Official SVS Owners/Support Thread. - Page 727 - AVS Forum | Home Theater Discussions And Reviews
post #21781 of 21810 Old 07-15-2015, 06:48 PM
Ahzari's Avatar
Quoted: 44 Post(s)
Liked: 42
Running my dual SB2000s for about 6 months now, unfortunately one of the amps malfunctioned so im getting a replacement amp sent out. Once this happened I started getting the itch to upgrade to the SB 13 Ultra.
I know the downside to having a single sub over 2 is the headroom.. but has anyone experienced the 2 vs 1 and enjoyed the Ultra more - is it sonically way superior to the 2000s to warrant going from dual to single subs?
Appreciate the thoughts.
Audio: Yamaha A-S1000 Stereo Amp // Kef LS50s // 2x SVS SB2000
Analog:Pro-Ject RM5.1SE Turntable // Pro-Ject Tube Box II SE Phono Amp // Pro-ject Speed Box II
Video: Samsung 65in HU9000 4k // Oppo BDP-105 // Apple TV (3G)
Power: Furman PST-8 AC Power Conditioner
Ahzari is offline
post #21782 of 21810 Old 07-15-2015, 07:47 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
I went from 1 PB13 Ultra to 2 PB13 Ultra.. There is a difference in sound and punch but far less than I expected.
I have them installed in the living room so cannot experiment with sub placement unfortunately
joseph10704 likes this.
januza is offline
post #21783 of 21810 Old 07-16-2015, 03:21 AM
TomC1315's Avatar
Quoted: 108 Post(s)
Liked: 128
I had a pair of SB2000s last year for a while, and in the end, ended up with the SB13ultra ... however, after returning the pair of SB2000s, I auditioned a PC12+ and then a PC13ultra, before ultimately deciding on the SB13U ... so therefore, I was unable to compare the two side by side.
That being said, I couldn't be happier with my choice of the SB13U ... I found good spot to place the single sub which provides me with satisfying bass through out our large living area (5500 cu.ft. living room and an adjoining kitchen), with power to spare.
I'll admit, however, that I've wondered occasionally how the dual SB2000s would fare in our new home compared to the SB13U, after reading so much about the advantages of dual subs here. Fortunately, whether it's the sofa (MLP), the computer desk, dining room table, or even most areas of the kitchen, the bass response from my single sub sounds (without, admittedly, REW measurements) great ... I'm familiar enough with my music that if the single SB13U wasn't getting it right, I'd know.
How's the bass response appear to you with the single SB2000? Is there a good spot in your living area where a single sub performs well? If so, I'd recommend you consider the sealed Ultra.
MartinLogan Motion 40s / 30 / LX16s
Marantz SR5007 / UD5007
Emotiva XPA-3
SVS SB13ultra
exercise room: MartinLogan LX16s / Dynamo700
TomC1315 is offline
post #21784 of 21810 Old 07-16-2015, 03:50 AM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
Hi. I went the route of having dual sb12nsd then single sb13ultra and now i have dual sb 13 ultra ...i will say this again...in my room there was no comparison between 2xsb12 vs sb13 ultra...the ultra is just so much better sub that when i turned it on it was hitting like a hammer really to me there was a night and day difference especially i like it much more in movies than 2xsb12...try it out and you will be very happy with ultra...rather sb13u tha 2xsb2k ...no comparison
Marantz sr7008, monitor audio bx6,bx center,bx fx,bx1,sub SVS sb13ultra (2x), panasonic 60asw654
tommaazz is offline
post #21785 of 21810 Old 07-16-2015, 09:34 AM
kluken's Avatar
Quoted: 119 Post(s)
Liked: 145
How big was your listening space. I am debating the ported vs. sealed right now and all the concerns about deep lows with sealed has me concerned. I want to fell the bass.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Klipsch RP-280F / RC-62ii / RS-35 / RS-25
SVS PC13-Ultra
kluken is online now
post #21786 of 21810 Old 07-16-2015, 10:46 AM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
Mi listening space is around 1600 cubic feet...i had before a ported mirage omni s12 (it was no slouch) and it sounded boomy in my room that is why i didnt like it...the ultra sound much much better...it can shake if it want and it is never distracting...i am very happy with it...awesome ☺ i just wanted dual for smoothening because even with one and my listening habbits the ultra never gave up...but once you have dual you can never go back at one ...i listen to movies at around -15 and have 5db hot sub level
tommaazz is offline
post #21787 of 21810 Old 07-16-2015, 12:23 PM
sinisanav's Avatar
Quoted: 88 Post(s)
Liked: 73
Man, they must be frightening when Ultras start pounding.
