Official SVS Owners/Support Thread. - Page 691 - AVS | Home Theater Discussions And Reviews
post #20701 of 20706 Old Yesterday, 06:01 PM
Teremei's Avatar
Quoted: 283 Post(s)
Liked: 157
Originally Posted by boobar View Post
Well my PC12-NSD arrived today and it is AWESOME!!!!! The one I got had a few slight wrinkles in the fabric around the outside but it smoothed right out when I rubbed my hand on it. Everything else looks like it should if the sub was brand new. I can't wait to put in a bass heavy blu ray to try it out.
Mine actually said it had "wrinkles" but honestly it looks so minor it's hardly something I'd complain about. The fabric actually looks new and it smells new. Mine was in extremely good shape for "used". I'm very happy with mine. What blu rays are you trying out? I've listened to some LFE but the ones that impressed me the most was actually just the soundtrack sections of Neverending Story and Jurassic Park. Be sure to report back!
Sony KDL-70R550A (passive 3D tv)
Denon x4000 (amazing sound correcting software)
Klipsch RF-62IIs (amazing horns)
Klipsch RC-62II (so clear)
Klipsch RS-41IIs (so full)
SVS PC12-NSD + Klipsch RW12d (so boom)
Teremei is offline
post #20702 of 20706 Old Yesterday, 06:58 PM
PWH1's Avatar
Quoted: 68 Post(s)
Liked: 238
Originally Posted by gene4ht View Post
Funny you should mention that!!! I'm thinking I'll do exactly that...replace my existing PSW10 with a PB-1000 in my secondary area...perhaps from the outlet store.
You will like it.... I have the same in my secondary setup. The PB-1000 is a very nice sub and performs exceptionally well in a smaller space. I gave my son one of the Klipsch subs I had and sold off the others. Paid for the PB-1000 and had enough left over for a cheeseburger...
gene4ht likes this.
Denon: AVR X1000
Klipsch: RF-82 II / RF-62 II / RC-62 II / RB-61 II
SVS: PB-2000 x 2
LG: 47LE5400
Panamax M5100-PM
PWH1 is offline
post #20703 of 20706 Old Yesterday, 07:21 PM
gene4ht's Avatar
Quoted: 51 Post(s)
Liked: 38
Thanks...I love those cheeseburgers!!!
Panasonic: PT-AE3000 Front Projector
Elite: 115" Fixed Frame CinemaScope (2.35:1)
Onkyo: TX-NR809
Klipsch: RF-82 II, RC-62 II, RS-52 II, RB-51 II, RB-41 II
SVS: PB-2000 x 2
Panasonic: DMP-BD85
gene4ht is online now
post #20704 of 20706 Old Yesterday, 10:20 PM
enoch861's Avatar
Quoted: 32 Post(s)
Originally Posted by Titan319 View Post
Both of my PC-2000's do the same thing they always go in stand by mode.
Sorry for the late reply, but in that case you might want to make use of the dual outputs and inputs of your receiver and subs respectively.
enoch861 is offline
post #20705 of 20706 Unread Today, 05:37 AM
bear123's Avatar
Quoted: 537 Post(s)
Liked: 1039
Originally Posted by Teremei View Post
it's just my personal opinion it's not silly. I like the idea of the air going straight down from the top. Just like you like your opinion of it is fine. I mean it's more like a box that happens to be cylinder shaped. Again I like the idea of how the air is pulled in in the old design.
This is not an air intake like on a car...the ports do not pull air in....at all. The purpose of the port is to provide OUTPUT. Having the port face the rear, toward a wall, can actually improve sound quality.
Also Teremei, I saw you posting about how tight? or crisp? you wanted your bass to sound. This is a product of in room frequency response. Download REW, preferably onto an HDMI laptop. You should be able to use your Audyssey mic to take measurements. This almost always helps get the subs set up properly prior to running Audyssey. Main thing is to try to eliminate nulls in your FR, which are not easily fixed with eq.
For Sale: PSA XV15se x 2 $675 each!!
http://www.avsforum.com/forum/209-au...-725-each.html
bear123 is online now
post #20706 of 20706 Unread Today, 07:04 AM
T0S
T0S's Avatar
Hello all,
Sorry to be take a contrary view to many here, but after adding a second PC-2000 and many hours of REW Room Sim followed by trying actual placement and REW measurements, I found I could not significantly improve bass frequency response or dynamics across the listening area.
And all attempts to go away from the single-sub-optimized set-up for the main listening position (which is all that is used 90% of the time and 100% of the time for critical listening) resulted in poorer performance at the main position!.
BTW, I comfortably get 110 +/- 3db to 17 hz with a single PC-2000 with <2% THD (as measured by REW) in my 3700 cu.ft. room - with plenty of headroom. I wonder how many folks are using REW to see how their set-ups are actually doing before simply symmetrically placing a second sub?
T0S is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
