Official SVS Owners/Support Thread. - Page 705 - AVS | Home Theater Discussions And Reviews
post #21121 of 21147 Old 04-16-2015, 12:14 PM
Mirage Fanboy
stikle's Avatar
Quoted: 129 Post(s)
Liked: 122
Originally Posted by joseph10704 View Post
all this time i been trying to say torx screw is what the svs pb13 ultra driver use's and then i get answers from everyone tell me no thats not it.Then i get you telling me its star when if you go on any video they call them str tor screw drivers the same thing that the svs pb13 ultra uses.So my thing is what screw is it if my info is not right when svs told me this info.then idk feels like people are messing with my head .Or i am just confusing the hell out of my own head lmao.
This is a Torx screw, what you called "star"
This is a Torx bit used to remove a Torx screw:
This is an Allen bolt, which is most likely what holds the SVS driver in:
And this is an Allen wrench, used to remove said bolt:
This is a Phillips head screw:
And this is what is used to remove it:
1c3d0g, iatacs19, DonRSD and 2 others like this.
Seth-o-Plex featuring Atmos 7.2.4! - LG | Denon | Onkyo | Mirage | SVS
stikle is offline
post #21122 of 21147 Old 04-16-2015, 12:29 PM
Bond 007's Avatar
Quoted: 634 Post(s)
Liked: 973
A hammer will remove all of those.
Bond 007 is online now
post #21123 of 21147 Old 04-16-2015, 12:55 PM
WarmongerX's Avatar
Well I bit the bullet and ordered the PB12+ last week. Got it yesterday and immediately started playing with it. I really liked the PB 2000 and almost stuck with it, however being the tinkering type that I am, I just had to find out if I was missing something. I talked to the SVS guys on 5 occasions burying them in questions over the course of a week trying to get different views on what I had and what I was looking to do. The last person I talked with, Brad, had some pretty in depth knowledge and took the time explain the differences of the PB12+ over the PB2000 and what I could end up doing with it in my space. I had some boominess in the PB2000 which REW showed was in the 35hz range. My receiver doesn't have the ability to tune that down, so I was either stuck with it or had to get a newer higher end receiver or try the PB12+.
I must say that I'm rather impressed with it over the PB 2000, which I didn't think would happen. Everything from the fit and finish to the actual sound. I wasn't super excited about the cost difference nor that it was actually larger than the PB 2000, if only by 1" taller, 2" wider and 3" deeper. However I ordered some 90 degree angle adapters for both the power and the LFE line which allowed me to put it closer to the wall and offset the difference in depth.
The ability of the PEQ to dial that 35Hz 6db down to a flatter looking curve made a big difference in the sound. I ran it in 20Hz mode and in 16hz. Right now I have it in 16 and I like it. I loaded up TV shows and Movies for a few hours and you quite literally feel it. I did on the PB2000 too, but not as much as this one. It's also a slightly cleaner sound.
I may play with the 20Hz mode next week, but I'm wondering what the differences are, if any, besides the obvious ability to play a little lower.
Best of all, it was delivered, setup and tuned all before the wife came home from work. I put the PB2000 in it's box back in the garage and we watched multiple shows last night...she never even noticed the newer sub, which was a slight point of contention when the PB2000 showed up due to it's massive size
Samsung 65" UN65ES8000FXZA
Pioneer Elite VSX23-TXH
Def Tech StudioMonitor 65 L/R - Def Tech ProCenter 2000 - Def Tech ProMonitor 1000 x 4 Surround
SVS PB12+ Subwoofer
18TB Plex Media Server
WarmongerX is offline
post #21124 of 21147 Old 04-16-2015, 04:03 PM
Bond 007's Avatar
Quoted: 634 Post(s)
Liked: 973
U da Man!
newfmp3 likes this.
post #21125 of 21147 Old 04-16-2015, 05:29 PM
retro124's Avatar
Quoted: 538 Post(s)
Liked: 344
Or semtex will remove all
I tought this is about subs not Home Depot lessons number 1
Denon X4000
Klipsch RF-82II's , RC-62II , RS-52II's , RB-81II's
SVS 2x PC12-Pluses
Sony XBR65X850B
Apple Mac mini, Sony PS3
retro124 is online now
post #21126 of 21147 Old 04-16-2015, 06:31 PM
Mirage Fanboy
stikle's Avatar
Quoted: 129 Post(s)
Liked: 122
BWAHAHA. My favorite explosives related fun-fact: det cord burns at 4 miles per SECOND.
