar
Originally Posted by retro124 View Post
I don't I have been using only my AVR Denon X4000 with Audyssey XT32. I bought also Umic-1 and download REW but I'm Apple guy and REW and Apple it is pain in the back part of mine body. I'm thinking to get windows for Mac so I will get all working much more easier.
There is a guide on the mini dsp site that explains how to use REW with a Mac. I use a Mac mini with HDMI.
It took a little bit of time to set up, and a couple of set up steps each time you start measuring, but it works well.
kendog is offline
post #20583 of 20603 Old Yesterday, 01:57 PM
Sdiver2489's Avatar
Quoted: 157 Post(s)
Liked: 103
You'll need something to measure your setup with....like REQ. Once you do this you can see if there is any large resonances that need to be tamed. I used the two PEQ's in tandem to flatten out a wide point of emphasis in my room. It doesn't need to be perfect...just help perfect it for Audyssey. The problem with mine I believe is that audyssey saw the drop off for this wide resonance as the actual drop off point in the sub and gave up anything below that. Once I flattened it out the results were startling when followed up with audyssey.
Sdiver2489 is offline
post #20584 of 20603 Old Yesterday, 02:11 PM
AllenA07's Avatar
Quoted: 130 Post(s)
Liked: 139
I have REW and measurement gear (though I haven't had much of a chance to play around with it), so I do plan on taking some measurements. All things considered, these subs have pretty decent PEQ's, so I would love to try to get things working between the two instead of buying more gear.
AVR: Denon 2112
Playstation 4
AllenA07 is offline
post #20585 of 20603 Old Yesterday, 03:29 PM
retro124's Avatar
Quoted: 455 Post(s)
Liked: 318
Thanks for tip. I also have Mac mini with HDMi so as Macbook. I will check it out and maybe will get back to you with some questions if I can, thanks again.
Denon X4000
Klipsch RF-82II's , RC-62II , RS-52II's , RB-81II's
SVS 2x PC12-Pluses
Sony KDF-60XS955
Apple Mac mini, Sony PS3
retro124 is offline
post #20586 of 20603 Old Yesterday, 03:31 PM
Gurba's Avatar
Quoted: 214 Post(s)
Liked: 102
REW will not fix Your issue but it will help you in finding the problem areas in the frequency response and Yu can make adjustments manually and REW will let you know the results.
Gurba is offline
post #20587 of 20603 Old Yesterday, 05:00 PM
etc6849's Avatar
Quoted: 46 Post(s)
Liked: 69
Hey buddy. I just noticed your PM and replied. Sorry, I honestly didn't see it before!
The ultras arrived today, and I'm setting them up right now. Too bad Audyssey pro takes so long to run.
Premise, a FREE home automation program. Open-source Z-Wave Premise Module found here.
etc6849 is offline
post #20588 of 20603 Old Yesterday, 05:38 PM
bear123's Avatar
Quoted: 521 Post(s)
Liked: 1026
Originally Posted by Titan319 View Post
I am in process of ordering the Minidsp Umik-1 i E-mailed them to make sure there is a calibration file for 90 degree measurements and there is so i can download it from the website. So i am going to order the mic i thought that Audyssey should handle set up of dual subs and im curious what would REW to fix the situation.
REW will let you see, and optimize, your response before Audysey or any other eq attempts to smooth your response. If your placement is poor and you have a huge null, there is not much that Audysey or manual eq can do to help. REW can help you work on getting the smoothest response possible without any nulls so that your eq can get you the nice smooth response that results in the best quality bass. It lets you see exactly what any change you make with placement, phase, distance changes, crossover changes, etc does to to your FR.
For Sale: PSA XV15se x 2 $675 each!!
http://www.avsforum.com/forum/209-au...-725-each.html
bear123 is online now
post #20589 of 20603 Old Yesterday, 07:03 PM
Titan319's Avatar
Quoted: 159 Post(s)
Liked: 42
So when i get the mic and i start testing do i need to run Audyssey every time or move the sub while the distance setting stays the same around the room and measure until i get the best response? Or how does that work.
Titan319 is offline
post #20590 of 20603 Old Yesterday, 08:15 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 71
Titan, you can also get the UMIK-1 from Cross Spectrum Labs if you want the best calibration. I don't know how large the difference is, but that's what was recommended to me.
Soulburner is online now
post #20591 of 20603 Old Yesterday, 08:27 PM
nashou66's Avatar
Quoted: 66 Post(s)
Liked: 94
What you should do is the sub Crawl.
Put the sub in your listening position and go around the room to the spots you want to put the sub and measure the output with a
SPL meter using a white noise signal. Put the sub where the white noise measures the loudest.
