Official SVS Owners/Support Thread. - Page 835 - AVS Forum | Home Theater Discussions And Reviews
 3907Likes
Old 11-06-2016, 06:34 PM
Maddmaster's Avatar
Quoted: 75 Post(s)
Liked: 31
That new Ultra 16 looks very inviting but I'm already rattling the ceiling and walls. Pictures in other rooms rattle.
Definitive Technology:Front Height - Mythos Gem XL
Front - Mythos ST, Center - Mythos 10 & 8
Side Surround - Gem XL
Back Surround - Gem XL
Sub - Supercube Ref & SVS SB13 Ultra
There can never be enough music
Maddmaster is offline
Old 11-07-2016, 09:28 AM
dabsabre's Avatar
anyone experience this before? picked up a pair of PC-2000s about 18 months ago. a couple of weeks ago one of them just started to make a host of low bass rumblings, etc.. when plugged into the wall and hooked up to the AVR but the system was off. It's behind an AT screen so it was easier to just unplug the power but about a week ago the 2nd one started doing the same thing. on this one, it's easy to unplug the coax cable going to it as well as the power. unplugged the power and noises stop. plugged the power back in, disconnected the subwoofer cable and the noises still continue so I assume it's an issue with the amps.
haven't even stressed out the subs at all recently as it's been nothing but MLB/NFL/NHL games in the media room of late. got a note into SVS to see what the next steps are.
dabsabre is offline
Old 11-07-2016, 09:34 AM
leedesert's Avatar
Quoted: 245 Post(s)
Liked: 130
So I tried this soundtrack "Throbberizer-dub" (Courtesy Imagic) that is a torture test for subs and at the lowest point I can hear the speaker excursions making a flapping noise. I'm assuming those were at the furthest low end extension of my PN-2000. Is it safe for me to play this with the speakers movement noise or is that my speaker telling me to back off?
https://soundcloud.com/psychedelicious/throbberizer-dub
valkenaar likes this.
Samsung 65KS-8000 VAA02, Xfinity X1 DVR, Xbox One, Samsung UBD-K8500
Onkyo TX-NR747, Set up: Atmos 5.1.2
Klipsch R-15 (L/R), Klipsch R25 (C), Polk Rc80i (SS), Polk Rc80i (FH)
Subs: SVS BP-2000, Paradigm PDR-10 (For Sale)
Amazon Echo, Harmony Hub, Harmony Ultimate One, Samsung Smartthings Hub, Z-wave lights throughout
leedesert is offline
Old 11-07-2016, 10:45 AM
Alan P's Avatar
Quoted: 4764 Post(s)
Liked: 3399
Originally Posted by paulfromtulsa View Post
Do any of you guys use the left and right input on yku subwoofers? Is there any benefit by using both? I'm currently just using the left input but was wondering if I should use both? Thanks
The guys have told you when you should use both inputs, but not really why it works.
Using both inputs will raise the input signal +6dB. If you find that you need to use both inputs to keep the sub's auto-off function from engaging prematurely, you will need to turn the gain down on the sub approximately 6dB and re-run auto setup on your AVR.
Alan P is offline
Old 11-07-2016, 10:52 AM
Mongo171's Avatar
Quoted: 833 Post(s)
Liked: 1262
Yessir, Lord Alan. I will leave all issues for you to address.
Your loyal, but incorrect, peasant Mongo
Mongo171 is offline
Old 11-07-2016, 11:49 AM
leedesert's Avatar
Quoted: 245 Post(s)
Liked: 130
It sounds like you have a ground problem on your AC. The amp may be seeing a difference between it's AC plug ground and the ground going to your source (AVR) via it's AC plug ground.
I would ground the chassis of the AVR to the house ground and see if that breaks the loop.
If it's doing it even with the audio unplugged at the back of the sub it's internal and coming from noise on AC line your plugged into.
Old 11-07-2016, 11:59 AM
mthomas47's Avatar
Quoted: 2571 Post(s)
Liked: 3217
Hi,
I would back off anytime I heard a speaker or a sub make noises indicating audible distress. SVS subs are built to be pretty bulletproof, so I can't say for sure that you would damage anything, but I would personally prefer to play it safe.
Mike
mthomas47 is offline
Old 11-07-2016, 12:00 PM
Matt2026's Avatar
Quoted: 376 Post(s)
Liked: 14142
You might want to ask Mark (Imagic) about it. I ran it fairly low and it warmed up the plate amp so I know not to crank it up too loud and your situation sounds like your sub is getting into a danger zone. My sub is servo/sealed. I'll assume your sub is a PC-2000 which is ported and below port tune the speaker has no constraints on it like a sealed speaker has. I suspect you are in dangerous territory if its flapping around I also have a rumble filter setting so that rolls off frequencies below 20Hz.
