Official SVS Owners/Support Thread. - Page 774 - AVS Forum | Home Theater Discussions And Reviews
 2495Likes
post #23191 of 23200 Old Today, 08:07 AM
movies2090's Avatar
Just ordered some svs ultra tower to round out my ultra line. Have a question though, can anyone tell me the height of the tweeter from the floor? Gonna redo my center speaker and would like it set up correctly before towers arrive
movies2090 is offline
post #23192 of 23200 Old Today, 08:36 AM
AllenA07's Avatar
Quoted: 434 Post(s)
Liked: 361
Originally Posted by Defcon View Post
Thanks for the replies guys. How would I go about integrating the PB-2000 and 25-31? I asked the SVS guys this and Ed said its not advisable. But then there are many of you in this thread running different dual subs happily.
I run dual, mismatched, subs. You need two subs that have similar capabilities. I talked with SVS before mixing my Plus and Ultra and was told that because they had they have the same tuning frequency they could work together. Likewise, while the Ultra has considerably more output it isn't to the point that the Ultra completely overwhelms the Plus. Advice I was given is that typically you can mix and match with SVS as long as you're just going one model up or down. So a Plus and an Ultra is fine, a Ultra and PB-2000 isn't.
Now the setup is definitely more challenging with mismatched subs. REW and a measurement mic are basically requirments, otherwise you're doing to a lot of guess work. Also either a MiniDSP or a receiver with Audyssey XT32 and SubEQ will make life so much easier. Placing the smaller sub a little closers will also help make up for the difference in power.
Under the right circumstances mismatched subs does work, you just need the right subs and the equipment to make it work. It's not exactly a plug and play experience.
AllenA07 is online now
post #23193 of 23200 Old Today, 09:26 AM
ceh383's Avatar
Quoted: 219 Post(s)
Liked: 1287
^^^Exactly correct^^^
My 2 subs are from different manufacturer's, everything about them is different, but the output and FR looked close enough to make them work.
For me the miniDSP and measurement equipment were a must!
Yamaha RX-A2020 | Outlaw M-5000 | Oppo BDP-103 | Sony CDP-CE500
Definitive Technology BP-8060ST :
CS-8040HD : SR-8040BP | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP 2x4 : DDRC-88A | Belkin PureAV x2
http://www.rpm-psi.com
ceh383 is online now
post #23194 of 23200 Old Today, 09:40 AM
mthomas47's Avatar
Quoted: 978 Post(s)
Liked: 1010
SVS would be able to tell you precisely, but just for fun I estimated it by looking at the photos and dimensions. Around 31.5" or 32" to the center point of the tweeter should be pretty close.
FWIW, even if the tweeters on the fronts and the CC were not at identical heights, I would concentrate on the height of the CC with respect to seated ear height at the MLP. For most people, measuring to the center of the ear canal, that would probably be in a range from about 30" to 34". Based on that, you should be right in the sweet spot.
mthomas47 is online now
post #23195 of 23200 Old Today, 11:12 AM
movies2090's Avatar
Yeah I did contact them but haven't heard back . Was thinking that'd be around where I guessed too. I have 28" speaker stands that I'm currently using for my bookshelves that I was hoping would work for my center. From the sound of it, should work out great
post #23196 of 23200 Old Today, 12:14 PM
mthomas47's Avatar
Quoted: 978 Post(s)
Liked: 1010
The 28" stand would put your center at just about 34" to the center of the tweeter, so you should be fine. Please let me know when you get actual dimensions. I would like to know for future reference. I imagine you are a little excited.
post #23197 of 23200 Old Today, 12:44 PM
Defcon's Avatar
Quoted: 400 Post(s)
Liked: 183
Update - I scored a good deal on a outlet PB-2000, it should ship next week! I'm already an SVS customer (old cylinder sub) but the outlet prices were a bigger factor
I've been thinking about an upgrade for a while and looking at all the usual suspects in the $1k range. As much as we like to compare and contrast the subs and debate numbers endlessly, I don't think any of the ID subs is bad. I was considering PSA, RA, SVS, HSU, Rhythmik and also a DIY 18". In the end what made my decision is I figured that at moderate listening below reference levels, there isn't much to choose and it'd be very hard to tell the difference.
I wouldn't have minded a PC-2000 due to lighter weight and to match my existing cylinder and it also seems to have a 1Hz lower extension (which I guess is due to higher volume in the tube?) but again I doubt if that's audible.
I'm quite curious now how much improvement I will hear after 2 generations (ISD to NSD to new driver, new amps) of changes.
gene4ht and mthomas47 like this.
Defcon is online now
post #23198 of 23200 Old Today, 01:01 PM
gene4ht's Avatar
Quoted: 301 Post(s)
Liked: 253
Originally Posted by stikle View Post
I've got the Prime Towers, Prime Center, dual PB-2000, and can tell you that my front soundstage is phenomenal.
Hi Seth...you and I (and a few others here) are running dual PB-2000's and you're right...they sound "phenomenally" good and contribute significantly to the excellent sound stage. But there is someone in these threads who is running four PB-2000's...just can't remember who. I'm asking because it's in the back of my mind to try quads. I like the 2K's SQ so much that I think I would even prefer quad 2K's ...believe it or not...over dual PB13U's...anyway, just thoughts for now.
Panasonic: PT-AE3000 Front Projector
Elite: 115" Fixed Frame CinemaScope (2.35:1)
Onkyo: TX-NR636 (5.2.2)
Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6
SVS: PB-2000 x 2
Panasonic: DMP-BD85
gene4ht is online now
post #23199 of 23200 Old Today, 05:56 PM
PlasmaPZ80U's Avatar
Quoted: 1272 Post(s)
Liked: 339
I just connected my SVS Prime Bookshelves to the HTR-3066 and keep getting E-8 No Signal error/message... no other speakers are connected except sub and when I play manual test tones from the AVR both FL and FR channels are loud and clear. Had no error message before with Sony Bookshelves. The only thing I could try and see is if the 2ch stereo mode is the culprit.
What else could be the cause? Don't think the YPAO mic suddenly went bad and mic cord looks fine.
EDIT: Straight mode didn't help.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, Sony Core (Sony SS-CS5) Mains and Center (Sony SS-CS8), Rythmik LV12R; PS4, Xbox One, Motorola RNG150N
PlasmaPZ80U is online now
post #23200 of 23200 Old Today, 06:50 PM
retro124's Avatar
Quoted: 817 Post(s)
Liked: 565
Gene, just go for it, when you will have time order another dual PB-2000 and play with them to see if that is what you been looking for. Nothing worst then send them back will not happened. I'm getting scared because you know me I try to keep up with you so I will start looking for another dual Pluses. Will have to sell some furniture
Denon X4000
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's, RS-52II's (soon for sale (maybe) :-)
SVS 2x PC12-Pluses
Sony XBR65X850B
Emotiva XPA-200 , Oppo 103D
Apple Mac mini, Sony PS3
retro124 is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