I have dual SB-2000 in 1500 cubic ft dedicated, basement space and they rock the place, and when I close the door they pressurize it well. I also tend listen to movies/concerts at -15, never above that but I do NOT run the subs hot.
Kluken, how big is your space, I think if if it is less then 1800 cu ft you should go sealed.
Change is the only constant.
My HT: http://www.avsforum.com/forum/19-ded...l#post32691273
sinisanav is offline
post #21788 of 21810 Old 07-16-2015, 01:19 PM
Ahzari's Avatar
Quoted: 44 Post(s)
Liked: 42
So when I had a single SB2000 it was underwhelming. I then tried the PC2000 and it was awesome in terms of impact but did not blend well with my Kef LS50s. I did notice with the PC2000 I was getting some dead zones in my 1900 cu ft room with a large entrance into the dining room. Thats the worry I had with the SB13U the dead space, but I figured maybe down the line I would be crazy enough to go dual SB13U..
I guess better question is, between the SB2000 and the SB13U is there a discernible difference in quality of sound reproduction.. A lot of reviews I have read were stating with the SB2000 being such a huge upgrade to the SB12s they were nipping at the heels of the SB13U.
Thanks for the comments.
Ahzari is offline
post #21789 of 21810 Old 07-16-2015, 01:33 PM
sinisanav's Avatar
Quoted: 88 Post(s)
Liked: 73
How big is the dining room? If it is open connection without the door then you need to add cubic space of the booth rooms to the total space that subs are working with, if it is more then 3000 cu ft then yes, one SB2K would not suffice. Duals rule as far as smoothing out effect.
I have not heard SB13U, so I can not compare, but I know I am extremely sattisfied with SB2K compared to Def TEch Supercube I( built in in my L and R towers). Much more extension down to single digits Hz, very fast, good transient response, no boom, working well with both music and movies ( in 1500 cu ft space)
post #21790 of 21810 Old 07-16-2015, 05:29 PM
kluken's Avatar
Quoted: 119 Post(s)
Liked: 145
My room is about 2300 cu ft, enclosed with single 30 mch wide opening near back of room.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21791 of 21810 Old 07-17-2015, 04:59 AM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
You can try running pc13 in sealed mode and see how you like it? That would be roughly the same as sb13
tommaazz is offline
post #21792 of 21810 Old 07-17-2015, 05:03 AM
kluken's Avatar
Quoted: 119 Post(s)
Liked: 145
Doh, I forgot about that. Now hopefully I can find my port plugs ;-)
tommaazz likes this.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
SVS PC13-Ultra
post #21793 of 21810 Old 07-17-2015, 05:10 AM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
I also cant comment on sb2000 sound vs sb13...but the sb12 is not nearly as good as sb13...also the sb2000 does not have much higher spls when compared to sb12 so the ultra still have a lot of headroom left especially above 25hz...the sb13 is a different animal as the svs subs below it...i tried running the one sb13u amp on -5 and avr volume at -10. ..Just for fun on music...and believe me in my room the floor and the windows were shaking and i got that slam in the chest feeling...that was with one...in think is hard to reproduce that with sb2000...i also have to say that the ultra was hammering like it wanted more not a single bad sound just pure deep bass...incredible
tommaazz is offline
post #21794 of 21810 Old 07-17-2015, 06:42 AM
k1n3t1k's Avatar
Quoted: 44 Post(s)
Liked: 82
I had 2xSB13U for about 14 months before I bought an Anti-Mode 8033S-II. What a world that little device makes! What AVR are you using? It helped with the low voltage output of my Yamaha receiver and in the 15-20 minutes for calibration, the time alignments were impeccable and tamed my room nodes and nulls with aplomb. The house rattles a lot more now and the bass is incredibly punchy. It was 'sufficient' before, but this is an entirely different level.
