Official SVS Owners/Support Thread. - Page 725 - AVS | Home Theater Discussions And Reviews
post #21721 of 21731 Old Yesterday, 08:02 PM
joseph10704's Avatar
Quoted: 205 Post(s)
Liked: 95
Originally Posted by SchattenJager View Post
I was doing some tests with my PB13U and got it to ~109dB on a 20Hz test tone. Master volume was set to -15dB. Heard some heavy reverberations that sounded like a jackhammer, which was probably the room, but want to make sure I wasn't bottoming it out. Do you think that output is safe?
I had the volume levels set to -3db on my sledge amp for my Ultra and my avr was set to -3 aswell.And i can say that subwoofer was PUMPING SOME SOUND'S.So i would not worry about how hard you play it worry about who is hearing it lmao.None the less i played my volume level on my receiver at -10 reference sound.IT WAS MIND BLOWING.I MISS MY ULTRA!!!!!
joseph10704 is offline
post #21722 of 21731 Old Yesterday, 08:04 PM
SchattenJager's Avatar
Quoted: 25 Post(s)
To calibrate, should I use the sledge amp's built in P-EQ based on my readings first, or just let MultEQ XT handle it?
SchattenJager is online now
post #21723 of 21731 Old Today, 12:04 AM
tommaazz's Avatar
Quoted: 119 Post(s)
Liked: 71
Originally Posted by joseph10704 View Post
My mind is still debateing if it's worth buying dual PB-2000S over buying 1 PB-13 Ultra again.To be far if i buy a pb-13 ultra gain.I don't see me going dual with the ultra as that's subwoofer is a beast of it's own.But everyone is telling me different that haveing dual is better then 1 sub.I was thinking about dual PB-12 PLUS'S.But at this point spending 2,649.99 for sub's s a little bit over my budget.Infact i don't even know what the right budget really is.My mind want's to buy a plus just to see how low it can still get from a ultra .But then my mind is like maybe dual pb-2000s would still shake the house down.Then my mind is like **** it let me buy again the ultra lmao.
If i were you i would buy a dual pb12+ you will still have more output than the ultra and also the benefit of duals...if i had a place i would have a dual pb12+...but now i have dual sb13 ultras (i had dual sb12 before) which are still pretty good and can hammer very well if i want them to but when i had one sb13ultra i thought i would never buy another ultra as one was enough and it was pricey here in Europe...but you know that when you go dual you can never look back at one again...so i just wanted to tell you that pretty soon you will buy another ultra if you get one now ...go for dual pb12+ you will be more than happy... i am done for upgrading subs for a very long time
retro124 likes this.
Marantz sr7008, monitor audio bx6,bx center,bx fx,bx1,sub SVS sb13ultra (2x), panasonic 60asw654
tommaazz is offline
post #21724 of 21731 Old Today, 12:52 AM
januza's Avatar
Quoted: 57 Post(s)
Liked: 40
I run mine very hot then. -12 on sledge and -3 on AVR for both my ultras.
I need to do REW soon as I have a crap living room with big windows, high ceilings, just lots of crap. Haha
januza is offline
post #21725 of 21731 Old Today, 08:04 AM
Quoted: 205 Post(s)
Liked: 95
try running the sledge amp at -3 then the AVR at -3 trust me you will be happy then set the speakers you have to small and make sure all of the speaker crossover levels are at 80htz then for the bass set that crossover to 120 htz.Trust me you will have the ride of your life.just make sure you follow the setting's i gave to you.And yeah it's going to be one hell of amout of bass.smooth chrisp bass and it wont even hurt in the ear's.
post #21726 of 21731 Old Today, 10:58 AM
alwaller's Avatar
PCI 20-39 SVS sub
Hi all
I have a older model SVS sub, the PCI 20-39, would turning up the gain on the sub or the volume on my receiver get the sub more punch?
alwaller is online now
post #21727 of 21731 Unread Today, 11:29 AM
CCSchoch's Avatar
Quoted: 58 Post(s)
Originally Posted by alwaller View Post
Hi all
I used to have the PCI 20-39 and LOVED it. Not sure what you mean by more punch, assume you mean volume. When talking with SVS customer service, think it was Ed, I remember him saying it's a good idea from your AVR to send it a clean signal, around -3 to -5 and then turn up the gain at the sub. That way it's getting a good clean signal from the AVR and letting the AMP on the sub do the work.
From memory, I think my gain was set about 12 - 1 o'clock (it is a turn knob, correct?)
CCSchoch is online now
post #21728 of 21731 Unread Today, 11:42 AM
eljaycanuck's Avatar
Quoted: 361 Post(s)
Liked: 758
.. I have a older model SVS sub ... would turning up the gain on the sub or the volume on my receiver get the sub more punch?
It should, and the easiest way to find out is to try it.
eljaycanuck is offline
post #21729 of 21731 Unread Today, 11:57 AM
alwaller's Avatar
CCSchoch
Thanks for your reply, I going to change to the levels you gave and see if their is any improvement.
I will let you know the results.
post #21730 of 21731 Unread Today, 12:34 PM
AllenA07's Avatar
Quoted: 172 Post(s)
Liked: 174
Hi all
Might as well try, SVS love their limiters so it isn't like you're going to be able to do any damage to the sub.
AVR: Denon 2112
Speakers: EMP Tek e55ti, Center- EMP Tek e56ci, Side Surrounds- EMP Tek e55wi, Rear Surrounds- SVS Prime Satellites, Sub- SVS PC-12 Plus, SVS PC-13 Ultra
Display: BenQ w1070 on a 110in fixed screen
Blu-Ray Player: Sony BDP S6200;
Playstation 4
AllenA07 is online now
post #21731 of 21731 Unread Today, 01:58 PM
alwaller's Avatar
Cool Worked great
CCSchoch, eljaycanuck, and AllenA07
Thanks guys, the change in my setting were right on point.
Thanks for the fast replies, I am back to how a SVS sub should sound.
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