Take care.
mthomas47 likes this.
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; LRS/L/R SVS Ultra BS, Ultra Center;
RRS Celestion 5; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-1, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
Old 11-07-2016, 12:02 PM
dabsabre's Avatar
but any explanation as to why it was working just fine as connected for the better part of 18 months before it starting having this issue?
dabsabre is offline
Old 11-07-2016, 12:11 PM
leedesert's Avatar
Quoted: 245 Post(s)
Liked: 130
Have you added any thing to the same circuit (side of your relay box) that that AC outlet is on? It could be something else on that phase of the electric circuit generating the noise. Try un-plugging the sub and plugging into an outlet found on the opposite side of your relay panel. If the noise goes away you found your issue.
Once you try that plug back into the original outlet and make sure the noise is still there. Make sure you turn the sub amp on because most have there subs in standby mode so the amp won't come on unless it see's enough audio. The noise might be enough to play through once the amp is on but not enough to make it turn on.
Old 11-07-2016, 12:17 PM
leedesert's Avatar
Quoted: 245 Post(s)
Liked: 130
Take care.
I have the PB but I'll back off from playing that.
Old 11-07-2016, 12:22 PM
Alan P's Avatar
Liked: 3399
Not sure if this was meant to be as snarky as I have interpreted it ...but I didn't mean to offend you or anyone else, and technically you weren't incorrect. I was just letting the OP know that using both inputs will require him to turn the sub down, that's all.
Alan P is offline
Old 11-07-2016, 12:31 PM
Mongo171's Avatar
Quoted: 833 Post(s)
Liked: 1262
Then ADD to the conversation. Don't just come out and say everyone was wrong, I am correct.
If he's hooking up both inputs, obviously he has to connect the sub BEFORE calibrating the sub. Then guess what he has to do? Give up? Turn the sub down to the correct level.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
Old 11-07-2016, 01:02 PM
Alan P's Avatar
Liked: 3399
I feel like I did add to the conversation, and please show me exactly where I said "everyone was wrong"?
He obviously (to me at least) has already calibrated the sub...he said "I am currently using only the one (input)".
I was just trying to help the OP by giving him all the available information on the subject and had no intention of trying to put anyone down.
Matt2026 likes this.
Alan P is offline
Old 11-07-2016, 01:11 PM
mthomas47's Avatar
Liked: 3217
I don't want to get in the middle of anything here, but I see this whole thread as a collaborative conversation, where we all add to what each other is saying. And, it's rarely a matter of "everyone else is wrong". It's more a matter of adding viewpoints, or detail, that the first, or even the second person didn't mention. Both of you guys make great contributions, and some other people do too. Pax?
Alan P and Matt2026 like this.
Mongo171's Avatar
Quoted: 833 Post(s)
Liked: 1262
When I answer someone, I don't get technical at first because I don't know if that person is just starting out and doesn't understand what a Bel is. Your first sentence said that we explained when it should be used, not why.
Then you give him the wrong advice.
Mongo171 is offline
Bond 007's Avatar
Quoted: 2381 Post(s)
Liked: 1918
You are both excellent contributors. No need to carry on with this any further.
Bond 007 is offline
Old 11-07-2016, 01:12 PM
Mongo171's Avatar
Quoted: 833 Post(s)
Liked: 1262
Sorry. We'll take this offline.
Mongo171 is offline
Old 11-07-2016, 01:35 PM
Pulloutchamp's Avatar
Quoted: 36 Post(s)
Liked: 36
Originally Posted by AllenA07 View Post
I'm glad to hear the cylinder is safe, as I'm sure there are far fewer of us out there who want that style of sub. That being said, if not for the cylinders I'm not sure I could fit an SVS sub.
I really was thinking of going PB-16 , from my dual PC-2000's , but after seeing the review of the PB16 and the picture of it next to the reviewer.....UMMMMM no , lol , thats a Sherman Tank! I really like the Cylinders and want to take advantage of the upgrade , just dont know whether to get the Pluses or the PC-Ultra.....Going to be keeping a close eye on the the SVS outlet , there should be plenty of traded in subs!
Pulloutchamp is online now
Old 11-07-2016, 01:41 PM
mthomas47's Avatar
Liked: 3217
Hi,
I like the cylinder form too. That was the first SVS sub I had, and I have always liked the way they look. If I were you, and could afford it, I would move on up to the PC13's. I have had both the Pluses and the Ultras and enjoyed having the extra output and extension that the Ultras provide.
Mike
Old 11-07-2016, 02:07 PM
Quoted: 32 Post(s)
Liked: 6
I am really enjoying the PC13 Ultra. It's in a 6000 cubic foot room and still does an incredible job. The only complaint (from my wife) is the size. Yes, it's a smaller footprint than the PB, but it's still the size of a small water heater. I can't imagine having two of them this size.