It is, but someone was giving incorrect information on what tool to buy to remove an SVS driver. So it IS sub related.
joseph10704 likes this.
stikle is offline
post #21127 of 21147 Old 04-16-2015, 06:35 PM
retro124's Avatar
Quoted: 538 Post(s)
Liked: 344
I know I been reading it all, Just you put such a nice and detail info it is why I got that idea about HD lesson
I'm totally fine with it no worries.
Denon X4000
SVS 2x PC12-Pluses
Sony XBR65X850B
post #21128 of 21147 Old 04-16-2015, 06:37 PM
PWH1's Avatar
Quoted: 71 Post(s)
Liked: 245
Originally Posted by valkenaar View Post
Have been loving my SB-2000 for the last few weeks. Definitely noticed an "improvement" in sound after about a week of break-in (see below).
I was going about another iteration of covering/limiting the front-facing LED and noticed how low the cabinet was sitting in my carpet. I had to lift the front edge to remove the grill since it was stuck in the carpet. Now - this is a front-firing woofer but I wondered if there was any problem with it sitting "in" the carpet.
Should I go through the trouble of getting extenders to lift it up or will the difference be minimal?
Oh - how did I notice the sound improvement after break-in? I was watching the same movie, same volume (my favorite volume setting), same Audyssey settings, etc., and I noticed various items around the room were now vibrating/buzzing during parts of the movie. I guess I wasn't imaging that extra "thump" I thought I felt. ;-)
While I have PB 2000's I had a similar situation. Their are varying opinions on the subject, but I purchased 2 Auralex SubDudes to place my subs on. The grills now easily clear the carpet which eliminated the upward pressure on the grill pins and they look like they are floating... I also feel that the SubDudes reduced vibration transfer being created by them being directly on the floor. They produce hard hitting clean bass with the residual vibrations being eliminated.
Denon: AVR X1000
Klipsch: RF-82 II / RF-62 II / RC-62 II / RB-61 II
SVS: PB-2000 x 2
LG: 47LE5400
Panamax M5100-PM
PWH1 is offline
post #21129 of 21147 Old 04-16-2015, 07:04 PM
PWH1's Avatar
Quoted: 71 Post(s)
Liked: 245
I have been away traveling so I have just been catching back up on the thread..... I must say after all this screwing discussion I fired up a cigar, poured a snifter of glenlivet 18, fired up the SVS Subs and feel quite satisfied.
Denon: AVR X1000
SVS: PB-2000 x 2
LG: 47LE5400
Panamax M5100-PM
PWH1 is offline
post #21130 of 21147 Old 04-16-2015, 07:27 PM
joseph10704's Avatar
Quoted: 122 Post(s)
Liked: 51
Originally Posted by pwh1 View Post
i have been away traveling so i have just been catching back up on the thread..... I must say after all this screwing discussion i fired up a cigar, poured a snifter of glenlivet 18, fired up the svs subs and feel quite satisfied.
hahahahahha thats priceless
joseph10704 is online now
post #21131 of 21147 Old Yesterday, 05:59 AM
Titan319's Avatar
Quoted: 194 Post(s)
Liked: 56
Here is a link look under tech specs http://www.svsound.com/subwoofers/ported-box/pb12-plus
Titan319 is offline
post #21132 of 21147 Old Yesterday, 06:27 AM
WarmongerX's Avatar
I bought a set of the SoundPath Isolation feet and did notice a difference right away, boominess and vibrations reduced substantially. There are still a very small vibration at moderate to higher volumes, but I don't think you could eliminate it completely unless you have a dedicated, properly built room or you just don't listen these subs the way they were meant.
