Official SVS Owners/Support Thread. - Page 770 - AVS Forum | Home Theater Discussions And Reviews
 2862Likes
Old 02-03-2016, 01:03 PM
k1n3t1k's Avatar
Quoted: 127 Post(s)
Liked: 226
Originally Posted by ceh383 View Post
Looking at that graph and strictly for music, I think I would opt for the PB. Music doesn't stop at 60hz, think about the lower register of a piano, all the way down to 27.5hz. At that point the SB is nearly 10db down
Tell. Me. About. It!!! Dual SB13U here and like I mentioned earlier, the SB isn't bad for movies, not even close. But if you wanna feel that super ULF, look elsewhere. Hindsight is always 20/20 and I don't regret my purchase one bit, but knowing what I know now, it would have bought dual PB13U simply to have my cake and eat it too.
Travis
k1n3t1k is offline
Old 02-03-2016, 01:52 PM
rhale64L7's Avatar
Quoted: 694 Post(s)
Liked: 235
Thanx for all the info folks. I need to really consider my purchase. I tell you I do watch movies at reference level. But I never run my subs hot.
rhale64L7 is offline
Old 02-03-2016, 02:00 PM
mthomas47's Avatar
Quoted: 1304 Post(s)
Liked: 1410
That's interesting! I can't really enjoy extremely loud volumes, in general, but I do like plenty of bass in movies, so I run my subs very hot. Do you leave your sub levels wherever your AVR set them?
mthomas47 is offline
Old 02-03-2016, 02:50 PM
bear123's Avatar
Quoted: 1447 Post(s)
Liked: 2037
Originally Posted by AllenA07 View Post
Bear, my understanding is that sealed subs have the advantage as you approach and exceed 60hz and up. Wouldn't this still make sealed a better bet if you're looking for a sub for mostly musical applications?
More commonly, the equivalent ported sub will actually have slightly more output across the entire frequency range due to the efficiency of having a larger cab. Now in the case of the SB13 Ultra and PB13 Ultra, the SB has a small advantage in maximum output up top. This is uncommon like I said due to the fact that given the same or very similar drivers and same power amp, the ported sub will usually maintain an output advantage full bandwidth.
I agree that sealed subs are better for music only applications, because they are smaller and cheaper. I am not against sealed subs at all. My room is 60/40 movies/music and I have two sealed subs. But, I have reference capability full bandwidth. If I could not hit reference down to 16-20 Hz with sealed, I would be using ported to do so.
bear123 is offline
Old 02-03-2016, 03:13 PM
bear123's Avatar
Liked: 2037
Based on this, I would definitely start with a single PB13Ultra. You will need a 2nd to play reference level cleanly.
bear123 is offline
Old 02-03-2016, 03:27 PM
rhale64L7's Avatar
Quoted: 694 Post(s)
Liked: 235
Yes
Old 02-03-2016, 03:30 PM
rhale64L7's Avatar
Quoted: 694 Post(s)
Liked: 235
Ok my plan is two subs. Can I get to reference cleanly in a 2700 cuft treated room with two sealed subs?
Old 02-03-2016, 03:33 PM
mthomas47's Avatar
Liked: 1410
With two SB-13's, I would say yes. If you have been reaching Reference volumes with adequate bass in the past, what do you have now?
Edit: I will defer to Bear's answer below on the question of whether two Sb-13's will reach Reference. But I had to go back several days in the thread to refresh my memory about the original question. I think that if you want to listen at Reference levels, and particularly considering the recent discussion of sealed subs, you should probably just start with PB's. I would be shocked if those didn't give you enough bass, and especially so, if you don't generally raise your sub trim from where your AVR puts it.
Old 02-03-2016, 04:14 PM
bear123's Avatar
Liked: 2037
Not with anything SVS offers, no(not even remotely close). You need to hit 115 dB minimum, not including bass redirected to the subs from all your other channels. Gonna take two capable 18's to do that. Perhaps two F25's would do it. Dual Seaton Submersives likely would hit reference as well. Other than that, it's going to take 18's to get clean reference with two sealed subs.
Two PB13 Utlra's would do it, or 8 SB13 Ultras. 4 SB's might get you close, but not quite I'd say.
bear123 is offline
Old 02-03-2016, 04:56 PM
rhale64L7's Avatar
Quoted: 694 Post(s)
Liked: 235
I should add that this is a totally sealed room. My old mfw15 held up pretty decent but would not give me the the shake when t-rex was walking.
