Official SVS Owners/Support Thread. - Page 842 - AVS Forum | Home Theater Discussions And Reviews
 3541Likes
Old Today, 06:48 PM
mthomas47's Avatar
Quoted: 2110 Post(s)
Liked: 2530
Originally Posted by Magellan55 View Post
Agreed, when the main reason to add a second sub is to even out the frequency response. You'll still benefit from the additional headroom with colocated subs, though not much when mixing subs like the OP is doing. Found this cool site that helps determine the additional dB gain from multiple subs, both identical and non-identical. They need to be in phase and of course playing the same material to use this chart (otherwise you need to use the "incoherent" version - in a nutshell the combined dB is mostly cut in half from these numbers). It also points out decreasing returns as you add more subs:
http://www.sengpielaudio.com/calcula...entsources.htm
So 2 identical subs would increase headroom by 6 dB, adding a 3rd adds an additional 3.6 dB, and a 4th only adds 2.4 dB. Of course, those extra subs also further smooth the frequency response, so everyone in the room feels it! But if you add an SB2000 to an SB13u, because they are not equal power you won't get a 6 dB gain. Assuming an average 7 dB difference between the two, adding an SB2000 to an SB13u only gives you an extra 3.2 dB. Not bad, but probably not worth the price of the SB2000 if you just colocate it and only buy it to add some headroom.
One other thing to point out, these charts assume the sources are colocated. Once they get about a 1/4 wavelength apart, they won't be in phase anymore, and that additive power will decrease. I noticed this on my own setup running REW, with my SB2000's about 10 feet apart. That's the 1/4 wavelength for 30Hz, and sure enough, above about 35 Hz I saw a gradual decrease in the effect of adding the second sub, from 6 dB down to 4 dB @ 50 Hz and 3 dB (incoherent) pretty much after that. They weren't co-located, so different responses to room nulls between them started dominating at that point in my test, but I would imagine they would see coherent effects again as they got close to full wavelength frequencies in the 90-150 Hz range. Subs further apart than 10 feet would see coherent effects die off lower than 30 Hz.
I deliberately didn't mention the issue of increased SPL, from adding a second sub, or via mutual coupling, because I didn't think it was really that relevant to the OP's goals, which seemed to be more FR related. He mentioned trying to smooth out nulls. I have experimented with mutually-coupled (identical) subs, and there certainly can be some circumstances where that really makes sense.
But, where one sub is substantially more powerful than the other--6 to 8db, in this case, placing the two subs together really doesn't offer an advantage that would justify the expense of a second sub. The only way that I can see the OP gaining a meaningful advantage from pairing a 2000 with an Ultra, is if the 2000 is substantially closer to the main listening position than the Ultra. Otherwise, he will simply have to keep the gain setting on the Ultra comparatively low in order to achieve any sort of acoustic balance, and any consequent improvement in overall frequency response.
You made a good point with respect to the uncertainty of SPL gain even from two similar or identical subs at frequencies above 1/4 wavelength. As Josh Ricci demonstrated in an article sometime back, the actual SPL gain from adding a second sub is highly dependent on room modes, and is very difficult to predict. Given reasonably good locations, though, ideally on opposing walls, some gain should definitely be achievable.
mthomas47 is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