SVS PB12+ Subwoofer
post #21133 of 21147 Old Yesterday, 10:05 AM
awardb's Avatar
Quoted: 18 Post(s)
Originally Posted by Mongo171 View Post
Wow. OK. I really don't know how to respond to this. It is obvious that you have no electronics training and no idea how a speaker works. A sine wave is introduced into the voice coil which then interacts with the magnet to move the cone to reproduce the sine wave as a sound humans can hear. The "thunk" or "pop" you describe is what I have described in my last post. Those are the cone reaching its max excursion, in or out. A DC voltage does not create a "sound" from the speaker. The speaker makes a noise.
As far as the 1/4-20 screwdriver thingy, ain't no such thing. More than likely, a No. 1 screwdriver will work.
Sheesh. Sound. Noise. Whatever. I completely understand how sound works (I've been in the home hifi/custom installation field for over 40 years). When you touch the 9V battery to the speaker leads, it causes the woofer cone to move one way or the other to full excursion. This causes a "sound" or "noise" to emit from the woofer. A "thunk" as I called it. I certainly know the difference between AC and DC. When you touch the battery to the leads, it makes a NOISE. Or a SOUND. Whichever you want to call it. This is exactly what I was telling the OP.
Sony Qualia 006 / Marantz AV8801 / Emotiva XPA-5 / Oppo BDP-103 / Paradigm Studio 40v2 / Paradigm Studio CC490 / Paradigm ADP190 / SVS PC12-NSD x2 -- "Begin at the beginning and go on till you come to the end; then stop." --Lewis Carroll
awardb is online now
post #21134 of 21147 Old Yesterday, 10:17 AM
awardb's Avatar
Quoted: 18 Post(s)
One more thing:
From M-W.com -
Noise
: a loud or unpleasant sound
: a sound that someone or something makes
As I clearly said in my post whereby I claimed that touching a 9V battery to the woofer terminals would cause the woofer to emit a "sound" or "noise".
I rest my case.
post #21135 of 21147 Old Yesterday, 10:19 AM
dkami712's Avatar
Quoted: 175 Post(s)
Liked: 114
The last few pages just about sums up the AVS forum as a whole
Emotiva XMC-1
RF-82
RC-62
RS-62
RB-81
dkami712 is offline
post #21136 of 21147 Old Yesterday, 10:51 AM
lflorack's Avatar
Quoted: 55 Post(s)
Liked: 51
And if you don't think there is a 1/4-20 screw here is a picture of what one looks like and the right name for that screw driver is i think a tork screw driver.
OK as a former machinist and tool and die maker, I'll tell you (and others) that 1/4-20 refers to ANY screw that is 1/4" (.25") in diameter with 20 threads/inch. A 1/4-20 screw can be any length and have just about ANY type head (pan, round, flat head, etc), and drive style (straight slot, hex, torx, Phillips, etc). Again, 1/4-20 only designates the diameter and pitch of the screw. Therefore, there is no such thing as a 1/4-20 screwdriver because the diameter and pitch of the screw in no way tells you anything about the screw head or drive style. The picture you showed in 211212 is a hex head (not Torx) and you'd use an Allen wrench for it.
Note: Looks like I should have read a bit farther ahead before posting because it appears what I posted has been covered already.
Links: System Diagram / System Pix
Klipsch: (2) RF-83, (1) RC-64, (2) RVX-54, (2) RSX-5, SVS: (1) SB13-Ultra
Yamaha: Aventage RX-A2010, CDC-685, Samsung: UN55B8000, Oppo: BDP-93
Apple: AppleTV, Roku: Roku3, Amazon: FireTV Stick, Roomie: Roomie Remote
ACP: J15BLK 1.5 kVA Power Conditioner/UPS, CinemaQuest: Ideal-Lume Std
See links for system details.
lflorack is online now
post #21137 of 21147 Old Yesterday, 11:00 AM
valkenaar's Avatar
Really?!? I usually find it quite useful. This has been an entertaining diversion, easily ignored. It is getting a bit stale, though. ;-)
Do you have another source you depend upon?