Bilious72 is offline
Old 11-07-2016, 02:39 PM
Alan P's Avatar
Liked: 3399
I would agree that this should be taken offline if it just became an argument, however I believe the OP in this instance deserves this to be cleared up in short order, and in this thread.
I guess you're getting too technical for me here...I have no idea what a "Bel" is. Is that short for decibel? If so, you may be right in this case...but regardless, he needs to know that by using a y-splitter he will be adding output to the sub (and subsequently using 3x the amp power). This can whack your calibration in short order.
At the very least, you could have mentioned that when using a y-splitter he will have to turn the sub down "substantially", or "quite a bit"...not using any technical terms at all.
Just so there is no confusion, exactly what was wrong with my advice? I'm asking sincerely, because if the added 6dB by using both inputs isn't how it works on this particular sub, I would like to know for future reference. I suppose you could be referencing my advice to re-run auto setup on the AVR...but if the guy doesn't know what a decibel is, I would assume he doesn't have an SPL meter...so re-running the cal would be the easiest way, no?
You still haven't shown me where I said "everyone was wrong".
Alan P is offline
Old 11-07-2016, 07:06 PM
confinoj's Avatar
Quoted: 118 Post(s)
Liked: 61
Originally Posted by confinoj View Post
Just set up a new PC-2000. It's replacing a pb-1000 that I'm returning. Denon 1912 avr. I noticed that when the the sub first triggers on or if you pause or resume a source with low frequency content there is a slight popping noise from sub. Pb-1000 was silent. Is this normal? It otherwise sounds fine.
Customer service says this is normal with some avr/sub combinations. They said it's indicative of a problem when louder and random. It's not very loud but definitely audible soft pop (sounds more like a soft knock actually) more noticeable when content playing is softer. It happens when sub is first triggered on or when playing content with LFE active and I do something like a 30 sec skip forward or back but not necessarily when I just pause content. Funny it didn't happen with the PB-1000 I sent back or the other sub I also tried out (RSL speedwoofer 10s). Anyone else have this with an SVS sub? Avr is a Denon 1912. Otherwise sub sounds fine during playback.
confinoj is online now
Old 11-08-2016, 04:44 AM
Ed Mullen's Avatar
Quoted: 93 Post(s)
Liked: 283
Using a Y splitter doubles the input voltage via an inverted op amp voltage summer. Doubling the input voltage causes the subwoofer to play 6 dB louder (as compared to a single-ended input). In order to keep the same calibration level (as compared to a single ended input), the gain control must be reduced 6 dB.
There is no real need to use a Y splitter on our subs, as the current generation of amps only needs 3-5 mV signal strength to wake-up the sub from standby and keep it in On mode. And the time-out to standby is about 15-20 min. It's hard to imagine a scenario (even at low volumes) where the sub doesn't see at least 3-5 mV during a 15-20 minute span.
Alan P, valkenaar and mthomas47 like this.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
Old 11-08-2016, 05:12 AM
Bond 007's Avatar
Liked: 1918
My Rythmik LV12r and Yamaha 2030 does the same thing.
Bond 007 is offline
Old 11-08-2016, 05:29 AM
leedesert's Avatar
Quoted: 245 Post(s)
Liked: 130
Mine won't turn on at normal TV listening levels. I have to turn up my AVR to movie watching level, which is fairly loud, in order for it to turn on. Many times while watching a show the sub will turn off because it's not seeing any input.
Old 11-08-2016, 05:39 AM
Mongo171's Avatar
Quoted: 833 Post(s)
Liked: 1262
Increase just the gain on the sub until it comes on at the desired volume.
Mongo171 is offline
Old 11-08-2016, 06:01 AM
leedesert's Avatar
Quoted: 245 Post(s)
Liked: 130
I already have the sub at 2 o'clock. I don't think I should need to turn it up more than that.
Old 11-08-2016, 06:54 AM
Bond 007's Avatar
Liked: 1918
Yamaha receiver?
Turn up the sub level in avr and turn down sub volume at the sub. The avr will send a stronger signal at lower volume.
Bond 007 is offline
Old 11-08-2016, 07:13 AM
Ed Mullen's Avatar
Quoted: 93 Post(s)
Liked: 283
Are all your speakers set to Small with a 60-80 Hz crossover? If some/all are set to Large (full-band), then that can cause auto-on problems.
If all speakers are set to Small and the sub still isn't waking up until movie watching level, then contact SVS CS at custservice@svsound.com and we can continue troubleshooting and (if needed) replace the amp.
Ed Mullen
SVS
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