Ok another question. Would two sealed subs be much better than what I already had?
Old 02-03-2016, 05:18 PM
mthomas47's Avatar
Liked: 1410
Looking at a review of that sub, and comparing it to DataBass numbers for the SB-Ultra, I would say that the two SB's would slightly outperform the MFW-15 at a nominal 20Hz. But the difference would be slight. Two PB's on the other hand would outperform either of the other two options by a huge margin.
No offense, but I am a little unclear why you are still so focused on two sealed subs. I understand it better when someone is trying to obtain the best possible music quality, although opinions are very divided on that. People have not, apparently, had much luck in recognizing the difference in blind tests. I'm not saying that there can't be a difference--just that it might be pretty subtle. But in this case, where you want to watch movies at Reference volumes, it does seem to me that the safer path would be to go with two ported subs. Frankly, two PB-Pluses would outperform the two SB-Ultra's by a wide margin at 20Hz, and would at least break even at an octave above that.
Old 02-03-2016, 05:44 PM
rhale64L7's Avatar
Quoted: 694 Post(s)
Liked: 235
I am really not set on anything. But I would really be bummed if I sold my mfw15 and really should have just got another. I didn't like how it sounded with music with my xmc1 though. I found it either bloated and slow or if I turned it down, lacking in slam. So this is why I think I may like sealed slightly more. I wish I could have my cake and you know.
Old 02-03-2016, 05:48 PM
retro124's Avatar
Quoted: 860 Post(s)
Liked: 623
Just keep for now your sub and get SVS what model you want and you have free 45 days compare time and if you will feel you have no improvement what so ever just send it back. Really no risk at all. If you didn't try it "what if" will bother you for a long time.
stikle, mthomas47 and Matt2026 like this.
Denon X4000
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's, RS-52II's (soon for sale (maybe) :-)
SVS 2x PC12-Pluses
Sony XBR65X850B
Emotiva XPA-200 , Oppo 103D
Apple Mac mini, Sony PS3
retro124 is online now
Old 02-03-2016, 05:58 PM
mthomas47's Avatar
Liked: 1410
I think that good subs have come a long way since your old sub was made. The review I read was from exactly 8 years ago. And the Ultra remains at about the top of the food chain for sound quality, although it has been surpassed in terms of sheer output. As noted, above, it's pretty much a no-risk proposition to put an SVS sub on a credit card, audition it in-house, and decide whether you like it or not, before keeping it.
I believe that a PB-13 would blow your old sub away in every respect, including both power and speed. And my ported Ultra's have never sounded bloated.
Old 02-03-2016, 09:41 PM
gene4ht's Avatar
Quoted: 401 Post(s)
Liked: 336
Originally Posted by bear123 View Post
If you are going to mutually couple the two pairs of subs and only have the four subs in two locations, I think you would be better served upgrading from two PB2000's to two PB13 Ultras. More tuning options, lower extension, better finish quality, etc. And no issues with getting four subs playing properly together.
Appreciate the input bear...
As I currently have dual PB-2000's, I'm inclined to try both scenarios. I did audition a "single" PB13U last year and found that I preferred the dual 2K's overall. My primary objective is to gain more output and headroom while retaining the SQ of the 2K's. Tuning options and better finish are nice but are not priorities for me. Also and admittedly, my reluctance in moving forward with dual PB13U's is due to the increasing opinion that competitors are providing greater value and comparable or better performance due to the burden of PEQ amp. Now, having said this, I will most likely try "dual" PB13U's anyway. Thanks again!
Panasonic: PT-AE3000 Front Projector
Elite: 115" Fixed Frame CinemaScope (2.35:1)
Onkyo: TX-NR636 (5.2.2)
Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6
SVS: PB-2000 x 2
Panasonic: DMP-BD85
gene4ht is offline
Old 02-04-2016, 06:53 AM
boarder1995's Avatar
Quoted: 14 Post(s)
I'm running dual PB13 in 16Hz tune. Originally I had the 800w(?) BASH amp in one, but now have the 1000w Sledge amps in both. That made a bit of a difference in shear output and (IMO) better control down deep at/near their limits. I don't remember what DataBass PB13 Ultras were used, but that may have been with the older amp.