You can achieve similar results with a Mini-DSP and a UMIK with REW, but it does take a bit of time to get things going if you're a novice with it. If you have a receiver with the Audyssey SubEQ on it, you should be set. My Yamaha 3040 with "sub calibration" is pretty sad and didn't do much of anything in this regard.
Travis
k1n3t1k is online now
post #21795 of 21810 Old 07-26-2015, 06:12 PM
bxbigpipi's Avatar
Quoted: 33 Post(s)
Liked: 33
This thread has been mighty quiet for 9 days now, hope that's because everyone is enjoying their subs.
bxbigpipi is offline
post #21796 of 21810 Old 07-26-2015, 06:49 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
5db hot sub means 5db over audessey? or +5 on the SVS sub?
januza is offline
post #21797 of 21810 Old 07-26-2015, 07:54 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
Travis
Hey Travis
This is very interesting.. I have an ONKYO 818 but im not happy with the sound of my 2PB13Us... U think I should invest in a Anti Mode.. My AVR does have Audyssey MultEQ XT32, but again im not liking the sound.. maybe its my living room but I feel the bass is too boomy..
januza is offline
post #21798 of 21810 Old 07-26-2015, 08:35 PM
Briant73's Avatar
I have a pc12-nsd subwoofer, tonight I wasn't hearing bass, turned if off and on and about ten seconds later I heard bass then nothing (power flickered also), checked and the green power light was off. Did a bit of research and saw there was a fuse that can be replaced and should be a spare one but didn't see a spare but had some radio shack 2amp slow blow fuses, turned back on and it shutoff immediately and another blowing fuse. Any advice on fuse type or do I have a serious issue with the amp?
Briant73 is online now
post #21799 of 21810 Old 07-26-2015, 08:51 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
Call SVS for help.. they cant help u fix the problem immediately
januza is offline
post #21800 of 21810 Old 07-26-2015, 08:57 PM
Briant73's Avatar
I wrote them an email tonight but thought I'd post here also to see if anyone else had experienced this issue.
post #21801 of 21810 Old 07-26-2015, 09:06 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
good luck.. keep us posted
Janus
januza is offline
post #21802 of 21810 Old 07-26-2015, 09:23 PM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
5db hotter than audyssey sets it...the ultra amps are at -24 at all times...audyssey sets one at -10.5 and the other at -7.5...now i have it at -5.5 and -2.5 db on avr...i also listen with dynamic eq on but i set the offset at -5 db...i find it is the best setting for movies and also sounds great with music and that way the surround boost is less pronounced
tommaazz is offline
post #21803 of 21810 Old 07-26-2015, 09:34 PM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
Hey Travis
If you have xt32 you are good to go...but i am affraid that onkyo 818 doesent have subeqHT for calibrating two subs independetly...i think it is the only xt32 receiver that doesent have subeqHT...it is calibrating both subs as one but with subeqHT it sets each subs independetly and than meassure it as one...i like the sound of the sealed sub in my room better than ported and the same thing is with my brother (he has 2xsb12) ...we both find the ported subs sounded boomy in our rooms...try running pb13 in sealed mode and see how you like it...it is free ...but dont forget to change the amp tuning if you will try it
tommaazz is offline
post #21804 of 21810 Old 07-26-2015, 09:42 PM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
Oh...and one more thing...i am back from summer vacation and i cant wait to enyoj my ultras in movies and music after eleven days...