Panasonic P60ST60
Sony BDP-S3100
Denon X2000
valkenaar is offline
post #21138 of 21147 Old Yesterday, 11:01 AM
Mongo171's Avatar
Quoted: 423 Post(s)
Liked: 934
I think this horse has been explained enough and dead for a while.
Mongo171 is online now
post #21139 of 21147 Old Yesterday, 12:14 PM
Mirage Fanboy
stikle's Avatar
Quoted: 129 Post(s)
Liked: 122
Hey...it's my right to get hung up on minutiae.
Thank you for chiming in. I've always wondered what that designation actually meant, I just didn't ever take the time to actually find out. I don't recall that from my metal/wood shop days in high school 30 years ago.
stikle is offline
post #21140 of 21147 Old Yesterday, 01:50 PM
lflorack's Avatar
Quoted: 55 Post(s)
Liked: 51
You are welcome.
post #21141 of 21147 Old Yesterday, 05:45 PM
Quoted: 16 Post(s)
Liked: 3
Hi folks,
I will be building a new home theatre room in few months time. It will be 21 x 15 x 9 in room size (2835 cubic foot). Will 1 x PB-2000 do a good job?
powersquad is offline
post #21142 of 21147 Old Yesterday, 07:38 PM
retro124's Avatar
Quoted: 538 Post(s)
Liked: 344
Originally Posted by powersquad View Post
Hi folks,
Yes it will ok but it is pretty nice size room I will look dual and better subs if budget allow you to do so. If not and one sub is your option I will try to get the best you can.
Denon X4000
SVS 2x PC12-Pluses
Sony XBR65X850B
post #21143 of 21147 Old Yesterday, 07:42 PM
Quoted: 16 Post(s)
Liked: 3
Thanks. I purchased the SVS PB-2000 along with rest of the Ultra line up speakers (towers, surrounds and centre) last year in NZ when it was on special and it has all been sitting packed on a pallet in my garage. Now that I have confirmed measurements for new home theatre room for new house build, I wanted to ensure PB-2000 will be no slouch. If I added a 2nd PB-2000 later down the track in the same room, will that be more than enough for this size room?
TomC1315 likes this.
post #21144 of 21147 Old Yesterday, 07:57 PM
retro124's Avatar
Quoted: 538 Post(s)
Liked: 344
One will be ok for sure PB-2000 is great sub it is just if you can and have option to do so. Every person is different and want different result, some want in 800sq PB13-Ultra other are fine with SB-2000 in 4000sq it is all about personal preferences. I will try it first just one sub enjoy it for while and then if you need more bass you can add second as you said. It will be nice step up and you will enjoy different more then if you add second now and place it in garage for later.
Looks like you will have great HT room and amazing set up there.
Denon X4000
SVS 2x PC12-Pluses
Sony XBR65X850B
post #21145 of 21147 Old Yesterday, 07:59 PM
jwtallguy's Avatar
Quoted: 88 Post(s)
Liked: 35
Enough just depends on how loud you want to listen. My room is a little bigger by a few feet and I have dual ultra 13s set at 16hz time and I still crave for more at times
jwtallguy is online now
post #21146 of 21147 Unread Today, 09:28 AM
Quoted: 122 Post(s)
Liked: 51
you have ultras sub is it pb or sb ultras.And you still sometime crave for more power lmao that is cool and funny at the same time.what ultras do you have tho.
post #21147 of 21147 Unread Today, 09:40 AM
retro124's Avatar
Quoted: 538 Post(s)
Liked: 344
If he is able to set Ultra to 16hz it will be ported one PB/PC.
Denon X4000
SVS 2x PC12-Pluses
Sony XBR65X850B
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
