Official SVS Owners/Support Thread. - Page 772 - AVS Forum | Home Theater Discussions And Reviews
 2479Likes
post #23131 of 23154 Old 02-07-2016, 06:24 PM
TJEli's Avatar
Originally Posted by madhuski View Post
I had the SB13 for a while, and I can echo the comments above that it can be a, in comparison, a bit lacking for movies. That's nothing against the SB13, but its asking a lot for a relatively compact 13 inch sub to go against, for example, bigger 15 inch subs.
here's my little journey to find my current sub:Deep Sea Sounds Mariana 18 Review
I replaced a perfectly functioning MFW15 with an SB13 Ultra in my 3000 cu ft room. I actually think the SB sounds better in all respects. In my room it is not lacking for movies. (Neither was the MFW). I did add a second one a week later but it had nothing to do with output. So far I am very impressed with them. Fwiw I have owned about 15 subwoofers ranging from DIY to a JL F113.
-Eli
AV Nut
TJEli is offline
post #23132 of 23154 Old 02-07-2016, 06:47 PM
saprano's Avatar
Quoted: 390 Post(s)
Liked: 408
Originally Posted by Mongo171 View Post
It's a square drive bit. SVS will send you the bit.
Really? Cool.
Originally Posted by NODES View Post
No pint in stressing out, SVS will take care of you.
I know. I wasn't expecting any problems so soon is all.
Once you figure out how to take it apart then you just paved your way into the world of DIY
Ha. Funny. Maybe it'll peak my interest to build my own sub.
home theater addict
saprano is offline
post #23133 of 23154 Old 02-07-2016, 06:56 PM
AllenA07's Avatar
Quoted: 423 Post(s)
Liked: 352
I was able to find the square bits at Lowes.
AllenA07 is offline
post #23134 of 23154 Old 02-07-2016, 07:07 PM
saprano's Avatar
Quoted: 390 Post(s)
Liked: 408
-Eli
I agree with this. I had an SB13 Ultra before and i never thought it wasn't enough for movies. Even now with the SB2000 i still find it sounds amazing.
home theater addict
saprano is offline
post #23135 of 23154 Old 02-07-2016, 08:51 PM
rhale64L7's Avatar
Quoted: 638 Post(s)
Liked: 203
-Eli
Wow this is great to know. I sold my mfw15 and was starting to get second thoughts.
So you like the sb13u more? In what ways?
rhale64L7 is online now
post #23136 of 23154 Old 02-08-2016, 12:24 AM
valkenaar's Avatar
Quoted: 14 Post(s)
Prime Satellite center
I'm considering replacing my hodge podge 5.1 with five Prime Satellite speakers (and my SB 2000). Anyone have experience using the center channel horizontally? Should I be worried about any strange waveform problems?
I was thinking it put some rubber feet on it so it doesn't rattle, etc.
Panasonic P60ST60
Sony BDP-S3100
Denon X2000
valkenaar is offline
post #23137 of 23154 Old 02-08-2016, 05:29 AM
madhuski's Avatar
Quoted: 273 Post(s)
Liked: 150
-Eli
Being a relatively smaller sub, the SB13 will give up quite a bit in lower bass compared to the bigger and/or more expensive subs out there. Now with his importance placed on music, the OP may not care.
@rhale64L7 whats your overall budget? Any size/WAF restrictions?
Salk Speakers. Deep Sea Sounds Subwoofer. Mastiff Dog
My Living Room HT
madhuski is offline
post #23138 of 23154 Old 02-08-2016, 07:40 AM
rhale64L7's Avatar
Quoted: 638 Post(s)
Liked: 203
Budget is 2000.00 and wife doesn't care it's in a dedicated theater.
But believe it or not I am the one that doesn't want a big black squared edge box. My buddy can get me Jbl monster pro theater subs at cost.
Actually I have a perfect setup for infinite baffle subs and actually considered it. But if I ever move into a smaller place I want to be able to pack it all up and go.
I would have more placement options if it is no taller than 22". This will allow them to be placed anywhere along the front wall.
I am going to probably start with one. But definitely will want another identical sub in the near future. Dsp will be a big consideration because I am using Dirac on my xmc1. And it has a problem with two subs.
post #23139 of 23154 Old 02-08-2016, 08:24 AM
TJEli's Avatar
To my ear it just sounds better. The MFW was a great design and performed extremely well for its price. I try not to use buzz words that mean different things to different people but the SB13 is "tighter" and "punchier" than my MFW was. In my room it was easier to get a smooth response with a single SB13 vs a single MFW. Less EQ was needed. I am not giving up anything in the subsonic range and it actually sounds cleaner to my ears. Remember though.... my room doesn't need a whole ton of "Subwoofage" to get good response at the MLP.
Our audio memory is extremely subjective but from what I remember the SB13 sounds a LOT like the F113 I use to own.
-Eli
tommaazz likes this.
AV Nut
TJEli is offline
post #23140 of 23154 Old 02-08-2016, 08:48 AM
rhale64L7's Avatar
Quoted: 638 Post(s)
Liked: 203
Tighter and punchier is what I am looking for.