There are many offerings out now that do compete very well against the PB13, but I will say I've been very happy over MANY years with SVS. They aren't a quick pop-up company or the latest best flavor. Not that some of these new companies aren't as good or better, but only time will tell if they're long term stable. Of course, with management changes at some of them (SVS to PSA comes to mind), there's no guarantee with SVS either. But they do have a big presence and now are distributing through brick&mortar stores.
If I was starting from scratch, knowing what I know now, I'd still heavily consider the SVS PB13U for music and home theater (60/40 for me). BUT, I'd also heavily consider PSA (Triax perhaps, or others from them with XLR inputs), Seaton definitely, and Funk Audio. Lots of good options on the market for consumers - it's a good time to be in the market for a sub!
Why do all of my threads suck? Is there an internet posting school somewhere? -wes k
boarder1995 is offline
Old 02-04-2016, 06:58 AM
cchunter's Avatar
Quoted: 446 Post(s)
Liked: 740
Another thing you should be looking at is if the subs are going in the basement on a concrete floor. Concrete eats bass up for breakfast and leaves you little tactile feel unlike a suspended floor. In your case just get the PB's and leave nothing on the table. Your room is fairly big. The PB's might not even be enough to your liking.
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Oppo 103D Sony PS4
Panamax 5300PM
Samsung UN60F7100 3D LED
cchunter is offline
Old 02-04-2016, 07:09 AM
stygz's Avatar
Quoted: 56 Post(s)
I'm trying to maximize my PC2000 before I decide if I should get a second PC2000 or trade up to a Pc12 plus.
My room is about 2900 cu ft. This does not include the open space to the kitchen and sitting room. Audyssey has me set at -3 db and I run the subwoofer volume/gain about 1/3. I am looking for more impact while watching movies. I have been bumping the trim from -3 to 0. After making system changes I find my preferred listening volume to be from -35 to -25 area. Any harm to turning trim up even more? How much are many of you bumping the trine abouve Audyssey settings? The PC is currently corner loaded.
stygz is offline
Old 02-04-2016, 07:18 AM
retro124's Avatar
Quoted: 860 Post(s)
Liked: 623
Adding second sub will be great if you can place them correctly. 2 PC-2000 over single Plus I will take all day long. Plus is better sub then 2000 no question so if you want to stay with single sub then Plus will be winner for me. It is great sub and will give you what you looking for with movies or music and always there is option to add second one.
BTW you can get 1 PC-2000 and one Plus and compare them in your house for 45 days. I did it same thing before had home 2 PC12-Pluses and PC13-Ultra.
I run both my pluses 5db hotter then Audyssey set it up.
Denon X4000
SVS 2x PC12-Pluses
Sony XBR65X850B
Old 02-04-2016, 07:28 AM
Quoted: 18 Post(s)
If it is an either/or situation, definitely add the second PC-2000 to your set up. I also started with a single PC-2000 and debated going up the food chain or adding a second. Very glad I went with the second PC-2000 to help smooth out response and provide a ton more impact with headroom. My media room is ~2400 cu ft and it absolutely slams when called upon.
As pointed out, you can always audition both options in home and see what works best to your liking though.
Sent from my SM-G925V using Tapatalk
mmmmmmbacon is offline
Old 02-04-2016, 07:30 AM
stygz's Avatar
Quoted: 56 Post(s)
With dual pc, they would be along the wall. I don't have 2 corners to work with. A single PC 12 plus would fit in the corner.
We will have to see how taxes go. So far it looks like I will be paying in again which will delay my upgrade for a few months.
I will have to try running the trim up even more.
stygz is offline
Old 02-04-2016, 07:50 AM
rhale64L7's Avatar
Quoted: 694 Post(s)
Liked: 235
It is in basement. But it is on a stage made of 3/4" osb framed. The stage is filled with sand. It is also made so none of the outer edges touch anything. Erskine's idea. Floor to ceiling bass traps up on the stage also.
cchunter likes this.