Also you can use REW at each spot and run a Sub sweep for 10hz-120hz. Find the spot with the shallowest null.
Then Audyssey can trim the peeks.
I have not tried this but it makes sense to me unless others can add to why this is a good idea or bad.
Nashou
nashou66 is offline
post #20592 of 20603 Old Yesterday, 08:39 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 71
Many subs loosen up after a break in period. I'd either wait to calibrate, or if you must, do it again after you get some hours on them.
post #20593 of 20603 Old Yesterday, 08:42 PM
retro124's Avatar
Quoted: 455 Post(s)
Liked: 318
You do calibration couple of times anyway a specially with dual subs until you find right spots for them or right mode for Ultras.
Denon X4000
SVS 2x PC12-Pluses
Sony KDF-60XS955
retro124 is offline
post #20594 of 20603 Old Yesterday, 11:20 PM
Titan319's Avatar
Quoted: 159 Post(s)
Liked: 42
Thanks for all the tips guy i guess first things first. Is it really worth the price difference to have the UMIK-1 calibrated from what i see it looks like it is accurate from 5hz to 25khz from the lab. And if i buy it direct it is accurate from 20hz to 20khz. Is this the only difference. I put my PB12+ back in place i am running 20hz tune man this sub has some serious bass output.
Titan319 is offline
post #20595 of 20603 Old Yesterday, 11:24 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 71
If that's the case - if you want to measure below 20Hz, I'd get the one from CSL. It's only a few more bucks.
post #20596 of 20603 Old Today, 01:18 AM
vador84's Avatar
hi,
I m living to France,
Svs support, said me to turn up the sub s volume knob to 3/4 on my new pc 2000.
thats a more typical position...in pratice the about 3/4 works best for the sta 500d in 2000 line.
With this tune, on my Yamaha 2030, the sub level is -3.5 and 75 db spl on sonometer !
Many people in France, with pc,pb, the volume sub is 1/2 (12.00)..and it 's terrific with bass ! My system with 12.00 volume is very bad, without bass !
What do you think about ? and you which position in your PC ?
regards
vador84 is online now
post #20597 of 20603 Old Today, 01:48 AM
Gurba's Avatar
Quoted: 214 Post(s)
Liked: 102
^^ I have my PC-2000 on 3/4. I Guess you need to calibrate you sub. Just adjusting the gain isn't enough.
Gurba is offline
post #20598 of 20603 Old Today, 03:25 AM
vador84's Avatar
hi,
like me, you must turn to 3/4 with your Pc2000...
Svs is right, then...
On the notice, it's write between 10 to 12 h !!!! it's a error !
I thinked than 3/4 was very high...
Calibrate ? I haven't got antimode and the YPAO's Yamaha 2030, on the sub canal , none acoustic correction, he s doing... no room gain, the 2030 found ! strange
excuse me for my bad English !
post #20599 of 20603 Old Today, 04:00 AM
bear123's Avatar
Quoted: 521 Post(s)
Liked: 1026
I'm pretty confident your subs frequency response is not going to change over time.
post #20600 of 20603 Old Today, 04:09 AM
bear123's Avatar
Quoted: 521 Post(s)
Liked: 1026
Nashou
This is what I would do. I don't have dozens of placement options, so I just measured in all of the places where my sub possibly can be placed and chose the best spot that way. The subwoofer crawl won't be as accurate of a method....you might have a big peak at a certain frequency that makes it loud, or a seemingly good placement option, only to have a huge null that cannot be easily fixed in another.
Once you have found the best spot, run Audysey to compare your FR with your mains running. If you have a mess around crossover, you can try adjusting phase, distance, or crossover to adjust things.
Scale your graphs 45-105 dB and 10-200 Hz.
post #20601 of 20603 Old Today, 05:15 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 71
My EMP speakers came with a booklet that among other things, stated that loosening up of the woofers after break in will lead to more bass extension. That is what I would consider a change in frequency response.
I've also read many people say the output of their sub when it was new changed after break in. Anecdotal yes, but take it for what it's worth.
*Under Construction*
To: AVR-X4000, Chane A3rx-c, Rythmik L12 (2)
Samsung PN64H5000 Recommended Settings
post #20602 of 20603 Unread Today, 06:01 AM
bear123's Avatar
Quoted: 521 Post(s)
Liked: 1026
I've heard of these opinions as well. I have just never seen any facts to support it. I have seen facts showing that speakers/subs do not change measurably with use.
post #20603 of 20603 Unread Today, 06:26 AM
Bond 007's Avatar
Quoted: 547 Post(s)
Liked: 925
Wasn't a couple of pages just recently wasted on this?
Bond 007 is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