tommaazz is offline
post #21805 of 21810 Old 07-27-2015, 10:49 AM
k1n3t1k's Avatar
Quoted: 44 Post(s)
Liked: 82
Hey Travis
Have you ever used REW with a mic to measure frequency response? There's a good chance you may be getting some room modes that is causing the sound to be undesirable. My problem was not with FR, but with the tactile responsiveness/clarity of the bass notes. I looked up your 818 and it doesn't seem to list the subwoofer pre-out voltage, but your regular pre-outs are 4.6V. I'm willing to bet you may have something else going on, but it's hard to say without seeing FR on a graph.
If you don't want to fuss with REW or calibration mics, I would definitely check out the Anti-Mode devices. They aren't cheap, but it's nice to know you went the extra mile to get the most out of your purchase. What is $400 when you already have >$3K vested in low-frequency reproduction?!? To me, it's like buying a nice sports car and not using premium fuel. At the very least, post-calibration, you know if it was room characteristics or something else that is making your SVS sound sub-par. I would strongly encourage you to buy from powersoundaudio.com as they offer hassle-free returns if you don't like it or find it didn't change much for the better.
As @tommaazz already mentioned, your receiver doesn't have the SubEQ portion of Audyssey calibration. Assuming that it is a FR issue you're battling, theoretically, SubEQ would resolve it, just like the Anti-Mode should. My twin SB13U are 'boomy' in my room without calibration as I get a huge 12dB jump at 42Hz and makes movies over the top and to the point where you can't really hear dialogue as clear! I also get a deep null at 56Hz without calibration. Anyway, as he also mentioned, try running your subs in sealed operation as that should change the characteristics to reduce the bottom end output. See here for a visual.
Travis
post #21806 of 21810 Old 07-27-2015, 05:22 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
I havent taken the time to do a REW... It seems pretty complex to get done... Could be that I will try the DSP Anti Mode and have that bad boy do the tuning for me..
januza is offline
post #21807 of 21810 Unread Yesterday, 12:13 PM
broodro0ster's Avatar
Liked: 0
Is Dynamic EQ on? If so, set the offset lower or turn it off. That makes the sub also boomy.
broodro0ster is offline
post #21808 of 21810 Unread Yesterday, 01:10 PM
januza's Avatar
Quoted: 70 Post(s)
Liked: 43
Dynamic sound is off. Talked to Ed Mullen he already recommended to switch to sealed.
I did that yesterday and watched Area 9 and there was quite an improvement. But still considering to try the anti mode. Should I run Audyssey again after changing the subs to sealed ?
januza is offline
post #21809 of 21810 Unread Yesterday, 01:15 PM
tommaazz's Avatar
Quoted: 128 Post(s)
Liked: 75
yes unfortunatelly you have to run audyssey again...
tommaazz is offline
post #21810 of 21810 Unread Today, 10:40 AM
k1n3t1k's Avatar
Quoted: 44 Post(s)
Liked: 82
I have never owned a receiver that has Audyssey. /dodges tomatoes
How long does it take to run? Does it vary between XT32/SubEQ and other Audyssey flavors? My Yamaha A3040 takes probably 3 minutes to run YPAO if I skip the angle measurements using the boomerang device.
Everything I have read is if you use an external calibration device, whether it is a MiniDSP, Anti-Mode, etc, you always re-run your automatic correction program after. Correct me if I'm wrong, but the theory is to leverage more resolution ability. If my receiver can only calibrate the subs on 4 different frequencies, then using the Anti-Mode's 36 filters to pre-correct the response allows for more of a "flattening potential" to the correction after the fact.
Travis
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
Gear in this thread - Sb1000 by PriceGrabber.com