And I have been told the sb13u sounds a lot like the jlF113 by a few people. Just not as much output.
davelr likes this.
post #23141 of 23154 Old 02-08-2016, 09:29 AM
madhuski's Avatar
Quoted: 273 Post(s)
Liked: 150
At 2k, yeah you're not going to be able to have your cake (high output, good extension, good musicality, good WAF) and eat it too.
Subs I'd consider would be the SB13, some of the Rythmik's (FV15-hp, F15hp if you want sealed) , or see if I could find a used Submersive
JTR just dropped the price on he S1 as well to $1999. Jim Wilson had the SB13, s1 and the Rythmik e15; you could alwYs drop him a pm and get his thoughts as well
edit: keeping in mind all this is relative. A $1600-2000 sub is generally going to be fantastic; but with that budget you're getting into the territory of having lots of options, some of which may make more sense.
My Living Room HT
madhuski is offline
post #23142 of 23154 Old 02-08-2016, 01:30 PM
saprano's Avatar
Quoted: 390 Post(s)
Liked: 408
So it seems my problem was with the volume nob. I was told debris can get inside and mess with it. That was the reason for the constant bloated volume level. So i had to press it in a little and turn in back and forth to reset everything. Problem solved.
I don't know if that's related the scratching noises when playing test tones, i didn't get a chance to test it again. I'll do that later on tonight.
I have to monitor the sub for awhile and get back to SVS with a video of the problem should it arise again.
home theater addict
saprano is offline
post #23143 of 23154 Old 02-08-2016, 02:49 PM
AllenA07's Avatar
Quoted: 423 Post(s)
Liked: 352
Box size is going to directly influence output, so you're not going to be able to get a small sub that is also small. If aesthetics are a really critical factor for you, you might want to look in Funk Audio. They're going to be a little above your $2000 budget (or several thousand depending on the model), but in terms of high performance and looks they are probably the best bet out there.
AllenA07 is offline
post #23144 of 23154 Old Yesterday, 06:23 PM
rhale64L7's Avatar
Quoted: 638 Post(s)
Liked: 203
Them Funk subs are pretty nice looking. But to pricey for me. All their own parts in them also from what I can figure out. Nice !!!!
cchunter likes this.
post #23145 of 23154 Old Today, 12:45 AM
COZisBack's Avatar
Quoted: 20 Post(s)
My 2nd PB-1000 arrived yesterday afternoon. I got it hooked up and I'm already in love. I do feel like I need to better adjust the volume, I'm currently at 12 o'clock on both. Any recommendations? Yamaha RX-V375 with Pioneer AJs in a 1904 ft listening space opening to a kitchen for a total space of 3640ft3.
COZisBack is online now
post #23146 of 23154 Old Today, 03:23 AM
Michael Bruce's Avatar
Quoted: 24 Post(s)
Liked: 35
Ive always put my SVS subs dial in the 2 o'clock position
COZisBack likes this.
5.1 setup
5 def tech sm 45s
svs pb-2000
denon avr x2200w
Michael Bruce is online now
post #23147 of 23154 Old Today, 03:39 AM
Bond 007's Avatar
Quoted: 1294 Post(s)
Liked: 1341
Thats irrelevant for everyone but you. And probably not the best setting even for yourself.
Bond 007 is online now
post #23148 of 23154 Old Today, 03:56 AM
Bond 007's Avatar
Liked: 1341
Since the 375 only has 1 preout you must be using a splitter. You need to level match or gain match your subs.
Setting a single distance for 2 subs can be difficult but should really be done also.
post #23149 of 23154 Old Today, 03:58 AM
januza's Avatar
Quoted: 106 Post(s)
Liked: 65
Run those suckers hot. I run mine very hot.
januza is online now
post #23150 of 23154 Old Today, 04:08 AM
COZisBack's Avatar
Quoted: 20 Post(s)
Yes, using a splitter. They're match in actual distance and physically set gain. I'm waiting on my friend's tripod to rerun YPAO.
My Main Setup
Display: Panasonic TC P60ST60 w/Acoustic Research ARRX18G XSight
Sound: Yamaha RX-V375 / Pioneer AJ SP-PK52FS 5.0 / SVS PB-1000 x 2
Sources: DirecTV HR44/200 / Xbox One 500GB w/Kinect & 4TB External / 1st Gen Chromecast / HP EliteBook 8460p (Win10)
post #23151 of 23154 Old Today, 04:34 AM
Bond 007's Avatar
Liked: 1341
Actual distance is irrelevant. Room placement will change gain.
post #23152 of 23154 Old Today, 04:50 AM
COZisBack's Avatar
Quoted: 20 Post(s)
Gotcha, they're either going to be corner placed or close to 1/4 wall placed on the "front stage" after my fine tuning testing.
post #23153 of 23154 Old Today, 05:01 AM
Bond 007's Avatar
Liked: 1341
Sub placement is critical for best performance.
Why would you do "fine tune testing" (whatever that is) and then place the subs?
post #23154 of 23154 Old Today, 05:06 AM
COZisBack's Avatar
Quoted: 20 Post(s)
Sorry, still waking up. Placement, then "fine tuning" of adjusting volume, running YPAO and small AVR settings tweaks.
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