Old 02-04-2016, 12:56 PM
AllenA07's Avatar
Quoted: 531 Post(s)
Liked: 423
To an extent I would always personally go with dual subs over a single more powerful sub. Now that being said, if I'm looking at dual BIC F-12's (a very capable budget sub FWIW) versus a single Submersive, I'm pretty sure I would side with the single sub. However in a situation where you're not taking that big of a step down, I would go with the duals. Dual subs is going to give you a smoother frequency response as you'll have much greater flexibility to deal with peaks and nulls.
AllenA07 is offline
Old 02-04-2016, 04:25 PM
mthomas47's Avatar
Liked: 1410
Hi,
The consensus over on the Audyssey thread is that the average sub boost post-Audyssey is about +3 to +6db. Your master volume is low enough that you can boost your sub trim level in your AVR by as much as you want with no problem. But just as a matter of best practice, it is generally recommended that you set your gain level higher the next time you run an Audyssey calibration, so that you can get your trim level deeper into negative numbers. Ed Mullen explains the reason for that in the FAQ, linked below.
I like a lot of bass boost for movies, so I try to get to a trim level of about -11 (even -6 to -9 would be perfectly fine). That way, I can add as much additional bass boost as I want without going much into positive numbers. Again, your MV is low enough that it will be absolutely no problem for you to add another 3 or 4db. But I like the idea of having an optimum set-up, just in case.
Mike
Old 02-04-2016, 05:53 PM
januza's Avatar
Quoted: 120 Post(s)
Liked: 67
Funny I watch movies with avr dialed in at +60-63 but run subs very hot adding 10db to audyssey.
januza is offline
Old 02-04-2016, 07:20 PM
mthomas47's Avatar
Liked: 1410
I'm pretty close to where you are. I might even go up to -14 (66) or so, and I add even more bass, post-Audyssey than you do. But, Reference: a master volume of 0.0, would run me right out of the room. Home theaters are already anywhere from about 5 to 7db louder than Reference (due to the smaller room effect with respect to early and late reflections) according to the film mixers who have posted on the subject. So, even they typically only listen at about -5 on their HT systems. Frankly, even -10 would seem uncomfortably loud to me, if the movie were very dynamic. I guess we all have a little different tolerance for loudness.
Old 02-04-2016, 07:27 PM
AllenA07's Avatar
Quoted: 531 Post(s)
Liked: 423
I generally listen pretty close to reference, if not actually at reference. Seems there is a wide range of what people like in terms of loudness.
mthomas47 likes this.
AllenA07 is offline
Old 02-04-2016, 07:29 PM
januza's Avatar
Quoted: 120 Post(s)
Liked: 67
I played the opening scene the other day of Edge of tomorrow with my ultras at -63 on avr and my iron front door flexed and vibrated so hard. Need a new door soon and have to leave it open. Hahahaha
januza is offline
Old 02-05-2016, 08:00 AM
COZisBack's Avatar
Quoted: 56 Post(s)
Liked: 50
Hi,
I was just teasing you about the clock--that once you have your first PB-1000, you might not be able to hold out for very long before getting your second.
Don't worry about where you bought your sub. As a matter of fact, I also got my first SVS sub, a PC-12 NSD, a number of years ago, from Amazon. My second one was a used PC-12 Plus, damaged in shipping. After that hassle, I decided to keep things simple and just buy all my subs directly from SVS. They really do have great customer service. But, it doesn't matter where you buy your subs, this thread is for everyone.
Mike
Originally Posted by COZisBack View Post
Don't worry, I didn't take it the wrong way. I was just trying to figure out if you were saying that I'll be buying the 2nd sooner than I think or something else. I will say, I'm definitely itching to buy another one already and the first one isn't even delivered yet.
So uhhhhhh.........
I guess it's time to update my signature to "2".
stikle, retro124 and mmmmmmbacon like this.
My Main Setup
Display: Panasonic TC-P60ST60 w/Acoustic Research ARRX18G XSight Touch
Sound: Yamaha RX-V375 / Pioneer AJ SP-PK52FS 5.0 / Dual SVS PB-1000s
Sources: DirecTV HR44/200 / Xbox One 500GB w/Kinect & 4TB External / 1st Gen Chromecast / HP EliteBook 8460p (Win10)
COZisBack is offline
Old 02-05-2016, 08:09 AM
mthomas47's Avatar
Liked: 1410
So uhhhhhh.........
I win!
But I think you're the bigger winner here. Let us know what you think.
COZisBack likes this.
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
taboola here
